Big nut tranny/nose cone q’s into a 59
Joe_bury
Joe_bury is offline
PostPosted: Mon Aug 30, 2021 9:10 pm    Post subject: Big nut tranny/nose cone q’s into a 59 Reply with quote
Hi all,
Just need a little bit of guidance. I’m going to be fitting a big nut tranny into my 59 bus however it’s missing the nose cone. I’m so confused as to which nose cone will fit ok. I found a 211.301.211G nose cone with the hockey stick for sale which is listed for a later split bus and will fit my tranny fine however will it be ok fitting into my 59 bus? Or do I need to modify or get a different nose cone to suit?
Your help will be appreciated, tranny knowledge is lacking a wee bit..
Thank you
Lind
Lind is offline
PostPosted: Mon Aug 30, 2021 9:29 pm    Post subject: Re: Big nut tranny/nose cone q’s into a 59 Reply with quote
Is your bus German?
what is the VIN number?
do you have a picture of the transmission mount area on the bus?
Most German '59 buses have the early style split case transmission, which uses a different mount than a bignut transmission. The last few months of '59 model year production uses the later transmission.
Wanted:
Joe_bury
Joe_bury is offline
PostPosted: Tue Aug 31, 2021 2:11 am    Post subject: Re: Big nut tranny/nose cone q’s into a 59 Reply with quote
Hey mate,
It’s an Aussie delivered bus (I’m in Melbourne) vin is 434824
This is the best picture I have at the moment
Hope this helps. The gearbox in there is not the one going be to use btw
Thank you
Lind
Lind is offline
PostPosted: Tue Aug 31, 2021 6:04 am    Post subject: Re: Big nut tranny/nose cone q’s into a 59 Reply with quote
Your 211G nose cone will bolt right on to the transmission. Bolting the transmission to the bus is a different story. What you have is a split case (early style) bus, and you want to put a tunnel type (late style) transmission in it. To bolt in a late transmission in an early bus you need to either cut the original trans mount out and weld a different mount in, or you have to go through a bit of work to do it without hacking on the bus. There are half a dozen solutions to do it, all with good and bad aspects to them. You can search through the forums to find the different solutions. In the end, it comes down to do you want to spend ~500 to preserve the originality of the body of your bus.
For my early bus, I did not want to hack the body, so I had a very talented local machinist weld part of a split case nose cone onto a tunnel type nose cone (one without the backup light switch, which interferes with the fit). Then we used a center mount for the transmission to carry the load. It was a bit of work, but I am happy I did it that way on that bus.
Most people just hack the old mount and weld in a new one.
Wanted:
Bruce Amacker
Bruce Amacker is offline
PostPosted: Tue Aug 31, 2021 7:02 am    Post subject: Re: Big nut tranny/nose cone q’s into a 59 Reply with quote
In addition to the correct info above, you'll have issues with the parking brake cables and need to shorten them, plus you may have issues getting the tires onto the bus as the BN is a bit wider and the '59 does not have the flared fenders like later buses have. BTDT.
'66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263
Erik G
Erik G is offline
PostPosted: Tue Aug 31, 2021 11:39 am    Post subject: Re: Big nut tranny/nose cone q’s into a 59 Reply with quote
still worth it - big nut trans makes all the difference in the world for regularly driving it
Clara Premium Member
Clara is offline
PostPosted: Tue Aug 31, 2021 1:22 pm    Post subject: Re: Big nut tranny/nose cone q’s into a 59 Reply with quote
Big nut boxes bolt right up to a split case center section the same as to a tunnel case.
Little and big nut boxes bolt the same to 55-67 bus spring plates.
In any case, read up on nose cone mounts in regards to bolting a tunnel center into your split case bus,
and read up on ebrake cables if you are installing a big nut in it.
I ended up swapping from a tunnel case to a split case center section in my 56 bus, with the 63 1 ton boxes.
The $300 nose cone adaptor I had used with the tunnel case pushed the trans back a a bit and changed things enough to mean excessive early rear tire wear after only a couple K miles. So it had to go.
split case trans is not as nice in rush hour traffic.
Joe_bury
Joe_bury is offline
PostPosted: Tue Aug 31, 2021 10:50 pm    Post subject: Re: Big nut tranny/nose cone q’s into a 59 Reply with quote
Thanks all for the prompt replies. Did a bit more digging and believe this would do the job?
https://wagenswest.com/product/lollipop/ should be all I need to do this install right using a standard nose cone?
Cheers
earlywesty
earlywesty is offline
PostPosted: Wed Sep 01, 2021 5:16 am    Post subject: Re: Big nut tranny/nose cone q’s into a 59 Reply with quote
Cheers
Yes, I used this and it works well. If you have a reverse light switch in the nose cone you may not have room for it with the adapter. If you have to remove the switch for this reason then use a very shallow plug in its place. Otherwise it will prevent correct shifting. I learned this the hard way a few years ago. I had to trim down the plug I put in place with an angle grinder. Suggest getting this right before you install the transmission, which is much easier.
Joe_bury
Joe_bury is offline
PostPosted: Wed Sep 01, 2021 2:25 pm    Post subject: Re: Big nut tranny/nose cone q’s into a 59 Reply with quote
That’s great thank you all for you advice.
Lastly though I remembered I do have an old 211.301.211A nose cone it’s listed as 51-58 can I use that on the big nut box and just bolt right in?
Thank you
Joe
jeremy57ride
jeremy57ride is offline
PostPosted: Wed Sep 01, 2021 5:33 pm    Post subject: Re: Big nut tranny/nose cone q’s into a 59 Reply with quote
Thank you
Joe
That early nose cone will unfortunately not work on a tunnel transmission so the above suggestions are correct... but there is some modifications needed. check out page 7 of my thread, been there done that on my 58 single cab. https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=120 -also there are nose cones with the early (donut) mount that have been machined to fit a tunnel trans but they are pricey and a could not find them in my quick search.
"If you don't do it this year, you'll be one year older when you do." -Warren Miller
'64cal lookdub
1200 Deluxe
'64cal lookdub is offline
PostPosted: Thu Sep 02, 2021 11:11 am    Post subject: Re: Big nut tranny/nose cone q’s into a 59 Reply with quote
Cheers
That’s pretty slick, I didn’t know that was around.
