Space saver tire size?
detoxed
detoxed is offline
PostPosted: Fri Nov 25, 2016 1:11 pm    Post subject: Space saver tire size? Reply with quote
Upgraded to 15" wheels/ tires and need a spare for future travels; had no spare when I bought the "ZenBox" so I'm considering using a "donut" space saver to easily fit in the clamshell, lighter wt(?) than the rim and tire combo being used. I've searched/ googled with no answers. My overall tire diameter is 27". Anyone have any suggestions? Thanks
Type17
Type17 is offline
PostPosted: Fri Nov 25, 2016 1:55 pm    Post subject: Re: Space saver tire size? Reply with quote
A 27" tire will fit with a little work. Get a full size spare.
I don't check these forums daily and often loose track of threads and comments. Please PM me a reminder if you're waiting on a reply. Thanks!
danfromsyr
danfromsyr is offline
PostPosted: Fri Nov 25, 2016 2:14 pm    Post subject: Re: Space saver tire size? Reply with quote
it's forever educating people that rim diam has nothing to do with outer tire diameter. 14in 15in and even 16in rims fit w/o modification.
unless you have upgraded your brakes to larger brakes. a stock 14in rim will suffice as a spare. make sure you have ALL the hardware (lug bolts & NUts) to suit the spare steel rim.
Abscate wrote:
