Type 2 77 camper brake servo and master cylinder
Royce123
Royce123 is offline
PostPosted: Tue Mar 08, 2022 6:39 pm    Post subject: Type 2 77 camper brake servo and master cylinder Reply with quote
What tool is used to adjust brake servo push rod to master cylinder piston for a 1 mm clearance? What sizes are the two ports used to loosen and to shorten or lengthen the pushrod?
busdaddy
busdaddy is offline
PostPosted: Tue Mar 08, 2022 6:52 pm    Post subject: Re: Type 2 77 camper brake servo and master cylinder Reply with quote
No tools required, except for wrenches to get the MC off, you may need pliers to pull the tip out of the pushrod. The clearance is adjusted by adding or removing washers under the tip.
Слава Україні!
SGKent Premium Member
SGKent is offline
PostPosted: Wed Mar 09, 2022 4:51 pm    Post subject: Re: Type 2 77 camper brake servo and master cylinder Reply with quote
I think that on the 1977 the free play might be adjusted via the rod in the front, assuming it is a stock master and booster.
kreemoweet
kreemoweet is offline
PostPosted: Thu Mar 10, 2022 8:40 am    Post subject: Re: Type 2 77 camper brake servo and master cylinder Reply with quote
One of the popular aftermarket servos has a threaded tip which is
held in place by a circular knurled locknut.
The ATE (stock) servos have tips with a shank which is pushed into
the hollow end of the push rod. There may or may not be washers
under the tip, and if not there would be no way to shorten the push
rod without further machining, or by improvising a substitute tip.
'67 bug: seized by the authorities
SGKent is offline
PostPosted: Thu Mar 10, 2022 9:22 am    Post subject: Re: Type 2 77 camper brake servo and master cylinder Reply with quote
It never would occur to me to look in the service manual.
http://kentcomputer.com/samba/adjustmaster.pdf
kreemoweet
PostPosted: Thu Mar 10, 2022 10:26 am    Post subject: Re: Type 2 77 camper brake servo and master cylinder Reply with quote
There's nothing relevant in the service manual on the subject. All it says it's
factory-set to the correct length, which we should by now all know is a falsehood.
ToolBox
ToolBox is offline
PostPosted: Thu Mar 10, 2022 10:33 am    Post subject: Re: Type 2 77 camper brake servo and master cylinder Reply with quote
Except we all know there are many parts that have tolerence issues these days.
SGKent is offline
PostPosted: Thu Mar 10, 2022 1:54 pm    Post subject: Re: Type 2 77 camper brake servo and master cylinder Reply with quote
Funny I would swear in the section to adjust the master cylinder pushrod it says in BOLD, "To adjust clearance on vehicle with brake servo"
I guess my English must be bad.
kreemoweet
PostPosted: Thu Mar 10, 2022 2:08 pm    Post subject: Re: Type 2 77 camper brake servo and master cylinder Reply with quote
That section pertains to the joint between the brake pedal linkage, and booster connecting rod,
not the internal booster push rod that interfaces with the master cylinder. It goes on to state that
the latter cannot be changed, which is nonsense.
SGKent is offline
PostPosted: Thu Mar 10, 2022 5:22 pm    Post subject: Re: Type 2 77 camper brake servo and master cylinder Reply with quote
read it again. It refers to the internal pushrod, and why you can't adjust that part on a late bay. You adjust it with the pedal linkage. On a late bay the length of that rod is set, it is not adjustable like an early bay with no servo. Instead you adjust the pedal linkage so that the inside of the eervo is not up against the pushrod.
kreemoweet
PostPosted: Thu Mar 10, 2022 6:26 pm    Post subject: Re: Type 2 77 camper brake servo and master cylinder Reply with quote
SGKent wrote:
... read it again ...
Don't need to read nuthin', I have actual hands-on experience with the parts and the situation being discussed.
It's clear that you have no concept of same. Maybe someday you will have the 'pleasure' of dealing with a
not-right internal booster push rod, and the light will turn on for you. There's quite a few posts here on the Bay
Bus forum that deal with this problem at length, that could prove useful.
busdaddy
busdaddy is offline
PostPosted: Thu Mar 10, 2022 6:36 pm    Post subject: Re: Type 2 77 camper brake servo and master cylinder Reply with quote
SGKent wrote:
........On a late bay the length of that rod is set, it is not adjustable like an early bay with no servo.
It is adjustable, back when all parts came from VW it didn't matter since they all fit so the books don't mention it, lately some new masters stick into the booster a little too much and cause the brakes to stay on if you don't shorten the rod.
No amount of fiddling with the front pedal to booster rod makes a difference, the issue is internal. If you can't take out a washer, or twist the screw in tip (if equipped) the next option is to make thick shim gaskets to go between the M/C and booster, or grind the end of the rod.
Слава Україні!
SGKent is offline
PostPosted: Thu Mar 10, 2022 6:41 pm    Post subject: Re: Type 2 77 camper brake servo and master cylinder Reply with quote
Are you saying that the ATE 211611021AA for $350 or so doesn't fit the late servo buses? I replaced the master, paid to get the good ATE one and had no issues. Are others having issue with those, or the cheaper made ones? They look different in the photos.
