Help needed...Bus starts but won't idle
minimember
minimember is offline
PostPosted: Wed Aug 07, 2013 5:04 pm    Post subject: Help needed...Bus starts but won't idle Reply with quote
My bus was driving fine up until yesterday when it stalled getting off of the freeway, ever since then she won't idle on her own. I have a 1970 1600DP with solex 34 pict/3
Things that I have already checked:
-Point gap is correct
-automatic choke is getting power from coil and functioning properly
-no apparent vacuum leak at the intake manifold (spayed with starter fluid) and I don't have vacuum assist booster brakes
-My electromagnetic idle cutoff clicks when given power
-I changed the fuel filter just to be on the safe side
-I tried cover the top of my carb at a high RPM to try and force any clogged debris there may have been in one of the jets, but to no avail
The bus seems to drive fine other then at idle, is it safe to assume that I've got a clogged jet? I've never had to take my carb apart and wanted to make sure that I had exhausted all other options, and ask for some tips if it does indeed seem to be the next logical step...
Thanks in advance
(oh and I do have a Bentley service manual)
busdaddy
busdaddy is offline
PostPosted: Wed Aug 07, 2013 5:12 pm    Post subject: Reply with quote
I'd dismantle the carb and clean it.
Слава Україні!
minimember
PostPosted: Wed Aug 07, 2013 6:32 pm    Post subject: Reply with quote
Do I need to dismantle the whole thing or am I only looking to clean the idle and perhaps the main jets? should I pick up that carb bath stuff i've seen at the auto parts stores?
Harleyelf
Harleyelf is offline
PostPosted: Wed Aug 07, 2013 7:28 pm    Post subject: Reply with quote
Start with the idle jet and whatever vacuum caps you might have.
Desertbusman
Desertbusman is offline
PostPosted: Wed Aug 07, 2013 8:00 pm    Post subject: Reply with quote
Buy a rebuild kit. Then follow the complete excellent detailed instructions in your service manual. That's what it's for.
The other option is just muddle through it and keep saying "maybe". Wink
71 Superbug
71 Westy
busdaddy
busdaddy is offline
PostPosted: Wed Aug 07, 2013 8:20 pm    Post subject: Reply with quote
I agree, do the whole thing or the next piece of loose shit floating around in there will be back in one of the idle jets next week or maybe next month and likely in heavy traffic or the middle of a big bridge during rush hour, it's a good idea to flush a quart of gas into a soda bottle using the starter before reinstalling that spiffy new carb too incase there's more crap lurking in the lines.
Слава Україні!
GeorgeO.
GeorgeO. is offline
PostPosted: Wed Aug 07, 2013 8:22 pm    Post subject: Reply with quote
Cracked Rotor? If you have an aftermarket rotor, it can be the cause.
minimember
PostPosted: Wed Aug 07, 2013 8:37 pm    Post subject: Reply with quote
It ended up just being a bit of debris in the idler jet...thanks your guys for all of your help!
minimember
PostPosted: Wed Aug 07, 2013 8:38 pm    Post subject: Reply with quote
oh and by the way, I just ordered the rebuild kit.
Thanks Again!
