Mr. Kadron mods
1975 Kombi
1975 Kombi is offline
PostPosted: Sat Jan 17, 2015 1:37 pm    Post subject: Mr. Kadron mods Reply with quote
Does anyone know what exactly AJ does to the carbs. I believe I have a set and the air jet has been drilled out to 165 instead of the 150 stamped on the jet. There has also been a vacuum port added with a plastic fitting but the plastic fitting has broken so I need to fit a metal tube in the hole now unless I can find another plastic fitting. Also does anyone have a parts set of carb that they might want to sell parts off of.
Brett
“He’s decieving you boy! Reach into his pocket and take what he’s got.” Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
Licensed pilot (single engine land VFR)
Rust In Pieces: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v
Brian
Brian is offline
PostPosted: Sat Jan 17, 2015 3:19 pm    Post subject: Reply with quote
Did you ask AJ?
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
1975 Kombi
PostPosted: Sat Jan 17, 2015 3:54 pm    Post subject: Reply with quote
I've emailed the guy 4 times and no replies.
Kind of odd but all the jet sizes have been ground off with a bench grinder. So I have no clue what is in there for sizes unless I buy a jet gauge. I used a drill bit on the main jet and it looks like 160. I'm guessing but to save money someone must have just drilled the jets that were in there instead of buying new ones.
Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
D/A/N
D/A/N is offline
PostPosted: Sat Jan 17, 2015 4:25 pm    Post subject: Reply with quote
Not necessarily....Kaddie Shack does the same thing....grinds the #'s off the jets so you don't know what they are which means you pay a premium for their "custom" jets. As if there's a super-top-secret formula for Kadron jetting. I stopped buying jets from them because I hated feeling disenfranchised. When I ran Kads, I bought jets from aircooled.net because their advice was great and you know what you have. Also, read around on this site because it's fairly common knowledge what size jets to put with which motor combo....you can really only move in full, 1/2, and 1/4 sizes anyway.
Tcash
Tcash is offline
PostPosted: Sat Jan 17, 2015 5:27 pm    Post subject: Reply with quote
I can't speak for the Vendors in this thread. But depending on the availability of jets. Some vendors use Jet Reamers to resize the jets and a good practice is to remove the old jet sizes.
If you have a micrometer or caliper. Maybe you can find a piece of wire, clothes hanger etc. to use as a gauge?
Tcash
TomWesty
TomWesty is offline
PostPosted: Sun Jan 18, 2015 11:23 am    Post subject: Reply with quote
Tcash
Having dealt with both AJ and Kaddie Shack,they are secretive about their jetting recommendations. That said, both provide a wealth of adjustment and tuning info on their sites. I understand them not wanting to make jetting recommendations only to have someone purchase their jets elsewhere.
1975 Kombi
PostPosted: Sun Jan 18, 2015 12:12 pm    Post subject: Reply with quote
Tcash
Ya I guess I can see that but if you have a jet gauge you can figure out the sizes anyway so it is a lot of wasted effort to remove the numbers.
Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
andk5591
andk5591 is offline
PostPosted: Sun Jan 18, 2015 2:42 pm    Post subject: Reply with quote
The port is for vacuum advance distributors - like the 034 SVDA. If you have a mechanical only distributor, cap off the ports. Now - as far as jetting goes. Go to someplace like aircooled.net and get a couple sets of mains - I really dont know what your engine is, but unless its really radical I you probably need 130 to 137.5's. So get a set of 130s, 132, 135 and 137.5. Idles are typically 55 or 60s. You's dump something like $50 for all the jets. For a conservative engine, would start with 55 and 132 and then go from there.
This is all assuming the carbs are in decent shape. AJ and Kaddie Shack both have decent tuning procedures on their sites.
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
1975 Kombi
PostPosted: Sun Jan 18, 2015 3:03 pm    Post subject: Reply with quote
Ya it's a 1974 T4 1800 stock engine. I'll figure out what I have first and then grab a couple around that.
Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
1975 Kombi
PostPosted: Sat Jan 31, 2015 4:05 pm    Post subject: Reply with quote
Also on a side note is there a ball bearing in each carb for the accelerator pumps?? I would assume so but I can only hear one side knocking when I shake the carbs and the one that has no knock has threads on the inside of the plug for the ball bearing passage for the accelerator pump so I'm guessing it was tampered with.
Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
