jr_vw2 Samba Member
Joined: February 14, 2006 Posts: 182 Location: Chattanooga Tn
Posted: Sun Jul 12, 2020 3:53 pm Post subject: Who has their battery up front? |
So I have next to zero options for my battery location. Thinking maybe up front opposite the master cylinder. Who has a battery up there and what model battery fits? _________________ Jeremy
Chattanooga TN |
oprn Samba Member
Joined: November 13, 2016 Posts: 15120 Location: Western Canada
Posted: Mon Jul 13, 2020 3:57 am Post subject: Re: Who has their battery up front? |
| Good question, I may be faced with this too when I convert to IRS. |
WMAGRU Samba Member
Joined: March 02, 2013 Posts: 28 Location: St. George, Utah
Posted: Mon Jul 13, 2020 4:38 am Post subject: Re: Who has their battery up front? |
I use an Odyssey PC680 mounted directly behind the passenger seat. This battery can be mounted in any position except upside down.
jr_vw2 Samba Member
Posted: Mon Jul 13, 2020 5:36 am Post subject: Re: Who has their battery up front? |
| WMAGRU wrote: |
Those dimensions look perfect. My concern should be with only having 170 CCA and a battery cable that's 8 feet long.
Does that battery have any struggle cranking your buggy? _________________ Jeremy
Chattanooga TN |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20886 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Jul 13, 2020 6:15 am Post subject: Re: Who has their battery up front? |
| oprn wrote: |
My solution was to cut about 1.5 inches off bottom of battery box and glassed in new bottom...
At full droop IRS arms cleared battery box...
Putting battery up front creates a situation for excessive long positive battery cable, which ""may"" cause voltage drop,. which ""may"" cause starter cranking problems...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
WMAGRU Samba Member
Posted: Mon Jul 13, 2020 6:31 am Post subject: Re: Who has their battery up front? |
| PC680 is mounted behind the passenger seat so the battery cables are only about 26" long. No problem on cranking power. Fires right up every time. |
slalombuggy Samba Member
Posted: Mon Jul 13, 2020 9:07 am Post subject: Re: Who has their battery up front? |
Mine is over the beam but I don't have a gas tank up there.
I started my race car engine with a lawn tractor battery running through 10 feet of cable for both terminals. But I use #4 welding cable with soldered lugs. No problems even when hot.
brad |
jspbtown Samba Member
Posted: Mon Jul 13, 2020 12:30 pm Post subject: Re: Who has their battery up front? |
| The Speedster crowd has their batteries up front. Use the correct wiring and on all but the most radical engines you won't have an issue |
bim55 Samba Member
Joined: February 11, 2005 Posts: 438 Location: Dennis Port, MA
Posted: Mon Jul 13, 2020 5:31 pm Post subject: Re: Who has their battery up front? |
Here’s a pic of my current car with a battery cage I found on Summit.
_________________ Boston Bob E.
www.bimelliott.com www.deserterownersgroup.org |
Rockbound Samba Member
Joined: September 06, 2017 Posts: 304 Location: Pennsylvania
Posted: Thu Jul 16, 2020 7:34 am Post subject: Re: Who has their battery up front? |
i did mine up front but i also do not have a stock vw chassis
4 bolts under neath to lower it down to change it. welded nuts on top of frame rails |
oprn Samba Member
Posted: Thu Jul 16, 2020 10:47 am Post subject: Re: Who has their battery up front? |
| Clever! |
