Full Flow Oil System Pressure?
salvatoremarino64
salvatoremarino64 is offline
PostPosted: Mon Sep 23, 2013 6:12 am    Post subject: Full Flow Oil System Pressure? Reply with quote
I have a full flow system on a 1835. Prior to that I had 45 to 50 psi. Now i have 25 psi cold to warm and about 15 hot.
Why the major drop in pressure??
OLD VW NUT
OLD VW NUT is offline
PostPosted: Mon Sep 23, 2013 8:36 am    Post subject: Reply with quote
Prior to what? If you did nothing more than add full flow filtering to an existing motor there will be some drop in oil pressure - it takes work to push oil thru the lines and filter then into the motor. Sounds like you should have added a larger oil pump while the motor was out and on the ground. A stock 21mm pump is barely adequate to push oil through a filter and lines added on for full flow oiling.
71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI
salvatoremarino64
PostPosted: Mon Sep 23, 2013 9:22 am    Post subject: Reply with quote
Prior to installing the full flow.
It does have a larger pump but im not sure what size. I go know that the pump housing is much thicker than stock.
ashman40
ashman40 is offline
PostPosted: Mon Sep 23, 2013 9:44 am    Post subject: Reply with quote
The easiest thing to check is the pressure relief valve next to the pump. Use a large screwdriver to remove. Make sure it can move freely all the way in until it seats. If it is stuck part way open, you will loose oil pressure.
AshMan40
salvatoremarino64
PostPosted: Mon Sep 23, 2013 10:35 am    Post subject: Reply with quote
I am using a Bugpack Oil return adapter that goes in where the pressure relief valve was.
Should I leave it all in?
ashman40
ashman40 is offline
PostPosted: Mon Sep 23, 2013 11:11 pm    Post subject: Reply with quote
Did you full flow the case? What I mean is, did you install a galley plug in the case where the output of the oil pump would normally flow oil into the case? This is to prevent oil from flowing from the return fitting back to the pump outlet. Without a plug here it is possible for oil to leak between the case and pump and drain back to the sump. Some will tell you this is not necessary as long as the fitment of the pump to case is snug. This is true.
I've not used the adapter you're referring to. I do understand it replaces the first pressure relief valve. I suppose if the upper orifice that the long tube fits through is not a snug fit to the tube oil will leak past and drain back to the sump. This would lower your oil pressure. You will need to find someone who has run one of these to see if they noticed the same thing as you. Maybe it is normal to see slightly lost pressures when using this adapter?
AshMan40
salvatoremarino64
PostPosted: Tue Sep 24, 2013 6:16 am    Post subject: Reply with quote
Yes.... I think. I pulled the pump out, put a plug in opposite the oil pick up into the pump. The pump was real tight to get in and out but it was not horrible.
You say it replaces the first pressure valve?? [u]
I did not install any valves or springs when I screwed the adapter in.
Should I have put something back in?
ashman40
ashman40 is offline
PostPosted: Tue Sep 24, 2013 6:50 am    Post subject: Reply with quote
Boy I hope you mean you plugged the outlet side of the oil pump?
See the pics here on how to full flow your case. The first three pics of the oil pump shows how to plug the outlet of the pump.
http://www.huelsmann.us/bugman/FilterTech.html
The next two pics show how to plug the case oil galley. The oil pump plug and the case galley plug would be back to back. This prevents oil from leaving the pump and prevents oil from leaking back from the full flow return into the gap between the case and the pump. In your case, the return is the adapter inserted into the oil relief passage neat the crank pulley.
Your case should have had two oil relief valves like in this pic, right?
You removed the three pieces of the oil pressure relief valve near the pulley... and replaced them with this adapter, right?
So, as I said, you removed the first (nearest the oil pump) pressure relief valve and installed the adapter in its place, right?
And then you installed the (second) oil pressure control valve on the flywheel side of the engine, right? This maintains the oil pressure. You should check that this valve is not stuck partially open. This would cause low pressure as well.
FYI, that adapter is only meant to be used with the later dual-relief cases like the pic above. If you happened to install it in an earlier single relief case... that would be a mistake. You would have no oil pressure control.
I doubt that is the case with your engine... you would have insane oil pressure when the oil was cold (like 200psi !) Shocked
AshMan40
salvatoremarino64
PostPosted: Tue Sep 24, 2013 8:16 am    Post subject: Reply with quote
Yes... When I pulled the pump out it was already tapped so I just put a plug in it as shown.
Oil pressure valve #1 had The screw on cap, 1 long spring, a valve, a smaller spring, and another valve.
Oil pressure relief valve # 2 is there but I did nothing with it.
I guess my next step is to unscrew #2 and see whats inside. What would you recommend putting in there?? I have no problem buying a new valve assembly, I just need to know what to look for in springs and valves. Or better yet what manufacturer?
BTW.... I appreciate all you help on this.
salvatoremarino64
PostPosted: Tue Sep 24, 2013 5:03 pm    Post subject: Reply with quote
Well... I went to remove the cover on the other relief valve and I had no luck removing it.
I did talk to someone about the front one and it should only be 1 spring and 1 valve in each.
Stumped on removing it. Don't wanna take it in but my have no choice.
OLD VW NUT
PostPosted: Tue Sep 24, 2013 5:11 pm    Post subject: Reply with quote
Here's a pic of the standard way of installing full flow oiling.
Is your's different?
johnnypan
johnnypan is offline
PostPosted: Tue Sep 24, 2013 5:29 pm    Post subject: Reply with quote
That's the right way to full flow...I plug the pump and the case to completely eliminate any loss of pressure at the pump bore.
Multi69s
Multi69s is offline
PostPosted: Tue Sep 24, 2013 10:27 pm    Post subject: Reply with quote
Lets take a step back, before checking relief valves and other things. The first thing that I would check is the gasket between the oil pump and its cover. There are two almost identical gasket that are used when installing an oil pump. One between the case and the pump body, and the one between the pump body and the cover. If you mix up these two gaskets, you will not have good oil pressure. The critical gasket is the one between the pump body and the cover. This gasket is so thin, that if you blew your nose with it, it would tear. If you put the thick gasket there instead, the oil will actually bleed off from the pump, and your oil pressure will be VERY low. I would check that first.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
salvatoremarino64
PostPosted: Wed Sep 25, 2013 5:55 am    Post subject: Reply with quote
Mr. Nut........ For the most part its the same. If you look at prior post, Ashman posted a pic of the return.
salvatoremarino64
PostPosted: Wed Sep 25, 2013 5:58 am    Post subject: Reply with quote
Multi69's..... Hard to mix the two of them up when only one fits over the pump snout between block and pump.
Thanks for your input. All is appreciated.
ashman40
ashman40 is offline
PostPosted: Wed Sep 25, 2013 8:35 am    Post subject: Reply with quote
That doesn't sound right. Do you have a pic?
All you want to do is inspect that valve is not scored. That it moves freely. If you have to replace it, find an original VW replacement, even if you have to pay a bit more.
To remove the slotted cover there are two approaches that work:
    1)Big a$$ screwdriver with square shaft. Put proper sized wrench on the shaft to give you leverage. While you press the screwdriver into the slot with all your might rotate the wrench ccw to loosen the cover. It wouldn't hurt to give the cover a solid tap using the screwdriver and a hammer. Not so hard do as to crack the case, but enough to loosen any rust. Heating with a torch could help too.
    2) Using screwdriver like a chisel, tap the cover in a ccw direction by placing the screwdriver tip in the slot on one side. This works well as the impacts loosen the cover. Just be careful not to chew up the slot.
Soaking the cover in penetrating oil also helps.
AshMan40
salvatoremarino64
PostPosted: Wed Sep 25, 2013 9:41 am    Post subject: Reply with quote
I don't have a pic at the moment but I can post one of what came out ov pressure valve 1.
Im looking into a large 1/2" impact screwdriver bit. If I can not find one... I have stuff to make one.
BTW.... Thanks for all your help!!
salvatoremarino64
PostPosted: Thu Sep 26, 2013 5:11 am    Post subject: Reply with quote
WOO HOO!!!! Great news!!
I was able to remove the spring and valve from the (flywheel) side. The spring was soft and short.
New spring from Empi is much longer and stiffer.
@ Idle 30 psi
@3000 rpm 50 psi
@4500 rpm on up 70 psi.
I would like to thank all of you for your advice. This inspires me to wanna build a larger engine.
salvatoremarino64
PostPosted: Thu Sep 26, 2013 6:09 am    Post subject: Reply with quote
Maybe I spoke too soon.... Sad
Drove it into work this morning. Oil pressure started out great. I know its cold and oil is thick. As it warmed up, pressure dropped slowly. By the time I got to work ( about a 20 min. drive) pressure was @ 25 on freeway and about 5-10 at Idle.
