Front beam inspection plate bolt size?
Jon's62
Jon's62 is offline
PostPosted: Wed Jun 24, 2015 5:26 am    Post subject: Front beam inspection plate bolt size? Reply with quote
I seem to have misplaced my bolts! I am referring to the plate that sits behind the front beam. Are these a special size or could one find them at a nut and bolt supply? I checked the big blue factory manual but couldn't find any details. Any help would be appreciated,
Jon
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Wed Jun 24, 2015 5:31 am    Post subject: Reply with quote
nothing special, just 6 mm
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
Jon's62
Jon's62 is offline
PostPosted: Wed Jun 24, 2015 5:50 am    Post subject: Reply with quote
That does help, thank you! If that's the case I should be able to get a nice pair of stainless hex bolts that fit.
Cusser
Cusser is offline
PostPosted: Wed Jun 24, 2015 6:21 am    Post subject: Reply with quote
You mean you drive a 50 year old VW and you don't have any spare metric hardware around ????
Jon's62
Jon's62 is offline
PostPosted: Wed Jun 24, 2015 8:12 am    Post subject: Reply with quote
Point well taken! I have been making a habit of replacing and keeping spare bits on hand; This one had me stumped as I could not remember the size. As a rule though if I need 2 bolts I buy 4 or 6. Except those shock mount bolts at $22.00 a piece! I actually have never driven it....yet.
Northof49
Northof49 is offline
PostPosted: Wed Jun 24, 2015 8:46 am    Post subject: Reply with quote
For mounting the shocks, I am simply using Grade 8 SAE hardware. Same with the axle to swingarm fasteners. They are just more readily available, and work fine.
1958 Karmann Ghia owner
scottyrocks
scottyrocks is offline
PostPosted: Fri Apr 07, 2017 3:13 pm    Post subject: Re: Front beam inspection plate bolt size? Reply with quote
Same bolt (6mm) for the inspection plate under the rear seat? Or is it the same as the what I think is a smaller bolt as on the steering box inspection cover plate in the front trunk?
67rustavenger
67rustavenger is offline
PostPosted: Fri Apr 07, 2017 3:49 pm    Post subject: Re: Front beam inspection plate bolt size? Reply with quote
Scotty,
The inspection plate is held in place by a IDK, 2.5-3mm sheet metal screw. Not a 6mm bolt. The screw is about 10-12mm long.
If you need a pic I can take one for ya.
Good Luck.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
scottyrocks
PostPosted: Fri Apr 07, 2017 4:21 pm    Post subject: Re: Front beam inspection plate bolt size? Reply with quote
Is that what is known in the building trade as a 'zippy?' If so, I have a million of them.
I also have buckets of various sized cabinet hinge screws.
67rustavenger
PostPosted: Sat Apr 08, 2017 5:30 am    Post subject: Re: Front beam inspection plate bolt size? Reply with quote
Go with the pan head screw. Rounded top with short straight sides.
Buy Once, Cry Once!
scottyrocks
PostPosted: Sat Apr 08, 2017 8:08 am    Post subject: Re: Front beam inspection plate bolt size? Reply with quote
Thanks! I'm gonna go with whatever threads in properly. Smile
