Roycebjr Samba Member
Joined: May 28, 2012 Posts: 28 Location: Fort Riley KS
Posted: Wed May 29, 2013 8:01 pm Post subject: Rear hub problem? |
| So while driving my 67 today I noticed as I backing out of my parking spot that There was a dragging sound coming from the right rear wheel and the car was moving like the wheel was egg shaped. When I drove forward it smoothed out and became quiet as I shifted into 2nd. when I got home I went to investigate and that's when I found out that the the axle nut was burning hot. Any Ideas? |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9757 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Thu May 30, 2013 5:47 am Post subject: |
Axle nut still have the cotter pin in it? If not, maybe it's loose and the wheel is on its way to falling off. Depending on how long it's been that way the splines on the axle and the mating surfaces in the hub may be worn from the movement. _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Thu May 30, 2013 7:11 am Post subject: |
I have an idea! Take the brake drum off and see whats wrong! _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Fri May 31, 2013 2:42 pm Post subject: |
well that is the problem. The axle nut is so rusted on that i broke a 1/2in drive ratchet, and I drained my air tank trying to free it up with my impact, despite my effort no movement. so I don't think it is loose.
Is the rear lubricated with grease like up front or is there something else because they are the drive wheels? I wonder if it has run dry. |
bonzai272 Samba Member
Joined: January 20, 2006 Posts: 240 Location: Houston, TX
Posted: Fri May 31, 2013 2:45 pm Post subject: |
Check this thread. You might want to buy the special tool to remove the axle nut. But yes, you should probably just remove the drum to have a look.
http://www.thesamba.com/vw/forum/viewtopic.php?t=556690 _________________ 1963 Beetle |
Posted: Fri May 31, 2013 3:07 pm Post subject: |
| thanks for the post! I will try to locate one of those tools, I hope it works I don't want to have to cut mine off like that guy did. |
OLDveedubs Samba Member
Posted: Fri May 31, 2013 5:13 pm Post subject: |
That guy should have spent his $100 on beer instead of that cheap chinese repop of a torque tool! The tool has it's place for other tasks, but be careful with 5 lug drums, its a couple mm too long making it skip the gears anytime you torque it up.
To drill it and cold chisel wasn't a big deal, just a pain. Take your time. Penetrating oil and heat may work, for me it didn't.
Trust me, once you get it off you'll want to yell really loudly with excitement.  _________________ -Ryan
Restoration Updates
www.my59bug.com
"Perfection through inspection." |
