WalshingMachine Samba Member
Joined: July 26, 2014 Posts: 1 Location: Northern California
Posted: Sat Jul 26, 2014 3:53 pm Post subject: Interior light help? |
| New to theSamba and have a problem: the interior sconce lights in my 67 campmobile have conked out. Bulbs are fine, wiring connects all the way back to the regulator in the engine compartment, but no juice! Any ideas before I put the seats and panelling back in? |
olliehank47 Samba Member
Posted: Sat Jul 26, 2014 5:17 pm Post subject: Re: Interior light help? |
| WalshingMachine wrote: |
I always assumed the rear sconce lights were wired to the switch on the left side of the speedo pod--the one that controls the rear cargo area light in all other buses. Have you tried flipping the switch on the side of the pod? I don't have a westy so it's just an assumption. |
Daddybus Samba Member
Posted: Sat Jul 26, 2014 5:21 pm Post subject: |
| Test connection at regulator to see if it is hot (12v). |
joe cool Samba Member
Joined: August 20, 2006 Posts: 1262 Location: Yolo County CA
Posted: Sat Jul 26, 2014 5:48 pm Post subject: Re: Interior light help? |
| olliehank47 wrote: |
x2. i would want those on a fuse from the fuse box. i don't believe they were not done that way originally. |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15429 Location: Casa de Oro, California
Posted: Sat Jul 26, 2014 7:06 pm Post subject: |
| If it's the original Westy harness then there is a bakelite fuse holder on the wire exactly like the back-up light fuse holder. But if it did pop the fuse, why? |
Clara Samba Member
Posted: Sat Jul 26, 2014 8:21 pm Post subject: Re: Interior light help? |
They are independent of the regular dome lights.
They were wired like this, off the VR, with an inline fuse:
Check the wiring in the engine compartment. |
Das67bus Samba Member
Joined: April 06, 2008 Posts: 263 Location: Prescott, AZ
Posted: Sat Jul 26, 2014 8:49 pm Post subject: |
Do you have a good ground to complete the circuit? _________________ SLOW RIDE........TAKE IT EASY!!!
-Foghat
COMFORTABLY NUMB!!
-Pink Floyd |
