Correct Size Tool To Remove Axle Bolts Or CV Bolt
Tcash
Tcash is offline
PostPosted: Wed Apr 17, 2013 5:40 am    Post subject: Correct Size Tool To Remove Axle Bolts Or CV Bolt Reply with quote
Thanks Wildthings.
Wildthings wrote:
Clean each socket well with a pick or small screwdriver, hammer the tool into the socket, remove and clean again. Hammer in one more time and hope for the best. My choice is to buy a 4" or 6" long tool as it will interfere with the boot less than the shorter variety.
The Allens are 6mm as others have stated, while the triple square is an 8mm, IIRC.
Wasted youth
Wasted youth is offline
PostPosted: Wed Apr 17, 2013 7:28 am    Post subject: Reply with quote
Napa sells that tool, by itself so you don't have to buy a set. I cannot recall the part number of the tool, but it is under $7. Also be wary that you might have allen socket screws installed, as were mine on several bugs/busses over the years. Just have both tools on hand.
guitarman63mm
guitarman63mm is offline
PostPosted: Wed Apr 17, 2013 7:39 am    Post subject: Reply with quote
Wasted: When I asked for a triple square / XZN bit at Napa, they looked at me all bug-eyed. Shocked Same for the other FLAPS I tried.
I made due with my old bolts and a standard hex for a while, just tack one of these onto your next order. I'm pretty sure this one was an EMPI-branded tool, so meh, but it gets the job done.
http://www.busdepot.com/5796
Jimmy
- 1974 Safaré Custom Camper. 091 trans + Dual Weber 34 ICTs + Pertronix SVDA + 1.7L 914 T4 engine.
Randy in Maine
Randy in Maine is offline
PostPosted: Wed Apr 17, 2013 8:22 am    Post subject: Reply with quote
After cleaning the bolt heads, I just put the 8mm triple square socket on my cordless impact driver to remove them. Give them a little love pat with a hammer to make sure the socket is well seated in the bolt head. That makes quick work out of it.
I like to use new bolts when I go to re-install, then I just use the impact driver to get them all started. Once all are started, I use my torque wrench to do the final tightening to the torque specifications.
Wildthings
Wildthings is offline
PostPosted: Wed Apr 17, 2013 9:04 am    Post subject: Reply with quote
I like something like this:
http://www.ntxtools.com/network-tool-warehouse/ASM-S3049XL-8.html
BUSBOSS
BUSBOSS is offline
PostPosted: Wed Apr 17, 2013 9:31 pm    Post subject: Reply with quote
or use the standard size one with a socket extension.
All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible
(sold - but not forgotten)
airschooled
Air-Schooled
airschooled is offline
PostPosted: Wed Apr 17, 2013 10:01 pm    Post subject: Reply with quote
Some early bays came with 6mm 6-side (Allen) head bolts.
When ordering at NAPA, find the product on their website and give them the NAPA part number. They can order it in the morning and get it to you before closing time. Don't make the poor guys behind the counter actually look something up on their own!! Shocked
And there is absolutely nothing wrong with the EMPI one Wink
WTB: 215mm Type 4 flywheel. Cash in hand.
www.airschooled.com
Road trip reports and tech blog:
Wildthings
PostPosted: Thu Apr 18, 2013 12:40 am    Post subject: Reply with quote
The long thin tool clears the boot much better than a short squat one used with an extension. Wink
Wasted youth
PostPosted: Thu Apr 18, 2013 4:45 am    Post subject: Reply with quote
From last July when I learned about this problem:
My local Napa store had the correct tool, house brand. Tool 2304 Serrated Wrench, 8mm @$6.69 ea.
I picked up my bus and it had a mixture of both Allen sockets and those in question.
Tcash
Tcash is offline
PostPosted: Sun Jul 13, 2014 1:01 pm    Post subject: Reply with quote
How to Remove Stripped CV Bolt Head
