Bus Rear / Back Seat information thread
PostPosted: Wed Jan 01, 2014 10:00 am    Post subject: Bus Rear / Back Seat information thread Reply with quote
I am starting a thread to detail all rear seat changes.
Photos and more information welcome.
PM me or post in this thread and I will update this first post.
Barndoor:
Barndoor only, although the Barndoor rear seat base may be the same as a 1955 Bus rear seat base.
Barndoor rear seat back rest photos:
http://www.thesamba.com/vw/forum/album_search.php?search_keywords=Barndoor+rear+seat+back+rest
Barndoor rear seat base photos:
http://www.thesamba.com/vw/forum/album_search.php?search_keywords=Barndoor+rear+seat+base
55 is considered "55 only" (may be same as Barndoor)
Unique "straight" rear seat bottom center leg:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=474001
55-57
Flat back seat
56-57 seat bottom
58-mid-63
Humped seat back, seat base has 4 floor mounting points
mid-63-67
Humped seat back, seat base has 2 mounting points, legs were changed when mounting points were changed, basic look is similar to above
Mid-63 rear seat base design change photos
http://www.thesamba.com/vw/forum/album_search.php?search_keywords=rear+seat+base+comparison
Example (note twist on left-hand leg here for primary difference)
In the photo above, the early seat is the bare frame, the mid-63-up frame is in green upholstery.
Other:
Back seat back rest mounts
https://www.thesamba.com/vw/forum/album_page.php?pic_id=218219
Mounting information for the bracket above:
The above bracket is from a '64 Deluxe.
The single bolt is M6x15.
The 2 machine screws are M6x15. 1.00 thread pitch.
My '63 has 2 machine screws:
M5x15 0.8 thread pitch
Cargo floor seat mounts:
57 and earlier "big spring" seat design:
58 and later spring design:
Bay Window versus Split-Window Bus seat from another member
Stanagon wrote:
I just measured two rear seats I have. Both are original upholstery with somewhat worn padding, but in overall good condition.
Bay window:
Seat bottom width: approx. 60 inches (measured toward the front of the seat using the upholstery piping for side to side points.
Seatback width: at bottom: 59-1/2 inches, near top: 57-1/2 inches
'61 Bus:
Seat bottom width: approx 61-1/2 inches
Seatback width: at bottom 62 inches, near top: 60 inches
Conclusion: the split window seat is about 1 - 2 inches wider than a bay window rear seat.
Deluxe rear seat upper luggage bar:
Lengths:
55-66: 53 13/16"
67: 46 1/2"
Diameter: 19mm.
Stanagon
Stanagon is offline
PostPosted: Wed Jan 01, 2014 1:08 pm    Post subject: Reply with quote
I'll add something.
You can use a bay window rear seat (bottom and backrest) in a split window bus that does not have the rear seat "heater log" in the way.
I've been using a bay window rear seat in my '65 panel bus for many years.
The panel (and Kombis?) do not have a rear seat "heater log".
Stan's Classic Service, specializing in air-cooled VWs:
http://www.thesamba.com/vw/classifieds/detail.php?id=614073
www.stanagon.com
My '61 Mango bus thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=110367
My '64 vert thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=386344
My '71 squareback thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=637709
BarryL Premium Member
BarryL is offline
PostPosted: Wed Jan 01, 2014 7:05 pm    Post subject: Reply with quote
I was under the impression that '67 only had a slightly narrower rear seat backrest and slightly longer wall mounting brackets.
Stocknazi
Stocknazi is offline
PostPosted: Wed Jan 01, 2014 8:29 pm    Post subject: Reply with quote
67 deluxe rear seats are unique as they have a different spacing of the luggage bar uprights; the bar itself i believe is the same length.
WANTED:
Thomas Jefferson
PostPosted: Wed Jan 01, 2014 10:44 pm    Post subject: Reply with quote
The bar is shorter.
I'm not sure about the rest but if someone can confirm that I will add the info.
I know Bay Window rear seat backrests are narrower.
CaLiBus
CaLiBus is offline
PostPosted: Wed Jan 01, 2014 10:54 pm    Post subject: Reply with quote
Everett- in your post above.. what makes this 55 only? This is a Portugal made barndoor base seat into the post Barndoor "55" bus.
https://www.thesamba.com/vw/gallery/pix/474001.jpg
Can we also point out the big springs in the seat base that carried into Hanover buses 56-57. I'll post pics of the early Hanover big springs seat.
PostPosted: Wed Jan 01, 2014 10:56 pm    Post subject: Reply with quote
Yes, the use of a Portugal wood seat there is sort of a bad example but was there for the metal leg design.
The center leg is different than later Buses.
It may be all Wolfsburg Buses - I would need someone to confirm that for me.
All flat back seats are big spring.
I did not spell out the "big springs" in the post but I will add that change.
CaLiBus
CaLiBus is offline
PostPosted: Wed Jan 01, 2014 11:19 pm    Post subject: Reply with quote
IMO Wolfsburg only would be a tough call with Wolfsburg parts and mods were found being used in the Hanover plant.
Here's the 56-57 big spring without the pointy center leg.
BarryL is offline
PostPosted: Thu Jan 02, 2014 9:54 am    Post subject: Reply with quote
The bar is shorter.
So the spacing IS the same?
This site doesn't show any other listings for back or bracket (part 33 and 34). http://oacdp.org/5867part/515.png
If the spacing were NOT the same then it's conceivable that the bracket and width change wouldn't show for the last year. I'll see what I can measure first hand.
Again, this doesn't show a shorter guard rail (part20). http://oacdp.org/5867part/463.png
PostPosted: Thu Jan 02, 2014 10:24 am    Post subject: Reply with quote
BarryL wrote:
The bar is shorter.
I don't know if the spacing is the same.
If the seat frame itself is narrower for 1967 I can see the spacing being different.
The bar itself is shorter.
I have a shorter one but I don't know what it came off of.
It doesn't look hacked but it is 46.5"
This matches a comment from Dave24 I posted below.
I did a search and here is some stuff from other threads:
I have a 66 and earlier luggage bar and it is 53 13/16"
Dave24 wrote:
The bar itself is shorter than earlier bars, by 6"-7"
My '64 Bus rear bar, installed, is 53 13/16" (not including the end caps)
I have another bar, uninstalled, this is 53 5/8". Year unknown but I think it is from a '60 or '61.
From Lind regarding 67 seats:
Lind wrote:
it is slightly narrower. the seat is one year only also because the mounts for the uprights are set closer to the middle.
BarryL is offline
PostPosted: Fri Jan 03, 2014 3:44 pm    Post subject: Reply with quote
This quote starts out "it is"..., meaning the bar or the seat?
I just measured an October '67 Kombi rear backrest across the bottom back frame as that was where I could get the tape the tightest. It was 61.5".
I then measured a '65 Delux and it was the same.
Both seats' mounting brackets look just like the one Everett posted.
PostPosted: Fri Jan 03, 2014 4:24 pm    Post subject: Reply with quote
It was a response to a question about the bar.
October '67 meaning a '67 Bus built in October, 1966. Right?
I'd check the top too...
BarryL is offline
PostPosted: Fri Jan 03, 2014 7:21 pm    Post subject: Reply with quote
Yes. Can you fix it if it needs clarifying?
The tops are hard to get to but I'll try. Thing is, the same brackets are in the same positions as the one you posted a picture of on both seats. So, theoretically, unless a '67 bus is narrower at the attachment points, wouldn't that kinda' prove they are the same width?
PostPosted: Fri Jan 03, 2014 10:15 pm    Post subject: Reply with quote
Yes, unless the brackets are different I would not expect to differ.
I seriously doubt the rear deck size changed to necessitate a seat/bracket alteration.
kenshapiro2002
kenshapiro2002 is offline
PostPosted: Thu Jul 17, 2014 8:13 am    Post subject: Reply with quote
I'm confused...jail bars aside did we ever figure out if the '67 rear seat is in any way unique? Width? Mounting points?
Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx
olliehank47
olliehank47 is offline
PostPosted: Thu Jul 17, 2014 2:00 pm    Post subject: Reply with quote
As I understand the discussion, the seat back and bottom are the same width as earlier seats. The luggage bar on the back of the deluxe seat, however, appears to be shorter on the 67 and the spacing of the bar uprights appears to be different as well. Mounting points are the same as earlier seats.
PostPosted: Thu Jul 17, 2014 5:51 pm    Post subject: Reply with quote
This is my understanding as well.
schnidlee
schnidlee is offline
PostPosted: Fri Jul 18, 2014 1:21 am    Post subject: Reply with quote
So if I'm looking at pictures of a possible split rear seat is there a way of confirming its not a bay seat without measurements?
Brian_1952
Brian_1952 is offline
PostPosted: Fri Jul 18, 2014 4:47 am    Post subject: Reply with quote
I would like to see the spring on a 53 earlier middle seat and back seat i'm assuming they're different like the front seat
(20-024785)Ambulance (20-037784)truck (20-035850)panel
(20-035778)kombi
WANTED 52 parts and NOS sheet-metal
olliehank47
PostPosted: Fri Jul 18, 2014 6:01 am    Post subject: Reply with quote
It's a little tricky, depending on what condition the seat is in and the pictures that are shown. Most common way to ID is look at the upholstery. Bay windows have a pattern that looks like three separate seating areas. Of course, upholstery is not always present or not original. Bay window bottom seats have holes in the legs for the pin on later seat clamps, split window seats do not. As far as the seat rear, bay window seats have a metal tab welded to the bottom rail that fits into a slot in the fire wall, split seats do not. Later bay seat backs have plugged holes along the top for headrests and some later ones have a latch mechanism on the sides to hold the seat vertically, instead of a bracket. If there is no upholstery on the seat back, later bay seat has square tube frame rather than round tubing, though I don't know when the change came about.
When in doubt, post the pictures here and someone will be able to help confirm if it is a split seat.
Page 1 of 7
