header pipe temps?
vwfye
vwfye is offline
PostPosted: Wed Jul 16, 2014 11:30 pm    Post subject: header pipe temps? Reply with quote
Hey all, this question is about header temps, not exhaust gas temps. So, that said:
What temps are you measuring on the header pipes and/or muffler tip?
64 No'back Speedster "Pearl"
LME "Little Giant Killer 3"
1974 Ghia "PUK"
Nate M.
Nate M. is offline
PostPosted: Thu Jul 17, 2014 8:42 am    Post subject: Reply with quote
On a normal running Beetle motor at idle measured with my IR thermometer, I typically see around 275F-325F an inch or so from the head flange and around 175F-225F where the heat exchanger goes into the muffler. I have no idea about the tips since that tells me all I need to know. . . Wink
Regards,
Nate M.
Squarsche build
Heavy Metal Affliction feature
For heaven's sake, put a type4 and a Porsche 5-speed in there. . . It's the right thing to do!!
vwfye
vwfye is offline
PostPosted: Thu Jul 17, 2014 10:00 am    Post subject: Reply with quote
Nate, what are you getting after a drive?
1974 Ghia "PUK"
