wudbuch Samba Member
Posted: Sun Dec 28, 2003 6:49 pm Post subject: seat options & gauge problems still |
ok so as with any vw with high mileage my vans front seats are baddly worn an torn aside from findin a set of good vanagon seats next to impossible and i havent seen any aftermarket covers like for the bug are any of ya usin seats from another car and used the vanagon tracks what are my options so i have somewhat of an idea before i go to the boneyard
also i posted earlier about the gas gauge not workin and have yet to drop the tank in this fine cold weather but the temp gauge also doesnt work i grounded the guages and they both do work so as i have not yet got my manual where would i find the sending unit for the temp gauge and yes the idiot light does work just not the needle thanks for all your input
oh its an 86 2.1 [/url]https://www.thesamba.com/vw/gallery/pix/130839.jpg[url][/url] _________________ 68 bug daily driver
66 westy non walkthrough velvet green |
Cam Samba Member
Joined: October 16, 2003 Posts: 35 Location: Halifax, Nova Scotia
Posted: Sun Dec 28, 2003 9:50 pm Post subject: |
I can say that, for the gas gauge at least, it's likely the sender. I ended up replacing my tank the other day and my new (used) tank came with a new(used) sender. And where I used to run dry with my gauge reading 1/4 tank, I can now go well into the red before a fillup! Hooray!
And i've got my seats covered with a set of fuzzy "llama fur" seat covers that fit well and appear to be generic "flaps" style covers. If that's what you were thinking of. |
jeremysmithatshawdotca Samba Member
Joined: February 11, 2002 Posts: 2530 Location: Edmonton, AB
Posted: Sun Dec 28, 2003 9:59 pm Post subject: |
| I've seen volvo seats in a baywindow, but I can't remember what year it was, or if the guy did anything to the tracks or not. You could measure the tracks, then tack a tape measure to a junkyard. Jeremy |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23022 Location: Northwest of Normal
Posted: Sun Dec 28, 2003 11:41 pm Post subject: |
| Your gage problem is most likely the voltage stabiliser which is a small replaceable chip in the instrument clustre printed circuit board. It's about a $10 part. Buy, beg, or borrow a Bentley manual. It'll show you what to do. |
earthmuffin Samba Worm Farmer
Joined: September 24, 2003 Posts: 1542 Location: In the shower..........peeing!
Posted: Mon Dec 29, 2003 3:39 pm Post subject: |
| [email protected] wrote: |
I was thinkin' something of the sort. Those gauges sit right next to each other, it would almost seem if they are both failed that you have a grounding issue or something going on with that hokey blue circuit card that graces the back of the cluster. If it is that voltage stabilizer, (I don't have my manual with me to reference), I believe that it is pretty easy to change, don't take me to seriously, but I believe you can just solder a new one on. |
Posted: Mon Dec 29, 2003 7:26 pm Post subject: |
| It doesn't even require solder. It just slips in to the recepticle and is held in place by a screw. |
Stanagon Samba Member
Joined: July 11, 2003 Posts: 4196 Location: Boston, MA
Posted: Tue Dec 30, 2003 11:15 pm Post subject: |
Re. seatcovers
A few years back Sewfine in Colorado made some nice Vanagon front seat covers for me. I specified a vinyl for the backs and cloth for the front part of the seat. They also made matching vinyl armrest covers for me.
At the time they did not have any Vanagon seat covers so I sent them my foam seat pads so they could make a pattern. I installed the seat covers myself and they fit great and have held up very well (5+ years).
I used '84ish seats with non-adjustable armrests in my '81 Westy. I sent them the seat bottoms for the '81 and '84 seats (the '84s are slightly longer and more comfy) so they could make patterns for both. I think the most recent catalog I got from them had a full range of Vanagon seat covers and carpet kits listed.
I'm pretty sure that all years of Vanagon seats are interchangeable.
-Stanagon |
