Darkhorse Samba Member
Posted: Sat May 31, 2025 3:04 pm Post subject: Wiring question |
So I’m stuck and looking for some help I just installed a new wiring kit for my buggy. I’m getting power at the key to turn the starter but the wire that runs from the starter to the voltage regulator also has power. The line running out from the voltage regulator is hot but the end of wire has no power. I thought I might have a bad wire but I tested with a new wire and same issue. Any thoughts or thing to check? _________________ 1962 OG PEARL WHITE RAG TOP BUG |
slayer61 Samba Member
Posted: Sat May 31, 2025 5:04 pm Post subject: Re: Wiring question |
I don't have a wire from the key switch to the voltage regulator. I have one that goes to the starter though. What wiring diagram did you use? FWIW, I have a 68 with a 2 wire alternator. _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes?  |
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
MSD Box and distributor
1 5/8 merged collector w/ hater stinger |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20805 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat May 31, 2025 6:28 pm Post subject: Re: Wiring question |
Darkhorse wrote: |
So I’m stuck and looking for some help I just installed a new wiring kit for my buggy. I’m getting power at the key to turn the starter but the wire that runs from the starter to the voltage regulator also has power. The line running out from the voltage regulator is hot but the end of wire has no power. I thought I might have a bad wire but I tested with a new wire and same issue. Any thoughts or thing to check? |
That makes no sense IF you have 12 volt at one end and all the wire and terminals are good, I don't see how it can happen..... What is the "dead" end of wire connected to? _________________ “Fear The Government That Wants To Take Your Guns"
