zero compression
desert westy
desert westy is offline
PostPosted: Sat Nov 02, 2013 1:23 pm    Post subject: zero compression Reply with quote
Took my van, 84 Westy, to get a tune up and to get smogged. When I picked it up, I found out that it had passed the smog test, but had zero compression in the number three cylinder. i've had the van for about seven years and have driven it about 30000 miles without any issues. The van runs and drives as well now as it ever has. Temperature and oil pressure seem to be ok, power is the same as it has always been. Wondering what problem the motor could have. Considering that it passed the smog test and runs ok, could I have issues with a worn cylinder/piston/rings, problems with valves? I would like to fix the problem rather than blow it up and get left on the side of the road.
bowtiebug
bowtiebug is offline
PostPosted: Sat Nov 02, 2013 1:30 pm    Post subject: Reply with quote
Rolling Eyes I would double check the compression .
It's very unlikely it has 0 compression and passed smog , without compression it would be pouring raw un-burned fuel into the exhaust and would read rich on smog test which = Failed ..
http://www.etsy.com/shop/AlphaKnots
bluebus86
Banned
bluebus86 is offline
PostPosted: Sat Nov 02, 2013 6:17 pm    Post subject: Reply with quote
ditto
dhaavers
dhaavers is offline
PostPosted: Sat Nov 02, 2013 6:28 pm    Post subject: Reply with quote
The cam happened to stop with a valve open on that cylinder.
Spin it and test it again, or do a leakdown test.
"The WonderVan"
