hippiepilot Samba Member
Joined: June 18, 2008 Posts: 455 Location: Sarasota, FL
Posted: Sun Jul 07, 2013 2:18 pm Post subject: A/C evaporator question |
I have a 91 Carat with factory installed A/C or dealer installed, as to not start the argument about the factory never installed A/C's, and had a couple of questions. Is the evaporator suppose to be mounted to roof with the evaporator housing clam shelled around it? Is the water drain tray attached to the evap housing.
Reasons for asking, I had the high low pressure switch replaced and when I got the van back there was a large crack on the bottom of the evap housing underneath the driver's side speaker. Once the van started cooling down it was obvious that the water drain tray was not catching the condensation and was now dripping down threw the crack.
The passenger side is draining properly.
I decided to investigate further and remove the evap housing and take a look and I'm glad I had that thing supported because it came down like a ton of bricks and the evaporator was not attached to the ceiling. I also notice the the driver's side drain tube went through some sort of housing up to the water drain tray which seemed to be attached the to evap housing. This was all done by feel because I couldn't figure out how to get the dang thing down by myself and I need my a/c working on my daily driver.
Any ideas on how to not make my van the Maid of the Mist attaction? _________________ 83 air-cooled Westy
91 Carat (daily driver)
http://www.changeisland.com |
denwood Samba Member
Joined: July 29, 2012 Posts: 1047 Location: Thunder Bay, Ontario, Canada
Posted: Sun Jul 07, 2013 6:53 pm Post subject: |
Normally the tray floats below, and the evaporator should be held up by two brackets that the rear evap screen also bolts to. You may want to look at a few of my posts on the redtek DIY thread, last few pages for a mod to attach the tray to the evaporator, and route channels in the wood work so the tray and lines can go in before the evap housing. _________________ Cheers,
Dennis Wood
The Grape |
Posted: Mon Jul 08, 2013 9:02 am Post subject: |
Thanks for reply will search for thread. I will follow up, I'm wondering if its a after market replacement evap. _________________ 83 air-cooled Westy
Posted: Mon Jul 08, 2013 11:40 am Post subject: |
On the factory evap unit you have four bolts holding it up. This picture from Hansh shows one side. The two larger holes (empty) at the extreme right on this photo indicate a large washer/bolt assembly that goes to nut inserts in the ceiling. Four in total. If someone has drilled out the rivets holding this bracket to evaporator...then it would just fall out. Either way, the evaporator housing wood bits are not constructed adequately to safely restrain the evaporator IMHO. Corners are just stapled/glued and mine had to be reinforced.
Dennis Wood
The Grape |
Posted: Thu Jul 11, 2013 7:52 pm Post subject: |
The evaporator does not attach to the roof. It is mounted to the clam shell.
At this point it doesn't matter. I have no AC and I live in Florida and I'm hosed until I figure this out.
Broken water tray drain tube PO fix but now is the root of my problem along with other stuff. _________________ 83 air-cooled Westy
Posted: Thu Jul 11, 2013 8:05 pm Post subject: |
apologies...missed the fact that you were driving a carat...westy setup is different. _________________ Cheers,
Dennis Wood
The Grape |
Posted: Fri Jul 12, 2013 12:22 pm Post subject: |
Oh no worries just venting out frustrations. It's the Bentley's fault page 87.9 at bottom says from 1986 and pg 87.12 at bottom says from 1986 as well but doesn't specify it if is a camper or tin top. I have decided to get some gauges after work and put another belt back on and check before I take it in. Problem is now I have to search and see what a normal reading would be on the dials. Heck I've had to learn every other system on these vans might as well add A/C to list.
Thanks again _________________ 83 air-cooled Westy
dhaavers Samba Member
Joined: March 19, 2010 Posts: 6940 Location: NE MN (http://g.co/maps/zt72q)
Posted: Mon Jul 15, 2013 9:33 am Post subject: |
Thanks for pdf link! _________________ 83 air-cooled Westy
vanis13 Samba Member
Posted: Wed Jul 17, 2013 5:57 am Post subject: |
hippiepilot wrote: |
Thanks for pdf link! |
Ditto! _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace |
Posted: Wed Jul 17, 2013 7:18 pm Post subject: |
So here's what I did to fix the evap water drain tray and evap housing. Although I'm sure it's been posted before, but what the hay.
Before pics
After pics. I basically used a soldering iron to melt the broken pieces/ cracks back together and then used JB plastic weld to re-enforce it and now when I run the A/C the condensation actually runs down the pillars.
Posted: Wed Jul 17, 2013 8:06 pm Post subject: |
^^^ DRIP-BUSTERS!!!
Nice work! _________________ 86 White Westy Weekender
"The WonderVan"
