CSR7644 Samba Member
Joined: July 09, 2007 Posts: 14 Location: columbus,ga.
Posted: Mon Jun 10, 2013 7:07 pm Post subject: Cargo door screw removal |
Can anyone suggest a good(easy)way to remove two stripped cargo door screws??  |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26385 Location: Olympia Wash Rinse & Repeat
Posted: Mon Jun 10, 2013 8:05 pm Post subject: |
Which screws? Interior panel, pop out, hinge, strap door stop, rubber bumper, etc..... _________________ In Stereo, Where Available! |
BulletBus Samba Member
Joined: August 17, 2005 Posts: 1276 Location: Panama City Beach
Posted: Tue Jun 11, 2013 6:01 am Post subject: |
No such thing as easy on this one. Start by using penetrating spray around the bolts and behind the hinge in the little open area. Then you have to step drill the bolts using small drill bits and stepping them up till you can get an easy out (usually nothing easy about them) in there. Give the bolt some heat with a torch and a couple good whacks using a screwdriver on the center of the screw. Lots of patience. Good luck. _________________ 53 Hatch Barndoor
If it's not a bus, it's bus money waiting to happen. |
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3081 Location: The Bull City
Posted: Tue Jun 11, 2013 6:42 am Post subject: |
| Welding a nut to the head of the screw works a lot of times too |
Mitch Case Samba Member
Posted: Thu Jun 13, 2013 6:42 pm Post subject: |
Skip the easy out!! All too easy to break it off in there and it is hardened so it will not be drillable........ _________________ In Stereo, Where Available! |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15508 Location: Casa de Oro, California
Posted: Thu Jun 13, 2013 7:07 pm Post subject: |
| There's a video of how that guy did his in The Funky Truck thread. Maybe someone can link it. |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5009 Location: Richmond, Verjinya
Posted: Thu Jun 13, 2013 7:14 pm Post subject: |
drill and retap it _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10267 Location: Petaluma, CA
Posted: Thu Jun 13, 2013 7:24 pm Post subject: |
Get one of these for your air chisel - then add a phillips impact driver bit.
I have removed screws that that no longer looked like phillips heads before.
I would only use this to knock it loose, once it's loose then try threading it out normally. |
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
MrBusCo Samba Member
Joined: February 13, 2007 Posts: 1576 Location: stoughton, WI
Posted: Thu Jun 13, 2013 8:33 pm Post subject: |
X2 on this tool. I have the longer version and it works great. _________________ Josh The Bus Guy formerly known as JOGR
BlazeCutUSA.com MrBusCo.com |
vwserphguy Samba Member
Joined: April 30, 2009 Posts: 176 Location: Vail Valley
Posted: Thu Jun 13, 2013 9:55 pm Post subject: |
| glideking wrote: |
There ya go.
Great video (and some funny moments) on how to remove frozen screws with your welder. _________________ "Relax and just enjoy the ride knowing everybody passing is wishing they had one." |
Posted: Fri Jun 14, 2013 6:20 am Post subject: |
At least we know that Gary Bussey's brother is doing well.  _________________ 53 Hatch Barndoor
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Fri Jun 14, 2013 8:27 am Post subject: |
| Mitch Case wrote: |
| You can also try to drill the center out just smaller than the threads and and use an easy out to try to back the remaining screw out. Heat is allways good |
I second this.
I removed several frozen gate hinge screws from my SC this way.
Drilled out the screw slightly smaller than thread size. The stripped Phillips centres the bit nicely.
Then heat it up real good with a micro torch aimed in the drilled hole and the Easy Out should turn it out effortlessly.
This method spares the original paint around the screw head.
Always got to be careful with an Easy Out and I would not attempt the Easy Out without heat.
Like E&B said, they are a bitch to try to drill out.
Welding a nut on the head works well too, as the heat breaks the corrosion bond, but it is harder on the surrounding paint. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
