scottjk Samba Member
Joined: May 31, 2006 Posts: 485 Location: Salt Lake City, UT
Posted: Sat Apr 12, 2014 6:36 am Post subject: Front Heater Box Rebuild -What foam to use for flapper doors |
I took out my front heater box to replace both wiper shaft assemblies and decided to clean it up. All the foam on the flapper doors is disintegrated and I'd like to replace it.
What foam do you guys recommend? I'd hate to put something in there that reacts with heat and either smells or off gases.
I've got some closed cell foam left over that is used for under floor applications. I wonder how this would work.
Thanks
Scott _________________ 1985 Westfalia 2.5L EJ |
Alaric.H Samba Member
Joined: March 28, 2009 Posts: 2529 Location: Sandy Springs GA
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8398 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Apr 12, 2014 6:52 am Post subject: |
EDIT: Damn, Al beat me to it! _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Sat Apr 12, 2014 7:14 am Post subject: Foam |
How dense is that stuff? Will it allow the flapper doors to close enough?
This stuff looks good for sealing the heater core barrier but I'm not sure it would work on sealing the 6 flapper doors. _________________ 1985 Westfalia 2.5L EJ |
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1342 Location: Snoqualmie (WA)
Posted: Sat Apr 12, 2014 10:06 am Post subject: Re: Foam |
scottjk wrote: |
This stuff looks good for sealing the heater core barrier but I'm not sure it would work on sealing the 6 flapper doors. |
Others have used it with success, there are threads on here detailing install tips (including use of a hot awl). _________________ '91 Double Door Transporter |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15350 Location: Syracuse, NY
chimivee Samba Member
Joined: September 23, 2009 Posts: 745 Location: Orange, CA
Posted: Sat Apr 12, 2014 9:33 pm Post subject: |
I re-foamed the heater flaps on a prior van about 10 years ago and, at least at the time, I couldn't find any camper top foam locally that seemed like a suitable replacement, even though that's what everyone recommended. But I don't remember if I tried specifically the 3M stuff mentioned in this thread.
I ended up using pipe insulation wrap and it seemed to work well. It's thin, fairly dense closed cell foam, but very soft and squishable - kinda like memory foam the way it compresses.
_________________ -James
86 Syncro Westy, etc |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10355 Location: N. Idaho
Posted: Sun Apr 13, 2014 4:05 pm Post subject: |
I have a thread on it as well. Whatever I used is ID'd in the thread and it seemed tailor made. It was extremely soft so conformed well to the surfaces with minimal pressure but also had kind of a "memory foam" feel so when the flaps were closed it seemed to further mush and conform with any high spots not preventing full and even seal pressure. Worthy project. Quieted the van on the highway (was whistling) and the fan blew a hurricane after this job.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
SyncroJack Samba Member
Joined: August 23, 2010 Posts: 94 Location: Vancouver, WA
Posted: Sun Apr 13, 2014 5:01 pm Post subject: |
What ever foam I used sticks in freezing weather and occasionally bends the control cables. Grrrr. I need to revisit the heater box foams....... _________________ 86 Syncro 1.8T power!, 76 Westy |
