DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6249 Location: SBS headquarters: Missery
Posted: Thu Aug 29, 2013 5:21 am Post subject: Bench Seat bracket measurement |
When I got my DC it had 1 & 2/3rd seats in it. Of course this isn't correct! I found a bench seat, but the PO(s) cut the back support brackets out. DOH! Yes I did a search, but didn't find one with what I'm looking for.
I need the following measurements so I can fab some up.
A.
B.
C.
D.
E. which is the top width
It's the bracket seen in this picture.
_________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
blink Samba Member
Joined: September 07, 2011 Posts: 91 Location: Australia
Posted: Thu Aug 29, 2013 6:35 am Post subject: |
This would be awesome if anyone can help out im looking for the same thing.
Also if anyone can help with the measurement of how far the seat bracket is from the divider too please.
Thanks matt
Ps sorry to hijack the thread |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Thu Aug 29, 2013 7:29 am Post subject: |
A= 4 5/8"
B= 6 1/2"
C= 4 9/16"
D= 1/2"
E=1 1/2"
Angle of repose = ~67 degrees
The bracket is one piece, bent into a C shape initially, then cuts made in the vertical faces so it can be bent at 67 degrees. Although the top is 1 1/2" across and the sides are 1/2", cut the piece wider than 2 1/2" as there will be some material taken up in the bend.
The vertical edges then overlap each other at the 67 degree bend and one spot weld holds them in place.
Make the bracket about 2" longer than needed as both ends needs extra length to be welded to the bulkhead and dogleg respectively.
matt, not sure what you mean by how far the seat bracket is from divider?
Which bracket and what divider? _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
blink Samba Member
Posted: Thu Aug 29, 2013 4:24 pm Post subject: |
Sorry
I was talking about the bottom seat bracket or locater where the seat is secured.
And i was looking to find out how far from the the edge of that to the cabin divider. if that makes sense.
Thanks Matt |
Posted: Fri Aug 30, 2013 3:00 am Post subject: |
| Riff Raff wrote: |
| The bracket is one piece... |
Thanks brother! _________________ Anthony
SBS #1
SBS #1 on FB
NestaVaughn Samba Member
Joined: September 09, 2020 Posts: 3 Location: Mesa, AZ
Posted: Mon Mar 27, 2023 8:14 pm Post subject: Re: Bench Seat bracket measurement |
Hello, first post so if I goof up I'm sorry... Is someone able to post a reference picture to clarify the measurements for the info in this topic? The picture the letters refer to appears to be nla, and I am unsure which letters mean what... Thanks.
My front bench seat bottom seems to be either too thick or those brackets were fabbed up incorrectly before I got the bus, they are so close to the bottom seat that I can not pivot the bottom bench seat up to access the toolbox. It's so tight in-fact, than in order to even remove the bottom bench seat, I had to compress the seat springs substantially to have enough clearance to not break the little seat holding tabs off their spot welds... Seems too tight to me, I assume VW designed it with more clearance than that.
I have a 4/59 Single Cab for reference, with what I think is a repop seat frame (Which could also be the problem?) The bottom seat has a horsehair pad, top does not. Also there are little rubber nipples on the brackets in question, not sure if those should be there or not either _________________ 04/59 Single Cab |
