z-volks Samba Member
Joined: March 11, 2003 Posts: 33 Location: Westport, CT
Posted: Fri Dec 26, 2003 6:10 pm Post subject: return sring on brake pedal |
how hard and how long does it take to replace one. mine just went. not a good feeling.
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79650 Location: Sneaking up behind you
Posted: Fri Dec 26, 2003 6:19 pm Post subject: |
You have to remove the pedal cluster to do it. I recently rebuilt my cluster and it's not hard.
The R&R of the cluster is about 30 minutes. Then you need to punch out the roll pin that holds the clutch pedal on. There's a external circlip that holds on the brake pedal. Now you can replace the spring, but maybe you should paint and lube it before reinstalling. Also check the clutch cable hook... mine broke and needed to be replaced.
Here's a picture of how the cluster goes together.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Fri Dec 26, 2003 7:06 pm Post subject: |
great pics i'll give it shot how hard is it to get the cluster out |
Glenn  Mr. 010
Posted: Fri Dec 26, 2003 7:11 pm Post subject: |
Just (2) 15mm bolts. You'll have to disconnect the clutch and gas cable 1st.
I think one of the magazines did a step by step article a few months ago. _________________ Glenn
Member #1009
#BlueSquare
Posted: Fri Dec 26, 2003 8:45 pm Post subject: Clutch pedal shaft broke weld |
Oh well Got it out quick enough however little problem adter i punched out the clutch pedal from shaft. when i tried to remove the pedal from the shaft the hook on the end of the shaft that connectes to the clutch cable broke its weld. Shaft is froze in the pedal. letting it soak. NEVER EASY!!!
murphy's law,, PS who sell's the whole rebuilt cluster??? |
Glenn  Mr. 010
Posted: Fri Jan 09, 2004 6:05 pm Post subject: |
WOW what difference thanks for all the help. |
Glenn  Mr. 010
Posted: Fri Jan 09, 2004 6:49 pm Post subject: |
Happy to help. _________________ Glenn
Member #1009
#BlueSquare
