ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Thu Sep 12, 2013 12:58 pm Post subject: Bosch ZV/JCU 4R3 oddity |
I bought two NOS Bosch ZV/JCU 4R3 distributors, and when they arrived, one has what appears to be an old 36 horse vac can. Anyone ever see this in the past?
I posted a WTB ad for a replacement can a while back...so far, no one seems to have one (or is willing to part with one).
I'm curious as to why this might have been installed...
Glenn Mr. 010
Joined: December 25, 2001 Posts: 77039 Location: Sneaking up behind you
Posted: Thu Sep 12, 2013 1:14 pm Post subject: |
That is a 36hp vacuum canister. It must of been replaced at sometime. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Posted: Thu Sep 12, 2013 1:19 pm Post subject: |
Thanks for the reply...any idea why the 36 hp can would have been installed vs. an original can? |
Glenn Mr. 010
Posted: Thu Sep 12, 2013 1:25 pm Post subject: |
ataraxia wrote: |
No idea. It could be it got damaged between first assembled and later and was replaced. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Warren G. Samba Member
Joined: September 21, 2012 Posts: 19 Location: Torrance
Posted: Wed Apr 17, 2024 9:19 am Post subject: Re: Bosch ZV/JCU 4R3 oddity |
I have one too...
Glenn Mr. 010
Posted: Wed Apr 17, 2024 9:21 am Post subject: Re: Bosch ZV/JCU 4R3 oddity |
Warren G. wrote: |
I have one too... |
You have the correct vacuum can. _________________ Glenn
Member #1009
#BlueSquare
notchboy Samba Member
Joined: April 27, 2002 Posts: 22479 Location: Escondido CA
Posted: Wed Apr 17, 2024 3:31 pm Post subject: Re: Bosch ZV/JCU 4R3 oddity |
Why are you assuming it was put on from new. It wasn't. Someone took the can off and put that one on. Typical "NOS" parts that are sold n now a days. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Glenn Mr. 010
Posted: Wed Apr 17, 2024 3:33 pm Post subject: Re: Bosch ZV/JCU 4R3 oddity |
notchboy wrote: |
Why are you assuming it was put on from new. It wasn't. Someone took the can off and put that one on. Typical "NOS" parts that are sold n now a days. |
Are you asking the OP?
They started this topic 11 years ago. _________________ Glenn
Member #1009
#BlueSquare
Posted: Wed Apr 17, 2024 3:41 pm Post subject: Re: Bosch ZV/JCU 4R3 oddity |
Glenn wrote: |
notchboy wrote: |
They started this topic 11 years ago. |
Shut up Glen. Im tired.
t3kg wrote: |
1964 1500 S
Glenn Mr. 010
Posted: Wed Apr 17, 2024 3:58 pm Post subject: Re: Bosch ZV/JCU 4R3 oddity |
notchboy wrote: |
Glenn wrote: |
notchboy wrote: |
Easy there, being the cranky old man is my job.
Member #1009
#BlueSquare
oldslow Samba Member
Posted: Fri Apr 19, 2024 6:29 pm Post subject: Re: Bosch ZV/JCU 4R3 oddity |
So the question for the experts, will fitting the common 36hp vacuum can allow the ZV/JCU 4R3 to function properly? Like, pretty darn close, or no way no how. _________________ - better to drive a slow car fast than fast car slow - |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6656 Location: Houston, Texas
Posted: Fri Apr 19, 2024 7:42 pm Post subject: Re: Bosch ZV/JCU 4R3 oddity |
oldslow wrote: |
So the question for the experts, will fitting the common 36hp vacuum can allow the ZV/JCU 4R3 to function properly? Like, pretty darn close, or no way no how. |
It's close enough to make it work. As with anything if you are doing something that isn't stock you will want to listen to the engine carefully. _________________ www.vwnos.com [email protected]
Posted: Fri Apr 19, 2024 7:44 pm Post subject: Re: Bosch ZV/JCU 4R3 oddity |
oldslow wrote: |
No, and I think no one knows. Get the proper can. To me having that dizzy AND having the proper can makes it what it is. If you don't care then run an OOOh 9. 😘 Doo what you gotta doo. But Im in the camp of "talk some shit" when I see you went the extra mile to have the right dizzy then said "hey, fuck it" _________________
t3kg wrote: |
1964 1500 S
heimlich VWNOS.com
Posted: Fri Apr 19, 2024 7:53 pm Post subject: Re: Bosch ZV/JCU 4R3 oddity |
I had this conversation with a customer. The end result was that we were going to try it but we didn't. I have a few documents that describe both the VJU4BR8 and also the ZV/JCU 4R3. The details on the two documents tell me that it should work and that everything will be fine.
I have these little nipples that screw into the type 1 cans. This allows you to put a hose on them just as you would with the stock can. _________________ www.vwnos.com [email protected]
Posted: Fri Apr 19, 2024 8:00 pm Post subject: Re: Bosch ZV/JCU 4R3 oddity |
heimlich wrote: |
I have these little nipples that screw into the type 1 cans. This allows you to put a hose on them just as you would with the stock can. |
If the proper cans were not available, Id say sure, go ahead and have a bastard mix. The OEM can is adjustable. Unless you know the adjustments for both, I wouldn't recommend it. There is no reason why you shouldn't take that extra step to make the 4R3 run as its supposed to. Sorry heimlich but a BR8 can is a hack to me at this point in parts finding history.
If not then just run a easier dizzy. There are plenty. _________________
t3kg wrote: |
1964 1500 S
heimlich VWNOS.com
Posted: Fri Apr 19, 2024 8:03 pm Post subject: Re: Bosch ZV/JCU 4R3 oddity |
notchboy wrote: |
Sorry heimlich but a BR8 can is a hack to me at this point in parts finding history. |
He asked if you could. Take it up with the person who asked the question. _________________ www.vwnos.com [email protected]
Posted: Fri Apr 19, 2024 8:05 pm Post subject: Re: Bosch ZV/JCU 4R3 oddity |
1964 Type 34 Ghia Convertible Engine. Has the 83mm domed pistons but with a 74mm counter weighted crank. Dual port heads - making me a Super 1600 VW style. What distributor do I have? A stock 1964 Only 4R3 distributor WITH Crack pipes.
t3kg wrote: |
1964 1500 S
Posted: Fri Apr 19, 2024 8:08 pm Post subject: Re: Bosch ZV/JCU 4R3 oddity |
heimlich wrote: |
notchboy wrote: |
He asked if you could. Take it up with the person who asked the question. |
Just a point of view brother. Should shouldn't mean could if you know better. You can lead a horse to water..... Just my 2 cents. _________________
t3kg wrote: |
1964 1500 S
Glenn Mr. 010
Just because you can, doesn't mean you should. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
