Slider door hinge trouble.
NomadCamper
NomadCamper is offline
PostPosted: Mon Aug 07, 2017 7:42 pm    Post subject: Slider door hinge trouble. Reply with quote
Hi Gang! I am having slider door hinge issues for my 1971 camper Bay.
My bearings fell out while closing and I have ordered a replacement hinge from www2.cip1.com $129
All seemed pretty good however when I received my new hinge, It does not close once installed and appears different that the one I took off where the cam and cam latches are.
I called www2.cip1.com and they said they would look at my pics and compare to the ones they have in stock. It took them 8 days to do so Sad
They said they were all that way and that that was the proper year for my vehicle. They told me I could take it a part and try switching the pieces around (which I told them was a stupid idea)
I know every nut and bolt on my bus except the slider hinge. I tried looking up a description of variations in different years of bays and could not find anything.
Please help me figure this out. I am stumped for now.
I cant be the only one with this issue right?
Thanks in Advance! Gabriel
williamM
williamM is offline
PostPosted: Mon Aug 07, 2017 8:28 pm    Post subject: Re: Slider door hinge trouble. Reply with quote
look on the bus c pillar for the latch seat- I had a night mare getting enough parts from 3 "used but good";- NOT- rollers I bought. Got one from 3 and boy did it roll good and latch open, but the latch closed would not work. Finally got a replacement but not installed yet due to having sold the greybus and now getting it ready for delivery in Oct.
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
busdaddy
busdaddy is offline
Welcome!
That's a bummer that the Chinese can't even assemble a knockoff part correctly and the morons at CIP aren't smart enough to recognize a bad apple in the barrel.
Have a look at this: https://www.thesamba.com/vw/forum/viewtopic.php?t=446358&highlight=sliding+refresh , you may be able to swap levers, if not send it back and shop the classifieds here for a German one.
Слава Україні!
Tcash
Tcash is offline
PostPosted: Mon Aug 07, 2017 8:48 pm    Post subject: Re: Slider door hinge trouble. Reply with quote
The hinge they sent you is a 281-843-336-A. That is for a late Bay Window.
IIRC the hinge changed 1974. So the late fits 74-79.
The hinge you need is 211 843 336 A for an Early Bay Window.
IIRC this hinge fits 1968-73
Good luck
Tcash
williamM
williamM is offline
PostPosted: Mon Aug 07, 2017 8:51 pm    Post subject: Re: Slider door hinge trouble. Reply with quote
Good luck
Tcash
I can't believe that vw wrecking yards across the country -LIED TO ME.
Would you know the specific differences- Might solve my latch closed problem???
Don't step in any!
Tcash
Tcash is offline
PostPosted: Mon Aug 07, 2017 8:56 pm    Post subject: Re: Slider door hinge trouble. Reply with quote
The bearing is the same for early and late.
211 843 359 B
https://www.google.com/search?q=211+843+359+B&...p;ie=UTF-8
NomadCamper
PostPosted: Tue Aug 08, 2017 12:32 pm    Post subject: Re: Slider door hinge trouble. Reply with quote
Good luck
Tcash
This was so helpful!! Thanks Tcash! I have Cip1 looking at how to return this thing for me. hmpf....
Any place to get the proper one????
