IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Sun Sep 04, 2016 11:23 pm Post subject: Current source for brake band O rings and piston seals? |
Anybody know where these 2nd gear brake band O rings and the piston lip seals can be found? I'm still looking but no luck. Bad timing as I thought I already ordered these and the tranny's in the engine stand. Argh.... _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
pablum Samba Member
Posted: Mon Sep 05, 2016 8:49 am Post subject: Re: Current source for brake band O rings and piston seals? |
Pablum,
Thank you. Unfortunately none of the 4 seals are available there, either. And everything I click on is $1.97 so they must be having an issue. That's a really good price for a tranny cooler, though!! Heh... Anyone else? _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1282 Location: Right Here
Posted: Mon Sep 05, 2016 9:01 am Post subject: Re: Current source for brake band O rings and piston seals? |
Why not get a complete kit? Normally when you have to go into a transmission [or any other big job] with a lot of miles, your foolish not to do everything. Of course, there are exceptions to the rules. |
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Mon Sep 05, 2016 9:33 am Post subject: Re: Current source for brake band O rings and piston seals? |
Idaho..if thee tranny has been separated from the diff..you will want the big "O" ring and the paper gaskets. And it is a good time to replace the back to back seals with the "O" rings inside the seal housing.
The reason Witt show.97 cents on the cooler as there are none available..
I may have some of the second gear servo piston "O" rings and misc other "O" rings around..let me know if you want me to look and I will send them on to you. |
Posted: Mon Sep 05, 2016 9:47 am Post subject: Re: Current source for brake band O rings and piston seals? |
Thanks, I've got the seals for the torque converter, the paper and large O ring seals, the governor seal, and the double seals on the shaft. Thought I'd ordered the brake band seals back in June, so kinda bummed to be hours from completion and discover I'm missing those 4 seals - two piston lips and two cover O rings.
So, that's what I'm looking for. Thanks, Atlas - will call AA in the morning and German as well. Was hoping to find a vendor I could order from online today (Labor Day) and then move on to other tasks. Will recontact if they are out, etc.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
pablum Samba Member
Posted: Mon Sep 05, 2016 9:52 am Post subject: Re: Current source for brake band O rings and piston seals? |
IdahoDoug wrote: |
Pablum,
Thank you. Unfortunately none of the 4 seals are available there, either. And everything I click on is $1.97 so they must be having an issue. That's a really good price for a tranny cooler, though!! Heh... Anyone else? |
I gave you that one because I thought $99 for a reverse clutch piston was felonious. I got my stuff here:
http://www.makcotransmissionparts.com/VW-010.html
They have all the gaskets and o-rings in their kits, as well. Just prepare for the shock. |
Posted: Mon Sep 05, 2016 12:05 pm Post subject: Re: Current source for brake band O rings and piston seals? |
Wow - no kidding. Reminds me of the Syncro front wheel bearing extra seal pricing - $45 for a thin rubber lip. Thanks for looking out for me! I'm sure the brake band piston seals are similarly dear in price....
Posted: Mon Sep 05, 2016 12:28 pm Post subject: Re: Current source for brake band O rings and piston seals? |
Hey, I just realized I have a single O ring that is the correct size you posted above. Since I did not have 2 of them I assumed I had not ordered them. So, I also have a thicker grey O ring that is slightly larger in diameter as well. Are the both the same size, or could this be the two O ring parts I thought I ordered?
Sorry about the confusion on my part. It was 3 huge boxes of parts and I've winnowed it down to a couple dozen. Thanks. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
