Bret Young Samba Member
Joined: August 26, 2006 Posts: 756 Location: Turlock, CA
Posted: Sat Jan 04, 2014 11:59 am Post subject: Anybody having difficulties opening doors with new seals? |
I have just finished the resto on my 64 panels and my only complaint at the moment is the difficulty opening and closing the front doors. Doors are aligned properly and were easy to close before putting the window assemblies in. And just for clarification, my 64 is an early 64 (Nov 63) so it still has ice pick from for handles. Just in case people were wondering.
When I close the doors, the flexible seal that goes around the top of the window frame seals very nicely, but so well that it takes effort to open and close the doors. When opening the doors, the latch disengages from the striker plate and pops out about half an inch and then its stuck there. I have to hold the handle open and then put my fingers in between the lip of the door and the body and physically pull it open. And it takes a good amount of pulling. Feels like the doors are suction cupped closed. Does everyone experience this with new seals? Does this wear in?
I dont have my door panels installed yet because being that the doors are hard to open....they are equally as difficult to close all the way. I have to slam them pretty hard to close all the way or they consistently just reach the first notch on the striker plate. Anyone running an accessory door pull on the inside of their bus? If the doors are this difficult, I dont want to put all the pulling pressure on that plastic handle.
Any incite is greatly appreciated. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24768 Location: Olympia Wash Rinse & Repeat
Posted: Sat Jan 04, 2014 12:22 pm Post subject: |
Might try some French Chalk and see if that helps.
Over time the top seal should improve. _________________ In Stereo, Where Available! |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Sat Jan 04, 2014 3:32 pm Post subject: |
I use baby powder on new seals.
Very effective dry lube. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
NAES Samba Member
Joined: September 10, 2003 Posts: 2121 Location: AREA-52 Southern Killafornia
Posted: Sat Jan 04, 2014 5:10 pm Post subject: |
X2 _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
Posted: Sat Jan 04, 2014 5:31 pm Post subject: |
Riff Raff wrote: |
Very effective dry lube. |
What do you think is the main ingredient in baby powder?? _________________ In Stereo, Where Available! |
Posted: Sat Jan 04, 2014 5:51 pm Post subject: |
I think it is talc.
Hydrated magnesium silicate, colloquially referred to in it's loose form as talcum powder, primary ingredient in baby powder.
Sounds like French Chalk is another name for it, but one I had not heard of. (I'll add it to my vocabulary)
Hence, I suggested baby powder. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14272 Location: Casa de Oro, California
Posted: Sat Jan 04, 2014 7:35 pm Post subject: |
I always put a length of lo-tack long lasting tape along the b-pillar where the seam is open. That is where the scraper hangs up. After a while it will get a memory and you can remove the tape. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Sat Jan 04, 2014 8:02 pm Post subject: |
Mark L. recommended corn starch to me. Works well, but you have to reapply it often. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
stevo Samba Member
Joined: January 22, 2004 Posts: 908 Location: the eugeniverse
Posted: Sat Jan 04, 2014 10:49 pm Post subject: |
i installed an around the top ww seal three weeks ago. sticky for the first 10-15 openings. it quickly lost that stickiness. a memory now. |
Posted: Sun Jan 05, 2014 1:02 am Post subject: |
stevo wrote: |
Haha lucky! Ive had them installed for over a month and still sticky as can be.
Everyone else. I greatly appreciate the suggestions. I will pick some of it up and give it a try. So you guys out it on to make them less sticky, but as it wears off, do they become sticky again?
John says he has to continually reapply it. Does everyone have to do that, or does it eventually kinda absorb into the seals? |
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Sun Jan 05, 2014 10:49 am Post subject: |
Silicon spray lube wet or dry. |
Posted: Sun Jan 05, 2014 11:04 am Post subject: |
RPGreg2600 wrote: |
The one problem with any silicon spray is if you later need to paint it will cause a fish eye mess, and seems to be tenacious in sticking around. _________________ In Stereo, Where Available! |
