cylinder head torque
mynameisnick
mynameisnick is offline
PostPosted: Fri Jun 07, 2013 4:56 pm    Post subject: cylinder head torque Reply with quote
Hello the samba,
I am rebuilding my engine and need to know the torque specs for the cylinder heads. They are 15mm bolts and all I can find is 10mm and 8mm.
Juanito84
Juanito84 is offline
PostPosted: Fri Jun 07, 2013 5:05 pm    Post subject: Reply with quote
10 and 8mm refers to the width of the threads, not the head of the nut where you put the socket. With the nuts off, measure the width of the head studs. They should be either 8 or 10mm. Or measure the threaded hole in the head nuts.
If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine?
Juanito84
PostPosted: Fri Jun 07, 2013 5:06 pm    Post subject: Reply with quote
johnnypan
johnnypan is offline
PostPosted: Fri Jun 07, 2013 5:06 pm    Post subject: Re: cylinder head torque Reply with quote
mynameisnick wrote:
Hello the samba,
15mm wrench size, stud diameter is either 10mm or 8mm..
mynameisnick
PostPosted: Fri Jun 07, 2013 5:08 pm    Post subject: Reply with quote
ok thanks guys
Tim Donahoe
Tim Donahoe is offline
PostPosted: Fri Jun 07, 2013 11:19 pm    Post subject: Reply with quote
And. Concerning torque specs:
Tighten in two steps.
First step 84 INCH pounds (which is only 7 foot pounds.
Then:
M10 nuts: 23 foot pounds.
M8 nuts 18 foot pounds.
Nick, you should get a Hayne's manual to show you the exact sequence to do this tightening. They are cheap and can be bought at most auto stores or VW on-line vendors.
Tim
ryohey
ryohey is offline
PostPosted: Sat Jun 08, 2013 5:08 am    Post subject: Reply with quote
This should help you out
http://www.vw-resource.com/heads.html#torque
69 bug restoration thread http://www.thesamba.com/vw/forum/viewtopic.php?t=387230&highlight=
peterwilks
peterwilks is offline
PostPosted: Sat Sep 16, 2017 1:22 am    Post subject: Re: cylinder head torque Reply with quote
Hi,
Am restoring a 1600 dual port. I don't know the year of the engine as it is not original to the car which is 1971. Am confused by the cylinder head stud size. I measured the diameters of the bolts and they ranged from 8.87 to 8.95mm. So are these 8mm or 10mm studs??. Need to know as this affects torque setting. The thread diameter on the bolts was larger at around 9.71mm so am guessing I have got 10mm studs and therefore torque to 23 ft pounds? The small bolt diameters (certainly not 10mm) however has me confused. Help please!!
thanks,
Peter W
N.Z
Multi69s
Multi69s is offline
PostPosted: Sat Sep 16, 2017 1:59 am    Post subject: Re: cylinder head torque Reply with quote
Maybe this chart can help you.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
Knusprige Flicken
Knusprige Flicken is offline
PostPosted: Sat Sep 16, 2017 6:24 am    Post subject: Re: cylinder head torque Reply with quote
peterwilks wrote:
Hi,
thanks,
Peter W
N.Z
It sounds like the studs have "rolled"threads, its a manufacturing process where they start with a blank rod that would be smaller than 10 mm (your 8.87 measurements) and a roller presses the threads into the rod, compressing the material and swelling the diameter of the threaded portion. It creates a stronger thread than by the traditional method of cutting the threads, and its alot faster/ more economical method of manufacter.
Or
The unthreaded portion has been relieved by cutting the material away for clearance issues
I'm betting on the rolled threads
It sounds like you have 10 mm studs
