Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Fri Apr 11, 2014 5:22 pm Post subject: |
Wasted youth/adulthood wrote: |
Joey wrote: |
The OE shock that originally came on a '72-'79 type 2 is 22.95" fully extended.
The KG5530 (Gas-s-Just) is 22.2" fully extended.
The 344082 (Excel-G) is 23.03" fully extended. |
Well, then does .75" make a significant difference? Just curious, not trying to be adamant. Will the Excel-G style be better for "off-road" applications? |
I think it does with a shock that doesn't have an internal stop. A shock with no internal stop that gets over-extended frequently won't last long. There's probably a reason the original shocks VW installed were longer than the total suspension travel - the top mounts not being strong enough may be one of them. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sat Apr 12, 2014 7:31 am Post subject: |
Joey wrote: |
Amskeptic wrote: |
Just a note:
The wheel bearing housing can be rotated on the spring plate when the four Big Bolts are loose. Depending on your toe and caster requirements, you can have a wheel bearing housing that is "rotated" forward enough that the short shocks just about almost work on the later suspensions. In other instances, the shock mounting is a mile away from the short shocks. Either way, get the correct shock travel for your car.
Colin |
I thought about rotating the wheel bearing housing. But, I currently have no problems with rear tire wear or the way it handles so I think I'll leave things be.
Oh I wasn't recommending that anyone do such a thing, I was answering to those who have said that the short shocks fit their later bus.
The wheel bearing housing needs to be exactly where it needs to be for camber/toe.
Colin _________________ www.itinerant-air-cooled.com |
Chodel Samba Member
Joined: June 13, 2013 Posts: 46 Location: Louisville, co
larryducas Samba Member
Joined: October 25, 2011 Posts: 233 Location: Fallbrook, CA
Posted: Fri May 16, 2014 12:21 pm Post subject: |
I have the kyb gas g on my 71. I love them, replaced older, but still good gas a adjust.
They work great.
Rear #344045, dont know front number.
May not apply, but I want to say that the gas g work great for me in all 4 corners. _________________ 71 deluxe, 1968 type 1 engine rebuilt, 009 distributor, pertronix module, Empi 38 EPC / DGES carb |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sun May 25, 2014 5:38 am Post subject: |
Here are a couple of pictures of my KYB Gas-A-Just shocks, P/N KG5530, rear application. I have removed the bottom anchor bolt and let them extend on their own until they stopped. They are specified to extend to 22.2 inches, and in the pictures they are fully extended with the trailing arm resting on its bottom stop. Note they are also at their maximum travel.
No sales pitch here, rather I was previously asked to see how well they extend with the car on jacks and trailing arm bottomed out. There are a couple more pictures in my gallery.
Joey Samba Member
Posted: Sun May 25, 2014 8:56 am Post subject: |
Hmm, funny how they exactly line up with the bolt hole - almost like they were forced to extend that long...
Mine were about a bolt width away from lining up. _________________ Joey
Posted: Sun May 25, 2014 12:58 pm Post subject: |
Joey wrote: |
Mine were about a bolt width away from lining up. |
When I installed these new on the 1973, the bus was not jacked up, and I seem to recall there was about two inches left when I put them on, but at the time I had no reason to be concerned. This picture was taken with about 2,200 miles on them. I cannot say whether they have been extended by use to the point where they match up close to the bolt holes, but I have my doubts. For them to be extended that far, I would have to be driving around with the trailing arm riding on the stop. These were first installed on my 1973 bus, then when I parked that I moved them over to my 1977 bus.
I'm not sure why yours were too short...or maybe mine are too long for the part number design? Maybe I was sent the incorrect shocks? At any rate, I hope it all works out. |
Posted: Sun May 25, 2014 1:39 pm Post subject: |
I went to the KYB website and searched the product by part number only and noted that their application for the KG5530 applies to rear application for 1974-1968 Transporter and 1979-1968 Campmobile, and shows extend length at 22.2 inches, with a compressed length of 13.74 inches for whatever that's worth.
I then searched by vehicle application (1973 Transporter) and showed more options: Excel-G 344045 with a shorter (!) extended distance of 21.97 inches, but advising Use Kit #107; Recommended OE Replacement. The kit 107 is merely a bolt sleeve kit, nothing about extending the reach.
Not saying that is the gospel here, just noting what KYB shows for the application.
Also, searching out KYB 344082 on their website shows up as "no parts found" |
Joey Samba Member
Posted: Sun May 25, 2014 2:27 pm Post subject: |
Here's how far my shock extends:
Joey Samba Member
Posted: Sun May 25, 2014 2:33 pm Post subject: |
I cannot say whether they have been extended by use to the point where they match up close to the bolt holes, but I have my doubts. For them to be extended that far, I would have to be driving around with the trailing arm riding on the stop. |
It would only take one instance of your suspension to go fully extended to permanently over extend the shock. _________________ Joey
Joey Samba Member
Posted: Sun May 25, 2014 3:14 pm Post subject: |
Anyone actually checked to see that these shocks don't have an internal stop? Replacement shocks are typically designed for the broadest range of applications possible so are apt to have a stop. The original shock that VW used may not have had a stop because it saved VW 2 cents per vehicle. |
Joey Samba Member
Posted: Sun May 25, 2014 3:29 pm Post subject: |
Wildthings wrote: |
In the link I posted above it indicates no internal stop. _________________ Joey
Posted: Sun May 25, 2014 3:59 pm Post subject: |
Joey wrote: |
Well, that's f***ed up. I wouldn't want to install that either. I wonder what's going on with this? |
Posted: Sun May 25, 2014 4:04 pm Post subject: |
Wildthings wrote: |
Anyone actually checked to see that these shocks don't have an internal stop? |
That would mean disassembling one, right? Can't say that I've done that.
OK, I only put that part number in their Search By Part Number box on the Catalog webpage. Didn't look further. |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Tue Jun 24, 2014 8:37 am Post subject: |
The KYB 344082s worked great for me.
Here's how far they extend past the lower mount.
Compared to the old shocks. The KYBs are just slightly longer.
And installed.
_________________ 1976 Westy
1966 Beetle |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12729 Location: on a bike ride somewhere
Posted: Tue Jun 24, 2014 9:50 am Post subject: |
Bala, your first picture is with the tire on the ground, but to compare with those above we'd have to see it on a jack stand/off the ground. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Bala Samba Member
Posted: Tue Jun 24, 2014 10:35 am Post subject: |
asiab3 wrote: |
Bala, your first picture is with the tire on the ground, but to compare with those above we'd have to see it on a jack stand/off the ground. |
I didn't think there was a question as to whether these particular shocks were long enough or not. I had no over extension issues with the old ones (I've done some "off road" camping too), so I am relatively certain these new ones have plenty of travel since they are a bit longer. But, for reference, I see how a jacked up, fully extended picture would be helpful, I should have thought of that. I'll snap a picture next time I get a chance! _________________ 1976 Westy
1966 Beetle |
Posted: Tue Jun 24, 2014 10:43 am Post subject: |
I figured you knew
But for the sake of readers everywhere, and for science!! _________________ Learn how your vintage VW works. And why it doesn't!
Bala Samba Member
Posted: Tue Jun 24, 2014 10:50 am Post subject: |
asiab3 wrote: |
I figured you knew
But for the sake of readers everywhere, and for science!! |
Ha!
Silly mistake, I used metric grade 8.8 bolts thinking they were the same as SAE grade 8 bolts. So, I'll be replacing those soon if I can find them locally. Will give me an excuse to get pictures too. _________________ 1976 Westy
1966 Beetle |
