Greg Lindquist Parts Pictorial (pic heavy)
Tcash
Tcash is offline
PostPosted: Fri May 09, 2014 1:35 pm    Post subject: Greg Lindquist Parts Pictorial (pic heavy) Reply with quote
First off This post is not for the purpose of sales, it is for the preservation of reference material only.
I would like to first and foremost thank Greg Lindquist! His knowledge, attention to detail and documentation in his classified ads is surpassed by none.
I only hope that this thread helps you and future generations to come to keep these great vehicles alive.
Tcash
To search the page:
Hit CTRL>F on your computer and type the part number in the box that pops up. Example of part number 211.945.531.B or 211.945.531B
Greg Lindquist, classified ads can be found here:
http://www.thesamba.com/vw/classifieds/search.php?username=Greg+Lindquist
This is a searchable document.
(hold-Ctrl>press-f)
Type in box part number or description
Westy Interior Fasteners/Buffers/Anchors
#01 - Aluminium Closet Clothing Hanger Mount (67-73)
#05 - White Small Rubber Buffer, Screw Pop-Top
#06 - White Large Rubber Buffer, Screw Pop-Top
#07 - Black Plastic Bracket 231.069.949 (Westy 73-79)
#08 - Ivory Plastic Bracket 231.067.949 (Westy 64-72)
#09 - Black Plastic Bracket 231.069.949 (Westy 73-79)
#10 - Steel Cargo Door/ Equipment Bracket 231.067.256 (64-73) - SOLD JAVIER (SPAIN)
#13 - Steel Passenger Seat Backing Bracket (68-74)
#14 - Chromed Guide Cover for Lock: Bottom Cushion 231.070.238
#15 - Steel (Stock) Guide Cover for Lock: Bottom Cushion 231.070.238
#16 - Steel Hammock Mount Front - SOLD JAVIER (SPAIN)
3 - Steel PopTop Anchor Bracket 231.069.486
B - Steel Pop Top Anchor Bracket 231.069.486
C - Black Donut Seal Connector Rod
C - Black Rubber Compression Seal Connecting Rod 211.259.285
C - Chromed Plated Bolt -
C - Connecting Rod, Adjustment Nut 211.259.279 -
C - Spring Clip for Rod Ends 211.259.283 -
D - Ivory Hard Plastic Closet Clothing Hanger Tube (72-73) -
E - Black Rubber Passenger Seat Buffers, Screw 211.881.865D -
G - (30 pcs REMAIN) Original Stainless Door/Interior Push Fasteners (SO42/44/69) - (42 pcs SOLD OLAF - GERMANY)
H - Steel PopTop Anchor Bracket 231.069.486 - $6.15 each
I - "GHE" Black Rubber Buffer Short for Cabinets, Screw "470 0052" - $3.15 each
J - Steel Corner Stiffener Large, Bolts, Nuts, for Cabinets - $4.95
K - Chromed Plated Bolt - $2.00
K - Fresh Air Flap Right Passenger Side, Nylon Mounts 211.259.150 - $17.15
M - Steel Corner Stiffener Large, Bolts, Nuts for Cabinet - $4.95
O - "GHE" Black Rubber Buffer Tall for Cabinets, Screw "470 0044" - $3.85 each
P - Steel Corner Stiffener Small, Bolts, Nuts, Washers, for Cabinets - $3.95
R - Fresh Air Flap Left Driver Side, Nylon End Mounts, Black PLastic End Cap 211.259.149 - $18.15
R - White Nylon Drawer Runner, Screws - $4.10
X - Original Black Plastic Door / Lid Push Fasteners (Westy 74-79) - ALL SOLD DOUG/PETER (USA)
Z - White Nylon Drawer Runner, Screws - $4.10
Bay Westy Interior Handle/Straps
B - Black Strap with Two Snaps & Screws (74-79) - SOLD MITCHELL (USA)
C - Westy Side Vent Window Knob with Screw (73-79) - SOLD MITCHELL (USA)
G - Ivory Push Buttons (73 in particular but work 68-79) - ALL SOLD BARRY (USA)
H - Aluminium / Plastic Push Rods for Latch (68-79) - ALL SOLD BARRY (USA)
K - Black Hard Plastic Handles (74-79) - $6.50 each - 6 SOLD ELOISE (CANADA)
O - Pop Top Pull Handle, End Caps, Nuts, Bolts, Washers (68-79) - $18.85
R - Black Bay Westy Curtain Straps, Snap, Screw (74-79) - $6.15 each
X - Off Green Latch Mechanicals, Springs, Catch (68-79) - ALL SOLD BARRY (USA)
Westy Electrical Housing 231.070.531
"C" - Bryant Bay Westy Electrical Housing/Power Cord - $65.00
"K" - Cole - Hersee Boston, Mas. USA Diode - $11.85
"O" - In line Fuse Holder - $2.10
"R" - ULTRA "0121L" 12 Volt Diode Suppressed Made in USA "5894" - $12.95
Original Bulbs & Fuses 6v & 12v
A - Brass Single Element 12v32cr - ALL SOLD FIJI
D - Silver Glass 5 amp 32 volt "303"- $5.95 Package
E - White 15/8 amp / Blue 25 amp Fuses - ALL SOLD USA
G - Brass Single Element: 12v32cr - $3.75 each
J - Silver Large Interior Bulb: 2x Osram 6V18W / 1x Winkler 6V/10 - $5.95 each
K - White 8 amp Fuses - ALL SOLD USA
M - Silver Medium Interior Bulb: Philips 12V10W - $4.15 each (3 SOLD THAILAND)
N - Silver Small Interior Bulb: 1x 12V5W "K5641" /1x Philips 6V5W "6844" - $4.95
O - Single Element:12v-21W SOLD FIJI /Osram 6V20W /Philips 6V18W - FIJI/USA
P - 2x Silver Bulb 12 volt 4 watt "Spahn"/2x Silver 12 volt 3 watt "Osram" - $1.55 each
Q - Pink 16 amp Fuses - ALL SOLD USA
R - Burgundy 16 amp / White 8 amp Fuses - ALL SOLD USA
S - White 8 amp / Red 16 amp Fuses Package - SOLD FIJI
T - Silver Glass 2 amp 250 volt - $6.95 Package
U - Silver Double Element: 12V21/5W - $3.95 each
V - NOS 8 amp Fuses - $0.95 each
W - Brass Double Element 12v32/3cp - ALL SOLD FIJI
Bay SLIDING Door 1968-1972
A - Striker Plate "Bomoro" part 221 843 656 (V.G.) - SOLD SPAIN
C - Striker Plate "Bomoro" part 221 843 656 (Good) - $5.95
D - Sliding Door Catch 211 843 454 - 1972 UP (Good) - $9.95
H - "Roller Guide" Bracket Grey Metal with screw / washer / steel pin part 211 843 436 (V.G.) - $9.95
H - Plastic Cover Cloud White (top of door) 211 843 486A 8/67 up (EXCELLENT) -
K - Sliding Catch 211 843 454 (V.G.) - SOLD SPAIN
Q - "TGO" Remote Control Lock 221 843 654A - SOLD USA
Y - Door Check part 211 837 249A - August 1968 UP (L or R)SOLD CANADA
Z - Door Post Striker Plate"Bomoro" with correct Bolts + Washers 211 843 656 (V.G.
BOSCH Vaccum Advance
A - Vacuum "BOSCH" "Germany" No stamping on Arm V.G. - SOLD INDIA
(for JUR4 distributor - VW - 113 905 205T/ Bosch 0 231 137 035)
M - Vacuum "BOSCH" with stamping: "885" on Arm - SOLD USA
(for JFU4 distributor - VW 043 905 205C / Bosch 0 231 176 028)
Z - Vacuum Advance Markings:"581" on Lever Arm (No other Markings) - $19.95
Westy Cabinet Panel Edging 64-73
1@18" - SOLD USA
1@2" - $0.05
[email protected]" - $0.05
[email protected]" - $0.15
1@23" - SOLD USA
1@35" - SOLD USA
[email protected]" - $0.30
1@57" - SOLD USA
[email protected]" - $0.50
1@63" - SOLD USA
2@ 2.5" - $0.10 each
2@13" - ALL SOLD USA
2@74" - ALL SOLD USA
B" - Ivory "T" Channel 3/4" Wide Face for: Vanity Cabinet / Spice Rack/ Jump Seat / Ice Box:
E" - Ivory Plastic "C" Edging Cap Trim 3/8" thickness for Wood Ceiling 12 feet length - $19.95
G" - Bright White Plastic "T" Channel LATE BAY:
Q" - Cloud White Beading for Front Door Lock Pillar: 315 867 365A (20.5" length) L/R - $5.95
Engine Mount Carrier (8/1971 up) 021.199.231C
2 - Bonded Rubber Engine Mounts "VI-3674" part 021 199 231C (Good usable) - $10.50 each
(correct bolts/washers good threads, mount threads all good with one mount slightly compressed)
Right Steel Mount Carrier: Straight & Crack Free 021.199.222A - SOLD FRANCE
Left Steel Mount Carrier: Straight & Crack Free 021.199.221A - SOLD FRANCE
Note: Rubber Mounts Made in Germany for August 1971 and later or Ch.No. 212 2000 001 up
Bay Westy Part Lot: HARDWARE
2 - Early Tan Support Brackets for Bottom Cushion Z Bed - SOLD GERARDO (USA)
6 - Early Tan Hinges for Cabinets - ALL SOLD BARRY (USA)
12 - Steel Catches for Cabinets - ALL SOLD BARRY (USA)
1 - Tan Curtain Strap - $6.65
44 - Aftermarket Steel Panel Clips Front Doors/ Rear Cargo Lid / Sliding Door - $1.05 each
"A " - Small Steel Plate Qty 2- $2.05 each
"B" - Large Steel Thread Bolt Mount Plates Qty 2 - $4.85 each
"C" - Large Steel Non-bolt Mount Plates Qty 4 - $4.15 each
4 - Steel Multi Hole Mount Plates for Z Bed Wood Backs - $ 2.05 Each
4 - Steel Thin Three Hole Stiffener Straps - $1.15 each
6 - Steel Corner Stiffener Plates Medium Two Hole - $2.00 each
4 - Steel Corner Stiffener Plates Large Two Hole - $2.55 each
Note: Bay Westy Early & Later Hardware
"SK68" 9 Pin Flasher Unit: 211.953.227A
1 - Original Tested 12 Volt Flasher Unit 9 Pin/1-4x21W: 211.953.227A
(Correct for July 1968 till August 1970 up to chassis number 211 2000 000)
Eberspacher BN4 12V Gas Heater:
B - Thermo Switch 311 261 571A - $29.95
C - "SWF" Relay (BN4 Heater) 211 963 141 Marking: J=7A, B=7A""MA 31JB" "R601.048" - SOLD NORWAY
D - BN Body Wire Grommet Wire Harness 211 611 751 - $1.10
F - Metal Gas Line Rubber Grommet - $1.25
G - BN Body Rubber Grommet Spark Plug & Thermo Switch - $7.45
H - Over Heat Switch with 8amp fuse 311 261 581B - $4.95
J - "BERU" 12 Volt Heater Plug (EB part 8140) Marking: 140M 12V""1A" - SOLD NORWAY
K - "BOSCH" Relay markings: "0.47 uF/100V""0290801""006""22" - SOLD NORWAY
N - Wire Harness Wire Pressure Clips (attach to BN Body) - $1.05 each
P - Rubber Washer - $1.10
Q - "BERU" 12 Volt Spark Plug (EB part 8130) Marking: "EBE514""DA""F" - SOLD NORWAY
S - Brass and Plastic Four Connector Base - $3.25
T - Thermo Switch Prob Body Seal Gaskets - $2.00 each
U - "SWF" Relay (BN2 Heater) 311 963 141 Marking: "500.255""12V240W""MJBA" - SOLD USA
V - BN Body Rubber Access Plug - $3.50
W - Controller Knob (by Drivers Seat) 111 941 541B - $16.95 each
Y - "Safety Switch Relay Unit" (Made in France) Marking:"104 140=2FT=12V" - SOLD USA
Z - BN Body Single Wire Grommet - $1.10
Bay Bus Sunvisor & Interior Trim Ivory
C - Ivory Door Pillar Beading Lock 315.867.356A 20.75" / 53 mm length - $9.95
E - Cloud White Bead Lock End Cap 214.867.304 "King" & Screw - SOLD RICHARD, CANADA
F - Cloud White Bead Lock End Cap 211.867.303 "King" & Screw - SOLD RICHARD, CANADA
G - Ivory Assist Strap 221.857.629A - $11.75
H - Ivory Assist Strap 221.857.629A - $11.75
I - Cloud White Bead Lock End Cap 211.867.303 "King & Screw - SOLD RICHARD, CANADA
J - 2 - REMAIN Coat Hanger Base "Helphos" / Screw 211.857.629A - $1.95 each (2 SOLD RICHARD, CANADA)
K - Ivory Sun Visor Driver Side Metal Swivel Base 211.857.551F with VW logo - (USA)
M - Biege Large Coat Hanger, Brass Centre, Screw 111.263.351 "King" - $5.95
O - Biege Door Handle Inner Door Cap 211.843.645 - SOLD ANDREW (USA)
O - Biege Door Handle Inner Sliding Door Right 211.843.642A - SOLD ANDREW (USA)
O - Cloud White Bead Lock End Cap 211.867.304 "King" & Screw - SOLD RICHARD, CANADA
Q - 2 REMAIN Coat Hanger Cap "Helphos" 221.857.629A - $1.05 each (2 SOLD RICHARD, CANADA)
R - Ivory Sun Visor Passenger Plastic Swivel Base "VW" & "Audi" logos - SOLD ANDREW (USA)
U - Cloud White Bead Lock Double Ended 211.867.302 & Screw - SOLD RICHARD, CANADA
X - Cloud White Assist Strap 211.857.629A, Mount Plate, Screws, Black Plastic Buffer - (USA)
Bay Blower Assist Fan: PARTS
B - VW Logo Bracket Mounts from Van Body to blower motor mount ("S" above) - $4.15
C - Rubber Vibration Isolator Mounts V.G. with correct Nuts - ALL SOLD STEVE (CANADA)
J - VW Logo Small Round Hose Clamp - $2.10 (Note: have the Oval Hose Clamp but did not photo)
K - Main Blower Housing Clean Straight with V.G. solid Brazed Repair / correct Mount Nuts (No Plastic Flaps) - $11.15
P - 12V Blower Motor/BODY/ Hardware/Fan (complete but need to be taken a part and serviced) - $12.95
S - VW Logo Bracket from Blower Motor ("B" below) - SOLD STEVE (CANADA)
W - VW Logo Large Motor Clamp - SOLD CANADA
BN4 Gas Heater Vent Ducting 66-72: 211.261.331
A - Gas Heater to FIRE WALL DUCT: 211.261.331 - $12.95
C - Regulator CONTROL CABLE & Casing: 224.261.941 - $24.95
F - HEX NUT for Control Cable by Driver's Seat Part: N 11 157 1 - $3.95
G - Wiring HARNESS, Fire Wall Grommet, Connectors (from heater regulator through body) - $6.95
M - Firewall Rubber SEAL: 211.261.367A - $3.95
Q - KURLED BOLTS, Lock Washers (for regulator switch) 211.261.357 - $2.95 each
SOLD B - Fire Wall Ducting (passes through body under rear seat) 211.261.357 - SOLD SPAIN
SOLD E - Regulator Switch with Cable/Hex Bolt for cable Part: 211.261.355 - SOLD HOLLAND
Bay Westy Water Tank Buffers 70-73
4 - Black Rubber Buffers Water Tanks 231.070.976 correct: Nut / Washer / Bolt
Seat Anchors: "O" "R" Remain
"1" - 2 RARE Short Seat Clamps 221.885.285 (NO Seat Rail Pin) - ALL SOLD FRANCE
C - Floor Plate at Cargo Door Bolt Anchor Plate 12 7/8" x 2 5/8" - ALL SOLD FRANCE
K - 4 Short Seat Clamps "VW" logo 221.885.285A (Seat Rail Pin) - ALL SOLD FRANCE
K - 5 Tall Seat Clamps "VW" logo 221.883.865A (Seat Rail Pin) - ALL SOLD FRANCE
O - 2 Floor Mount Bolt Anchors Holds Metal Clips from 1972 Westy - $4.95/$3.95
R - 2 Large Body Mount Threaded Nut Mounts from 1972 Westy - $3.15 each (3 Small SOLD - USA)
Bay Westy Interior Parts Lot#3 68-79
B - Steel BED PROP for base cushion, Ivory Stop, correct nuts/bolt/screw (V.G.) - SOLD DOUGLAS (USA)
C - "RAND-Tec" FAUCET, White Switch, Black Hose, Stainless Clamp (Good) SOLD IRELAND
D - White Wiring Harness (12" White Dutrax length) 14/2 Cable(V.G.) - $3.95
F - Spare TIRE LID Bracket (Black Secure Knob threads into) Good - $5.95
G - "RAND-Tec" FAUCET, Black Switch, Black Hose, Stainless Clamp (Good used) - SOLD FRANCE
H - Sink Sieve Stop (tall style) Stainless/Rubber Stop ZVW.223.522 (V.G.) - SOLD USA
I - Black Wiring Harness (32" Black Duraflex length) 3/14 Cable (V.G.) - $5.95
J - ROOF VENT 3 Hole "Sun Valley California" (Earlier with Sun) V.G. - SOLD GERMANY
K - "D.E.F." Faucet, Tap, Screws, Mount Plate, Switch, Hose, Clamps (V.G.) - SOLD UK
L - FENDER MOUNT ANCHOR for "Z" Bed Base, Rubber Seal, CORRECT Nylon Nuts (V.G.) - SOLD USA
M - "D.B.G.M." VW logo IN-LINE FUSE Holders (V.G.) - ALL SOLD CANADA / USA
O - "BRYANT" Electrical Service Cover EXCELLENT - SOLD GERMANY
P - Sink Sieve Stop (short style) Stainless/Rubber Stop ZVW.223.522 (V.G.) - SOLD UK
Q - Steel CARPET CAP (for Spare Tire Lid Cover) EXCELLENT - $9.15
R - Black Rubber BUFFER PAD SPARE TIRE Mount (back tire well) V.G. - $1.05
S - Steel CARPET CAP (for Spare Tire Lid Cover) GOOD - $5.95
U - Spare TIRE LID Bracket (Black Secure Knob threads into) V.G. - $9.95
V - Ivory Plastic Water Fill Neck, Cap, Rubber Seal Collar: ZVW.221.515/506 - SOLD USA
X - Ivory Plastic Water Fill Nek, Cap, Rubber Seal Collar: ZVW.221.515/506 - SOLD UK
Y - "GSR" 5 Hole Sun Valley California Roof Vent (with Horse worn one side) "3927-8"- SOLD USA
Z - "GSR" ABS Plastic 1.5" Dia SINK DRAIN PIPE, Rubber Seal (Parts 3216-1/3211) - SOLD CANADA
Bosch Vacuum Advance 205C 1974 Calif. Smog
1 - Bosch Vacuum Advance Unit JFU4 with "885" Arm
(VW part 043 905 205C / Bosch part 0231 176 028)
Note: For 1974 California Smog Regulated Distributor
EBERSPACHER Gas Heater BN4: PARTS
A - Bosch FAN Motor, Harness, Body, Shaft (Tested...NOT Working for Parts) 0 130 056 026 - $16.50
(Markings: "CRG 12V 3A" "5000 U/MIN" "Germany Importe Dallemagne")
A1 - Orange Fan Blades, Brass Nut EX. Used - SOLD Holland
G - Stainless COMBUSTION CHAMBER /Heat Exchanger V.G. Used Condition - $29.95
K - Support CLAMP with Rubber SEAL: 211.261.397 (EB part: 8013/14) - $6.95
Q - Grey CASING COVER: 211.261.315 (EB part: 8001) Screws EX. PAINT! - $18.95
(Note: Casing I.D. Tag: Heizgerat Typ BN4 / Ausfuhrung 201415 / Fabrik-Nr. 28193 / Prufzeichen
S-36 / Brennstof Benzin / Spannung-Volt 12 / Heizliestrung kcal/h 1080-400 / Sai nr 200 B4)
F - Grey CASING COVER: 211.261.315 (EB part: 8001) Screws/Washers/Clips V.G. PAINT! - $15.95
(Note: Casing I.D. Tag: Heizgerat Typ BN4 / Austfuhrung 201295 / Fabrik-Nr 70852 / Prufzeichen
S-036 / Brennstoff Benzin / Spannung-Volt 12 / Heizleistung kcal/h 1080-4000 / Sar nr 200 B4)
Note: Grey Cover Styles: marked "Made in Western Germany" "Hersteller: J. Eberspacher Esslingen"
both covers have different cut outs. - Greg
Bay Floor & Dash Heat Ducts: 68-79
A - Senegal Red Heat Distributor Tree 211.255.881D 76-79 EX. - SOLD USA
B - Heater Elbow 211 255 805B + Heater Pipe Under Floor 211 255 815B - SOLD USA
C - Black Plastic Heater Splitter Duct: 211 255 477B with Marks: "RHO" - $9.95
D - Heat Distributor Tree Vent Control Cable/Casing with hardware - SOLD USA
E - Left Hand Fresh Air Vent:(at glass) 211 259 237 HP - $9.95
F - Right Hand Fresh Air Vent: (at glass) 211 259 236 HP - $9.95
G - Right Hand Heater Vent: (top of dash) 211 255 476B Marks: "RHO" - $9.95
H - Left Hand Heater Vent: (top of dash) 211 255 475B Marks: "RHO" - $9.95
I - Dash Vent Insert 211 255 481B Marks: "2" - SOLD USA
J - Dash Vent Insert 211 255 482B Marks: "1" - SOLD USA
K & L - Metal Dash End Caps 211 857 213 / 214 - $9.95 pair
M - Left Fresh Air Duct 211 259 235 - SOLD USA
N - Right Fresh Air Duct 211 259 236 - SOLD USA
O & P - Rubber Vent Fresh Air Seals 211 259 239 - SOLD USA
Q & R - Metal Fresh Air Covers 211 249 241 - $8.25 Pair
Sliding Door Hinge 1968 to July 1971
1 - Sliding Door Casted Mount with Brass inserts / washers / bolts 211 843 387 - $12.95
1 - Metal Clip Hinge for Seal (below) 211 843 403 - $1.95
1 - Rubber Seal Hinge Housing Right 211 843 402 - $1.95
1 - Sliding Door Spring 211 843 395B - SOLD CANADA
Note: Lower Brass Bushing Insert has small part of lip missing .
SWF Bay Bus Wiper Motor Unit: 211.995.113G
1 - SWF German Wiper Motor Unit from 1977 Bus 211.995.113G
(Markings: "54" Pivot Arm / "68" Pressing Wiper Rod / "88" Body)
BA6 Gas Heater Bench Seat Deflector Shield
1 - VW Bay Bus BA6 Gas Heater Bench Seat Deflector Shield with correct Rubber Buffers
Note: For Fire Wall Under Bench Seat or Westy Bed Bench Seat Heater Vent correct 74-79 Bay Bus
Bay Bus Glove Box Lids: 221.857.123A
C - Metal Trim Frame Surround/ Screw / Washer 221.857.137A (8/71 - 1979) - $6.95 each (1 SOLD JON, USA)
K - "VW" Logo Glove Box Lid / Hinges / 4 Tap Screws / 4 Speed Nuts EX. Used 221.857.123A - $22.55
O - Cloud White Plastic Beading - Lock Pillar 21.5" length 315.867.365A - $4.55 each
R - "VW" Logo Glove Box Lid / Hinges / 4 Tap Screws / 4 Speed Nuts EX. Used 221.857.123A - $22.55
Note: Bay Bus August 1971 up Bus Chassis Number 212 2000 001 Left Hand Drive
Late Bay Tail Light PART LOT #77
C PINK" - Rubber Side Reflector Seals - $1.15 each
C" - 7 pcs Plastic Bulb Holder Single Contact - $5.15 each (5 SOLD PETER - USA)
G" - Small Spade Black Wire - $1.15
H" - Plastic Bulb Small Holder 2 Contact - $1.95
J" - Plastic Bulb Holder 4 Contact - $3.65 each
K" - 4 Grey Rubber Housing/Lens Seals - ALL SOLD USA
O" - Hella Grey Side Body Reflector Mount Base "MR 70" 211.945.161 - $4.95 each
P" - Plastic Bulb Medium Holder Single Contact - $2.95
R" - SWF Grey Plastic Tail Light Housings/Mount Nuts/Mount Washers - SOLD PETER (USA)
T" - 4 pcs Plastic Bulb Holder 3 Contact - $4.85 each (2 SOLD PETER - USA)
Y" - Rubber "D" Body Seal for Electrical Wiring Harness - $3.15 each
Bay Dash Spliter Heater: 211.255.477B
A - Part 211 255 477 B Markings: "RHO" Black Plastic - $9.95
K - Part 211 255 476B Markings "RHO" - SOLD USA
M - Part 211 255 475B Markings: "RHO" Black Plastic - SOLD USA
BN4 Gas Heater 12 Volt ELECTRICAL Parts
C - Two Post ELECTRICAL BRACKET Over Heat Switch - $8.95
D - TERMINAL & GROUND Wires for Thermo Switch - $2.00
G - "PRUFREX" Ignition Coil 12 Volt - SOLD USA
L - Grey Metal Mount BRACKET (for body) - $4.95
M - Wiring HARNESS fairly complete with lots of connectors - SOLD USA
Note: Van Late 1967 till 1973, All 12 Volt items.
P - Heater CONTROL KNOB for Dash (No Bulb) - SOLD USA
Q - Brass BRACKET (for Condensor "W") - $2.95
V - TERMINAL PLATE "WECO" with correct mount screws - SOLD USA
W - Bosch CONDENSER 1.297.330.074 (markings"0.5uF""915") - SOLD USA
X - SAFETY SWITCH Unit Made in France (Markings "104140-FT-12V") - SOLD USA
Y - Brass SENSOR with Grey Wire - Over Heat Switch (markings "0+5.5V") - $6.75
Bay Bus Ambulance Fan Covers 68-79
2 - RARE Original PAINT Bay Bus Fan Covers, Electrical Grommets, Body Seals
Note: RARE, Original paint, correct electrical wire grommets & rubber seals!!!
Bay Bus Booster Brake PARTS 1972
C - Clutch Pedal Lever, Body Mount Housing, Bearing, Nut, Catch Mount EX. used - $22.10
K - Booster Pull Rod Handbrake Equalization, Pin, Cable Cross Mount, Pin Rod Arm EX. used- $18.15
O - Brake Lever, Nylon Bushing, Bolt Collar, Rubber Seals, Return Spring, Bolt, Nut, Lock Washer V.G. used - $24.85
R - Booster Push Rod, Adjust Nut, Rod Pin Part: 211.721.295 Stamped: "FSW" EX. (CANADA)
X - Clutch Cable, Pin Clip Part: 211.721.351A Stamped: "VW" "Audi" EX. used - $18.15
Westy SO42/69: LOT#2 "SMALL Stuff"
#01 - Vent Window Latch - SOLD TURKEY
#02 - Door Window Handle - SOLD PORTUGAL
#03 - SO42/44 Cabinet Tightener Knob - SOLD USA
#04 - Black Rubber BUFFER Front Seats (protects seat corners from floor) - $3.85
#05 - Steel LUG NUT for later Bays (with small four studs pattern) - $2.10
#06 - Red & Silver Side Reflector Lens - SOLD FRANCE
#07 - Red & Silver Side Reflector Lens - SOLD FRANCE
#08 - Amber & Silver Front Reflector Lens - SOLD FRANCE
#09 - Black Plastic HORN BUTTON (Clean... NO Chips!) - $4.25
#10 - Coat Hook Knob with two inserts - SOLD TURKEY
#11 - Dash Brake Light Warning Unit - SOLD CANADA
#12 - Trim Edging Cap - SOLD AUSTRALIA
#13 - Side Marker Rubber Electrical Cap Seals - ALL SOLD USA
#14 - Hella Side Marker Base with Bulb Holder - SOLD FRANCE
#15 - SEAT ANCHORS TOP for Passenger 1969-1974 Bus/Westy - $8.10 each
#16 - Horn BUTTON RING Plate Steel Spring Screws - $1.15 each
#17 - Seat Belt Hook Hanger - SOLD TURKEY
#18 - Cabinet Handle - SOLD FRANCE
#19 - Side Marker Grey Base Plate - SOLD FRANCE
#20 - NOS Round Convex Mirror (for Exterior mirror) - SOLD UK
#21 - SO42 MIRROR clips & correct screws EX. used - SOLD UK
#22 - SO42/69 Side Cabinet Clamp Latch - SOLD USA
#23 - Set Mirror Clamps (4) - SOLD TURKEY
#24 - Black Metal Front DASH END PLATES (mounts on end next to door post) - $3.75 each
#25 - SO69 Tie Down Brackets - ALL SOLD UK & CANADA
#26 - Passenger Seat Rubber Wall Bumpers - ALL SOLD FRANCE & TURKEY
#28 - NEW Wiper Mount Clips - ALL SOLD USA
#29 - Black Plastic In Line FUSE HOLDER + Fuse - $12.95
#30/#27 - Main ELECTRICAL HARNESS+Connectors (Steering Column to Floor) - $15.95
A - Water Sprayer Cover Cap - SOLD AUSTRALIA
B - NOS Wiper Blade - SOLD USA
C - BLACK RUBBER Signal Seals (1968-1972 only: lower nose by bumper) ALL SOLD FIJI
D - Door Pull Handle - SOLD PORTUGAL
E - Empi Strap complete (Pin / Washers / Rod) - SOLD USA
F - Sprayer/Wiper Unit SWF 6 terminal (German) Part 141 955 517 - SOLD USA
G - Side Marker with Grey Base Plate - SOLD FRANCE
H - Metal HORN BUTTON Base with correct screws to mount - $5.95
I - Side Light Markers - SOLD FRANCE
J - Metal & Black Plastic HORN BUTTON Base/Contact Plate & Ground Wire (later Bay) - $8.95
K - Black Metal Spray BOTTLE MOUNT with Neck Mount - $8.75
L - Front Dash Vent Plates - SOLD USA
M - Double Carberator Neck - SOLD UK
N - Metal Horn BUTTON BASE with correct screws to mount + correct ground wire - $6.15
O - Metal DASH Pad END PLATE Mounts Three Screw Style - SOLD USA
P - Pop-Top Hold Down Plates - ALL SOLD USA
Q - BLACK RUBBER SIDE REFLECTOR Seals (fair usable) - ALL SOLD CANADA
Bay Bus Steering Part Lot #69
#01 - Ground Wires for Horn Button to Shaft - $0.95 each
#03 - Nylon Horn Insulation Position Plate (for #5) 211.951.547A - SOLD MIK (DENMARK)
#05 - Horn Mount Steel Mount Plate with Ground - SOLD MIK (DENMARK)
#06 - Lock Ring "N12 316 1" 48 x 1.75 - SOLD MIK (DENMARK)
#06 - Steering Shaft Wave Washer for Steering Wheel Nut - SOLD ALFONSO (P.R. USA)
#07 - Horn Base Brass Contact Plate - $3.15
#08 - Steering Wheel Shaft Nuts "90""N" - $7.10 each (1 SOLD MIK DENMARK)
#10 - Black Plastic Horn Button 211.415.671 "VW""H" - SOLD STEVE (USA)
#13 - Shaft Collar Guide 211.415.617B "VW""2" - SOLD ALFONSO (P.R. USA)
#14 - Steering Shaft End Steel /Copper Sprung Springs - $11.15 each
#15 - Shaft Collar Shim Guide (for #13 above) 211.415.559A "KING" - SOLD MIK (DENMARK)
#16 - Thrust Ring 113.415.589 - $5.55
B - Nylon Raised Collar Washers (for "Q") - $1.00 each
C - Steering Column Support Bracket Screw -$1.05
D - Ground Wire Clamp with Correct Screw (for #5 above) - $3.65
D - Steering Column Support Bracket Screw - $1.05
G - Black Plastic Collar - SOLD SCOTT (USA)
K - Column Screw Keys - $2.55 each
M - Nylon Flat Collar Washers (for "Q") - $0.55 each
P - Steel Cog Flat Washers (for "Q") - $0.55 each
Q - Horn Mount Plate Screws - ALL SOLD MIK (DENMARK)
U - Steel Steering Shaft Guide Spacers - $1.00 pair
X - Horn Bolt Mount Screw Spring (for "Q") - $0.95
Y - Steering Column Support Bracket Screws - $2.15 pair
Bay Air Flow Sensor/ Filter 1975-1979
A - KNECHT Air Filter Body (Air Sensor Mounts to) 022 129 607N - SOLD USA
B - Rubber Seal Heater Box Tin 021.119.337 EX. used - SOLD USA
C - Black Plastic Rectangle Pressure Clip Cap 021.119.295 EX. used - SOLD USA
D - Plastic "Y" Junction Tube 022.133.215A (Good) as in NO Cracks or Chips! - $2.95
E - Bosch Decelerator Valve 022 133 551B (Made in Germany) - SOLD CANADA
F -Black Plastic Inspection Plug: 021.119.233A (V.G.) - SOLD USA
G - Black Plastic Flex Neck with correct VW Clamp 022.129.967AC - SOLD USA
J - Intake Manifold Blocks $4.50 each V.G. / Intake Manifold Gasket V.G. $0.30
K - Cloth / Rubber Hose .75" Diameter x 15" - SOLD CANADA
L - "KNECHT" Air Filter Body, Metal Clips (with air intake neck) V.G. - SOLD USA
M - "BOSCH" Air Flow Sensor: 022.906.301B Clean, untested, flap good - SOLD UK
N - Muffler Strap 021.251.521 (Bus 75-79 or Van 80-85) V.G. Solid NO Issues - $15.50
Note: Cleaned, Inspected, Used, German! (other than "O" which is aftermarket)
O - Rubber/Foil Flex Tube: 46 cm x 500 cm EX. used (aftermarket) - SOLD CANADA
P - Oil Breather Box good mount threads (021 115 451A) V.G. used - $12.95
Q - Clear Plastic Tube .5" Diameter x 9.5" - SOLD CANADA
R - Rubber Flex Neck, Metal "C" Clip 021.903.655B V.G. used- $6.95
Bali Yellow Heater Tree: 211.255.881D  (74-75)
1 - Original Distributor Heater Ducting (Heater Tree) with Cable Clip 211.255.881D
Note: Bay Bus 1974-1979 (proper code for Bali Yellow - L62H - 1974-1975)
(Harder to find item... with out a rust out problem or paint total messed up)
Bay Westy Fridge Storage Unit! (76-79)
1 - Bay Westy Side Fridge Storage Unit Very Good + Very Complete 110v + 12v
(Nice with a few issues needing attention as in two corners glue down but NO Cracks on those corners.
One very small chip bottom front corner face. Metal grills would look better with fresh black paint then
a final detailed cleaning would make it an Excellent used original item!!)
Note: Fridge looks to be in good condition, NO leaks or Damage to Inner Fridge Walls
or the exterior refrigerator mechanics! For 1976-1979 3/4 wide Bed Westy will fit a
1968 to 1975 Bay Bus also.
Bay Passenger Seat Green Plaid / Body Swivel Clip
C - Driver Seat BOTTOM: Rails/Front Adjustment Handle/Side Adjust Levers GOOD used - SOLD USA
G - Passenger Black SWIVEL SQUARE Track Base Plate GOOD used - SOLD FRANCE
K - Passenger Seat BACK: Allen Head Mount Bolts/Correct Head Rest Collars WITH Pugs! V.G. used - $42.25
P - Passenger Seat BOTTOM: Rails/Front Adjust Handle/Side Adjust Levers V.G. used - $55.50
V - Passenger Black SWIVEL ROUND Mount,Track Plate,Pull Lever EX. used - SOLD FRANCE
Y - Driver Seat BACK: Mount Bolts/ Head Rest Collars (No Plugs) V.G.used - SOLD USA
Note: From 1979 Bay Westy with Green Plaid Faces and Green Vinyl Edging,
Westy Stove Parts 1974-1975 "CHC"
1 - Stove Control Knobs (Good) Clean Used Shape - $5.95 each (1 SOLD FRANCE)
2 - Stove Burners (Very Good) NO Pin Holes, NO Rust and NOT Bent or Damaged - $19.95 each
1 - Face Plate (Fair-Good) clean & straight some blemishes (Late Westy/Early Vanagon) - $9.95
Bay Bus Part Lot #4 (Shift/Caps/Pads) 69-79
B - "BLAU" Bay Gas Cap, Rubber Seal: 211.201.551G (Good Used) - SOLD FIJI
C - "RES" Right (Passenger) Dog Leg STEP PAD, VW logo, 211.863.736 V.G. used - SOLD WILLIAM (USA)
D - Silver Steel License PLATE BASE MOUNT, NO Rust, Straight, V.G. re-Spray, ready to use - $8.95
G - "HELPHOS" VW Logo Sprayer Bottle FILLER CAP: EXCELLENT used - $5.50
H - Black Plastic Spray Bottle Bracket MOUNT COLLAR: EXCELLENT used - $3.25
J - Shifter Knob with VW Logo, Steel Grey Silver Extension: EXCELLENT Used - SOLD FIJI
M - Factory Aluminium ACCESSORY PLUG-IN for lower dash, correct lock collar+nut MINT - $7.65
P - "BPO" Gas Cap Mount Ring: "VW" "Audi" logo marked: "Oktan min.91ROZ/RON" - $8.95
Q - "HELPHOS" VW Logo Cap, PRESSURE HOSE, "DILL USA" Valve Cover: 113.955.481 - $12.95
S - Sprayer Bottle Top Cap, VW Logo marked: 211.863.127 (V.G.) - SOLD FIJI
V - "BPO" Gas Cap Mount Ring: "VW" "Audi" logo marked: "Oktan min.91ROZ/RON" - (AUSTRALIA)
X - TIRE AIR GAUGE with "10-50 PSI"+"75-325 kPa" marked "Made in USA" V.G. used - $4.25
Y - "RES" Left (Driver) Dog Leg STEP PAD, VW logo, marked: 211.863.735 V.G. used - $14.15
Eberspacher BN Gas Heater: FUEL PARTS
C - COLLAR BELL Fuel Filer (for wing nut) - $4.95 each (1 SOLD USA)
D - Copper FUEL LINE with Steel DOUBLE FEMALE Connector (V.G. used, NO CROSS THREADS) - $9.15
G - NUT Connector BN Steel (with line) Double Female 4" (10.2 cm length) V.G. used USA
H - Orange Connector Line Seals (V.G. used) - ALL SOLD USA
J - BN Gas Line Steel/Brass Connectors Male / Female (for Solenoid to firing Chamber) Good used - $16.95
K - Fuel FILTER CAP TOP & internal Rubber Seal (V.G. used NO CROSS THREADS!) - $15.50 each (1 SOLD USA)
L - Fuel Pump Collar NUT - $0.95
M - NUT Connector BN Steel Double Male Thread Ends (V.G. used) - SOLD USA
P - IN LINE Filter: Steel Mesh with Plastic Seal Ends (V.G. used) - ALL SOLD USA
P - NUT Connector BN Steel Male/Female Ends (V.G. used) - SOLD USA
Q - WING NUT Fuel Filter - $2.50 each (1 SOLD USA)
R - NUT Connector BN Steel (with line) Double Female 1" (2.6 cm length) Good used USA
S - WIRE CLASP CAGE with Threaded Rod for Fuel Filter Cup - $7.55 each (1 - SOLD USA)
SOLD I - Fuel Solenoid Valve, Wiring, Good Threads, Green Seal on Metering Nut (Good used) - SOLD USA
T - Fuel FILTER BOWLS (press fit to "K") - $9.50 each (1 - SOLD USA)
U - Mesh & Alumnium Inside FUEL FILTER (threads in to "K") - $9.95 each (1 SOLD USA)
W - NUT Connector BN Steel (with line) Single Female 5" (10.3 cm length) SOLD USA
X - Complete HARDI 12V FUEL PUMP: "12V5070" "Mod.E57" "DBGM" Made in Germany
Y - NUT Connector BN Brass Double Male Threaded Ends (V.G. used) - SOLD USA
Z - BN Gas Line DOUBLE FEMALE CONNECTER 20" (51 cm length) Good used - SOLD USA
Bay Bus Part Lot CONTROLS
#02 - Red Plastic Dash Pod Heat Control "OFF" "MAX" - $2.10
#03 - Red Plastic Dash Pod Heat Control "HEAT" - $1.10
#04 - Red Plastic Dash Pod Heat Control "DEF." - $1.10
#05 - Exterior Mirror Chrome Collar VW stamp 211.837.517 - $2.15
#06 - Exterior Mirror Chrome Bracket 211.857.541 - $3.85
#07 - Rubber Buffer Back of Seat Rest 271.881.865 1970 up - $3.15
#08 - Blue Rubber Heater Control Cap - ALL SOLD USA & MEXICO
#09 - Blue Rubber Heater Control Cap & Arm - SOLD ROBERTO (MEXICO)
#10 - Complete Heater Control Arm Cluster, PLastic/Nylon Spacers - $22.25
B - Steel Reinforced Gas Peddle with Weld to Floor Plate -$14.50
C - Hand Brake Support Bar 1972 with Racket Tooth, Return Spring, Mounting Bolts, Ground Screw - $19.95
E - Dash Cap Vent Surround Frame chemically stripped - $4.95
F - Dash Pad Washers & Screws - $2.15 Set (Washer/Screw)
G - Steel Floor Collar for Steering Tube 68-73 211.415.621 - $19.95
H - Original Rubber Buffer for Hand Brake - $0.95
I - Eye Bolt "N 16 076 1" AM 8x45 Hand Brake Rod - SOLD ROBERTO (MEXICO)
J - Black Rubber Handle 211.711.421 rip short end fixable - SOLD LEDESMA (USA)
J - Racket Bar with Hand Pin for Hand Brake 211.711.399 - SOLD ROBERTO (MEXICO)
K - Emergency Hand Brake, Pivot Pin, Spring Clips, Floor Mount Housing Metal Clip 211.711.305C 1968-July 71 - $22.95
M - Support for Instrument Panel (Dash) LHD 211.415.551 August 1968 and Earlier - $14.15
N - Dash Cap Vent Surround Frame chemically stripped - $4.95
O - Steer Column Support Plate Bracket 211.415.601F 1968 - August 1969 - $22.15
Q - Dash Cap Vent Surround Frame - $3.95
SOLD R - Shifter, Knob, Boot, Steel, Housing, Spring, Ball Pin & Spring 211.711.121E - SOLD ROBERTO (MEXICO)
U - Eye Bolt Pin for "I" above - SOLD ROBERTO (MEXICO)
X - Gas Peddle Pivot Arm, Mount, Pinch Washer, Metal Floor Clip 211.721.631A 68-73 - $18.85
Bay Bus Sliding Door Cables: 211.843.719/951
1 - Steel Pull Rod "Remote Control" Nut Adjustment, Brass Tread Collar 211.843.719C - $18.15
1 - Steel Braided Cable "Remote Control' Casing, Nylon Guides, Foam Buffers, Adjustment Hardware 211.843.951
August 1971 till 1973 Chassis Number 211 2000 001 later Bay Bus
Westy Interior Light 1968-1972:
Westy Light Hella Made in Germany
1 - Metal Base with Wiring & Bulb Holders (Excellent) - $8.95
Hella White Lens: chipped & cracked BUT... usable! - SOLD CANADA
Grey Rubber Seal great shape - SOLD UK
Good Bulbs - ALL SOLD CANADA
Westy Electrical Exterior HOUSING: 1970-72
1 - Exterior Electrical Housing / Plug-in / usable & restorable / missing flap cover / original Decal!! - $8.50
1 - Metal Backing Plate Housing / Clean & Straight - SOLD USA
1 - Interior Electrical Face Plate/Reset Breaker/Brown Plug In/Mount Screws/Foam Seal - SOLD USA
Note: All from 1972, original paint / original foil decal / original foam seals!
Bay Bus Latch, Lens, Small Hardware
C - Steed "88" Bolts for "J" anchor plates - $2.55 each
D - Amber Inner Lens Front Signal "L2" Left Side - $3.75
G - BUM Sliding Door Rear Anchor Mount Plate 211.843.636B ( fits "H") - $8.85
H - Nylon & Rubber Buffer Sliding Door Anchor (for "G") - $2.85
J - BOMORO Sliding Door Post Anchors 211.843.656 - $4.10 each
K - Steel Allen Bolts "8.8" for "G,M,Z" mount anchors - $3.05 each
M - TAGA Steel Rear Cargo Lid Anchor Plate (for "T" ) 211.829.221E - $5.25
P - Heater Tree Control Arm Black Plastic End Knob - $3.85
S - Heater Tree Heat Control Arm Bar Rubber Buffer - $1.10
T - Steel Two Screw Rubber Buffer Mount Base Plate (for "M") - $1.25
V - Front Seat Head Rest Collar - $$2.95
X - Black Rubber Seat Back Buffers/Screws/Washers - $6.15 each (1 - SOLD USA)
Y - Blau 35mm Cap "Ohne Luftung" - $12.95
Z - BRM Latch Lock Anchor Mount/Rubber Buffers 1977 (211.843.742D) "1470" "1" - $19.95
Bay Westy Pop-Top Edging: 231.069.709
C - Ivory Trim Pop Top from 1968-73 Westy 66 inches - $22.25
K - Front Ivory Trim Pop Top Edge from 1968-73 Westy 40+ inches - $11.85
R - Ivory Trim pop Top from 1968-73 Westy 40 inches - $11.15
Bay Bus Dash Directional Vents: 211.259.473 (68-79)
4 - Original "VW" logo Black Plastic Bay Bus Dash Directional Vents EX. used - $19.95 Each
(Round Body Duct: 211.259.473 / Duct Lever: 211.259.481)
1973 Bay Bus Steering Box Unit: 211.415.049H (73-79)
1 - Original Used Steering Box/Drop Arm/Frame Plate/Frame Bolts 211.415.049H
Bay Bus Walk-through Mat Caps: 241.863.7871 (74-79)
A - Original Paint Excellent Used!
B - Original Paint Excellent used!
BA6 & BN4 Gas Heater Parts #14
O - "SWF" Circuit Breaker Switch 1970-1974 Type 4 BN4 Heater - $32.25
(Markings: "VW" "GERMANY" "12V 1A" "S600.979" "411.963.209B")
C - "BERU" Gas Heater Glow Plug BA6 Spark Plug - SOLD STEVEN (CANADA)
(Marked: "VW" "Audi" "GZE 22" "11V" "KX" "BERU" "Made in Ireland")
R - "Eberspacher" Thermo-switch(211.963.203) & Stainless Body Clip(211.261.119) - $39.95
(Markings: "VW" "Audi" "SATTLER TE 145u" "20.1305.35.0000")
Bay SPRAYER Reserve 211.955.453
A - Front Door Vent WITH ALL the post clips Pressing #1 211.857.129 - SOLD USA
B - Glove Box Latch with Collar Nut 113 857 131A - SOLD MALAYSIA
C - Dash Glove Box Lid, "ALL" correct Screws & Clips 221.857.123A - SOLD MALAYSIA
E - Filler Bottle Cap Cover VW logos part 211 863 127 - SOLD FRANCE
F - SWF Rear Tail Lights cracked, some missing on clear other wise usable - SOLD CANADA
G - Front Door Vent WITH ALL the post clips Pressing #2 211.857.129 - SOLD USA
H - "HELLA" BOTTLES Both German: NO Cracks Very Clean part 211.955.453 - $15.95 each
H - Pressure Feed Black Rubber Line, Screw Collar (Excellent) - SOLD UK
I - Black Plastic Collar (for mounting & secure spray bottle to metal bracket "Q") - SOLD UK
J - "HELPHOS" Black Plastic with VW Logo Bottle CAP EX. used - $6.95
K - White Plastic Mount COLLAR (for use with "H") EX. used - $2.95
M - Filler Bottle Cap Cover VW logo part 211 863 127 - SOLD UK
N - "HELPHOS" Air Pressure Feed Spray Bottle Line 113 955 581 - SOLD UK
P - SWF Rear Tail Light Lens small chip missing, scratches face, good for driver - SOLD CANADA
Q - Black Metal Mount Bracket (spray bottle body to body) - SOLD UK
TheFonz
TheFonz is offline
PostPosted: Sat May 10, 2014 4:55 pm    Post subject: Reply with quote
This is amazing but I can help but think of-
https://www.youtube.com/watch?v=5XcKBmdfpWs
-73' Westfalia
-76' Westfalia
-72' Westfalia (parts bus)
-76' Westfalia (project for my dad as a thanks)
http://www.thesamba.com/vw/forum/viewtopic.php?t=452223&highlight=
^Check out my restoration thread
Tcash
Tcash is offline
PostPosted: Sun Apr 05, 2015 6:43 pm    Post subject: Headlight switches Reply with quote
Mera" 8 PRONG Switches: 211.941.531.E
P - Headlight Switch Unit Marked: "VW""MERA""58""58R""58L""58b""30""X"
T - Headlight Switch Unit Marked:"VW""MERA""58""58R""58L""58b""30""X"
B - Headlight Switch Unit Marked:"VW""MERA""58""58R""58L""58b""30""X" -
"KLO" 6 PRONG Switch 211.941.531.C
O - HeadLight Switch Unit Marked: "VW""Audi""W-Germany""02 8464 76""123F""30""58""56""58b""X" -
"Mera" 6 PRONG Switches: 211.945.531.B
Y - Headlight Switch Unit Marked: "VW"'MERA"'30""56""58""58b""X" -
I - Headlight Switch Unit Marked: "VW""MERA""30""56""58""58b""X" -
A - Headlight Switch Unit Marked: "VW""MERA""30""56""58""58b""X" –
Greg Lindquist
Greg Lindquist is offline
PostPosted: Fri May 13, 2016 5:14 pm    Post subject: Re: Greg Lindquist Parts Pictorial (pic heavy) Reply with quote
Premission for photograph?
Stocknazi
Stocknazi is offline
PostPosted: Tue Dec 06, 2016 9:13 am    Post subject: Re: Greg Lindquist Parts Pictorial (pic heavy) Reply with quote
Tcash wrote:
Looking for some information on the these Westfalia GHE short rubber buffers (marked I in the pics).
Can someone please post where these were located in the bus, and what year/s Westy they were used?
WANTED:
Thomas Jefferson
Tcash
Tcash is offline
PostPosted: Tue Jun 06, 2017 10:29 am    Post subject: Re: Greg Lindquist Parts Pictorial (pic heavy) Reply with quote
Regulator Relay
B - "SWF" 5 Post Relay, Made in Germany 12V bis 100W "R 200.957" 411.941.583C (69-73?) - $25.25
R - "SWF" 4 Post Relay, Made in Germany 12V bis 100W "R 200.648" 311.941.583A (68-69) - $14.95
T - "BOSCH" 3 Post Regulator, Made in Brasil AD1/14V "908" 0190 601 006 (72-79) - $35.85
P - "BOSCH" 3 Post Regulator, Made in Germany AND1/14V "323" 0190 600 009 021.903.803 (72-79) - $32.50
Bus "HELLA" Defrost Switch: 211.959.621A
Bus "HELLA" Defrost Switch: 211.959.621A Price: $19.95 (Item: T)
"T" YELLOW - "HELLA" Defrost Switch Unit Made in Germany 211.959.621A Marked:"61/35-1""31""15""K""VW" - $19.95
SOLD "P" YELLOW - "HELLA" Defrost Switch German 211.959.621A Marked:"61/35-1""31""15""K""VW" - SOLD GAB. (USA)
SOLD "B" YELLOW - "HELLA" Defrost Switch 211.959.621A Marked: "61/35-1" "31" "15""K" "VW" - SOLD STEVE (USA)
SOLD "O" PINK - "HELLA" Rubber Switch Knob NON-Graphic Style - SOLD SCOTT (USA)
Bay Bus Air Filter Parts
A - "KNECHT" Filter Housing "VW" "Audi" Logo 021.129.620 NO Issuses!!!! V.G. Used - $19.50
M - "OVAL" Stainless Air Filter Neck Clamp, Correct Bolt (for item "B") EX. Used - $12.95
SOLD H - Air Filter Housing with Long Neck Air Draw, NO Cracks, NO Chips V.G. Used - SOLD BRYAN (USA)
SOLD B - Air Filter Bottom Carb Pancake Engine, ALL Original Clips, NO Cracks, NO Issuses V.G. Used - SOLD JEFF (USA)
SOLD G - Steel Filter Housing Bracket for Block, Rubber Buffers "VW" Logo 021.129.545B EX. Used - SOLD JEFF (USA)
SOLD O - Steel Filter Housing Bracket for Block, Rubber Buffers "VW" Logo 021.129.545B EX. Used - SOLD JEFF (USA)
Interior/Electrical/Duct
N - Manifold Pancake Engine, Carb Block Gasket, Nuts, Washers, Lock Washers VW Logo Stamp"2" - $18.85
I - Oil Fill Neck Pancake Engine, Good Threads, Straight & Solid - $14.50
C - Oil Cooler Bracket 021.117.171A/181, Correct Screws, Washers, Straight - $9.95
E - Cloth & Rubber Hose .75" Inner Diameter 14" Over All Length, NO Rot!!! - $8.85
Y - Stainless Clamps: 65mm (USA), 54mm (VW), 47mm (VW) Diameters - $8.00 Set Three
O - Under Front CAB FLOOR HEATER DUCT Elbow 14" Length along Seam V.G. Used HARD to LOCATE!!! - $25.15
B - Under Front CAB FLOOR HEATER DUCT elbow 14" Length along Seam V.G. Used HARD to LOCATE!!!- $22.50
A - SWF Grey Plastic Rear Tail Light Housing Dust Cover, Rubber Seal, All Clips 211.945.285 Good Used - $9.95
V - SWF Metal Three Bulb Housing Base 211.945.231 (72-79) Straight, All Bulb & Ground Mounts Ex. Used - $8.25
G - Steering Shaft End Copper Spring (Under Steering Wheel) - $8.15 each
T - VW Logo Black Plastic Horn Buttons 211.415.671 EX. Used, NO Clips or Cracks - $15.85 each
X - Steel Horn Button Pressure Clips (For above Black Horn Buttons) Ex. Used - $8.95 Set of Three
O - Steel Front Door Stop 6 5/8" Length, Correct Steel Door Pin Ex. Used - $9.95
P - "REPA" German "VW" 70 Complete Lap Seat Belt, 8.8 Bolt/Washers 111.857.709C/B EX. Used NO Issues! - $22.25
U - "REPA" 8.8 Steel Seat Belt Body Bolt & Washer Anchors EX. Used - $8.25 Pair
K - Ivory Body Plugs 211.857.785ANOD & Pressure Plug 211.857.785MS - $13.50 Set of Five
J - Dust Plugs, Rubber Dust Cover 221.809.443 & Coat Hanger Mount 221.857.629A, Z Bed Stay - $14.95 Set of Seven
H - Assorted Screws & Clips for Interior - $9.95 Lot
R - Winder Buffer Backing Spring, Winder Buffers 111.837.595A, Assorted Winder Screws - $14.50 Set of Seven
M - Metal Core Front Window Winders, Black Plastic Covers/Knobs Tight & Good Splines EX. Used - $17.95 Each
(Chrome Insert: 111.937.579B, Black: 111.837.579B/803.837.581B)
F - Black Plastic Door Pull Surround Backings 111.837.239B - $10.55 Pair
Q - Black Plastic Door Pull Inserts 311.837.247 - $8.00 Pair
Z - Clear Late Bay Front Signal Lens Marked: "LE" "CHL" 74-79 EX. Used - $8.95
L - Late Bay Front Signal Rubber Seals 74-79 Good Used - $8.00 Pair
S - Pair (Left & Right) 68-73 Interior Amber Front Signal Lens Marked: MBL po 700 L/R Good Used - $10.00 Pair
SOLD W - Back Plastic Door Pull Surround 211.837.097 with Assorted Mounting Screws - ALL SOLD JOSH (USA)
Left Side Electrical BLACK Tags:
J - Ivory Cabinet Trim "T" Channel 13" Length - $8.00
W - Green/Black Electrical Harness, "WECO" 406 VW Connector - $9.00
Y - White/Black Electrical Harness, "WECO" 406 VW Connector - $9.00
O - Green/Black & Grey & White/Black Electrical Harness, "WECO" 406 VW Connector - $12.00 3 Wire Set
C - Grey Electrical Harness Two Terminal to One Terminal - $8.00
Z - Brown Tail Light Harness, 2 Correct Rubber Seals - $8.00
P - Head Light Connection Harness, Ground Screw, Bucket Rubber Seal & Wire Protector (Passenger Side) - $14.95
Q - Head Light Connector Harness,Ground Screw, Bucket Rubber Seal & Wire Protector (Driver Side) - $12.95
G - Head Light Connector Harness, Ground Screw, Bucket Rubber Seal & Wire Protector (Driver Side)- $13.95
M - Head Light Connector Harness, Ground Screw, Wire Protector (Passenger Side) - $12.95
E - Head Light Connector Harness, Wire Protector (Passenger Side) - $9.95
T - "BOSCH" BrazilVOLTAGE REGULATOR Alternator 72-79 Marked "908" "663", Harness, Bracket, NOSish Tested Good. - $39.95
R - Interior Ceiling Light & Switch, Chipped Border but Mechanical EX. used - $8.00
Westfalia Ceiling Channel
Y - Bay Westy Aluminium Ceiling Channel 231.069.022 (8/67-4/72) 180 mm Good Used (Last One Currently!) - $9.95
SOLD B - Bay Westy Aluminium Ceiling Channel 231.069.022 (8/67-4/72) 180 mm V.G. Used - SOLD (USA)
SOLD D - Bay Westy Aluminium Ceiling Channel 231.069.022 (8/67-4/72) 180 mm Good Used - SOLD (USA)
SOLD Z - Bay Westy Aluminium Ceiling Channel 231.069.022 (8/67-4/72) 180 mm EX. Used - SOLD (USA)
SOLD S - Bay Westy Aluminium Ceiling Channel 231.069.022 (8/67-4/72) 180 mm EX. Used - SOLD (USA
SOLD M - Bay Westy Aluminium Ceiling Channel 231.069.022 (8/67-4/72) 180 mm V.G. Used - SOLD (UK)
SOLD X - Bay Westy Aluminium Ceiling Channel 231.069.022 (8/67-4/72) 180 mm Good Used - SOLD (UK)
SOLD J - Bay Westy Aluminium Ceiling Channel 231.069.022 (8/67-4/72) 180 mm Good Used - SOLD (UK)
SOLD K - Bay Westy Aluminium Ceiling Channel 231.069.022 (8/67-4/72) 180 mm Good Used - SOLD (UK)
Westfalia upholstery tag
H & I - Bed Product Tag for Z Base Board "Westfalia-Werke K.G. (74-79) 3.75" x 2.5" Original
68-73 Westy Pop Top Support
SUPPORT BARS:
D - Short Support Bar (42cm/16.5") Passenger/Right 231.069.722B Slight Bend, Usable (heat & straighten) - $13.85
R - Short Support Bar (42cm/16.5") Driver/Left (1972) 231.069.721B Slight Bend, Usable (heat & straighten) - $13.85
K - Long Support Bar (55cm/21.75") Driver/Left (1972) 231.069.721B Straight, Clean, Mint Used - $16.85
SOLD O - Short Support Bar (42cm/16.5") Left or Right (8/72 Up) Straight, Clean, Mint Used - SOLD JENNIFER (USA)
SOLD J - Long Support Bar (55cm/21.75") Pass./Right (1972) 231.069.722B Straight,Clean,Mint Used - SOLD RUSTON (USA)
SOLD C - Long Support Bar (55cm/21.75") Left or Right (8/72 up) Straight, Clean, Mint Used - SOLD JENNIFER (USA)
HARDWARE:
B - Steel Folding Arm Return Springs QTY 3 - $11.15 each
Q - Aluminium Support Foot Bracket One Hole (Small) QTY 3 - $9.95 group
A - Aluminium Support Foot Bracket Two Hole (Large) QTY 3 - $12.25 group
L - Original Mounting Bolt, Washers, Lock Nut (Sample, mounting Arms to Fiberglas Pop Top) QTY 4 - $6.95 Set
M - Foot Support Pins with Pinch Washers QTY 8 - $9.95 group
Bay Bus Dash Pod Gauges 70-78
W - Pod, Speedo KPH, Gas Gauge, Block & Glass, Bulbs Unit 1/78 - $165.50 (39,818 Km)
"O Black Tag" - Grey Face Speedo MPH 3/74 - $45.95 (84,771 Mi.)
"O White Tag" - Grey Face Speedo MPH 3/74 - $45.95 (16,030 Mi.)
C - Grey Face Speedo MPH 12/73 - $55.50 (38,980 Mi.)
P - Gas Gauge Sensor 5/1972 - $38.85
U - Gas Face Plate 4/1972 - $25.85
N - Gas Face Plate 5/72 - $25.25
K - Gas Gauge Sensor 4/72 - $38.85
S - VDO Backing Plate, Green Plastic Lens 3/72 Straight & Clean - $9.95
Q - VDO Backing Plate, Green Plastic Lens 12/73 Straight & Clean - $8.95
M - VDO Backing Plate, Green Plastic Lens 3/74 Straight & Clean - $8.00
H - Later Block Plates Dash Pod (Sprayed Silver) V.G. Used- $8.75 Each
T - Later Gas Gauge Face Plate (Sprayed Silver) V.G. Used - $8.00
G - Plastic Instrument Pod with Glass 3/75 (No Gauges) NO Cracks V.G. - $28.85
Y - Plastic Instrument Pod with Glass 12/73 (No Gauges) NO Cracks V.G. - $38.95
E - Gas Face Plate 3/73 - $19.95
A - Gas Gauge Sensor 3/73 - $36.50
J - Gas Gauge Sensor 12/73 - $36.50
Z - Gas Face Plate 12/73 - $19.95
SOLD B - Pod, Speedo MPH, Gas, Block & Glass, 10/70 - (35,572 Mi.) SOLD ART (SINGAPORE)
SOLD D - Dash Pod Rubber Seal for Dash Face to Pod Backside - SOLD ART (SINGAPORE)
SOLD V - Bulb Bracket & 15 Pod Mount Screws, Brake Warning Light - SOLD ART (SINGAPORE)
SOLD F - Gas Face Plate 11/77 - SOLD TONY PARK, AUSTIN, TX., USA FEB. 20TH PP
SOLD L - Gas Gauge Sensor 11/77 - SOLD TONY PARK, AUSTIN, TX., USA FEB. 20TH PP
notchboy
notchboy is offline
PostPosted: Tue Jun 06, 2017 11:08 am    Post subject: Re: Greg Lindquist Parts Pictorial (pic heavy) Reply with quote
Dude thats got to be the longest post ever Laughing I almost forgot that Greg has everything.
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
alman72
alman72 is offline
PostPosted: Tue Jun 06, 2017 2:04 pm    Post subject: Re: Greg Lindquist Parts Pictorial (pic heavy) Reply with quote
it is indeed huge. how long until someone quotes it?
hazetguy
hazetguy is offline
PostPosted: Tue Jun 06, 2017 6:04 pm    Post subject: Re: Greg Lindquist Parts Pictorial (pic heavy) Reply with quote
edited
PostPosted: Tue Jun 06, 2017 6:13 pm    Post subject: Re: Greg Lindquist Parts Pictorial (pic heavy) Reply with quote
Yes, it's long.
Please don't quote it.
TCash - It would be more useful to split it up into multiple posts as you gather more information.
New set of info - new post.
Greg has given permission.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Tue Jun 06, 2017 6:15 pm    Post subject: Re: Greg Lindquist Parts Pictorial (pic heavy) Reply with quote
well, here we go again Laughing
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Tcash
Tcash is offline
PostPosted: Tue Jun 06, 2017 7:33 pm    Post subject: Re: Greg Lindquist Parts Pictorial (pic heavy) Reply with quote
I am going to Lock it, to keep it as a searchable document only.
Thank you
Tcash
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Bay Window Bus All times are Mountain Standard Time/Pacific Daylight Savings Time
