CV Joint - Orientation of Concave Washer
GJ780662a
GJ780662a is offline
PostPosted: Tue May 27, 2014 12:43 pm    Post subject: CV Joint - Orientation of Concave Washer Reply with quote
Hi folks,
Which way is the concave washer installed?
Dwayne1m
Dwayne1m is offline
PostPosted: Tue May 27, 2014 2:11 pm    Post subject: Reply with quote
Boot and washer goes on axle before CV joint. Dished side of washer towards CV joint. make sure you put the CV joint on the correct way or you'll be taking it off again. If you are not sure which side goes on first, line it up/test fit with the boot. One side of the CV joint is larger then the other side.
volksworld
volksworld is offline
PostPosted: Wed May 28, 2014 1:00 pm    Post subject: Reply with quote
its designed to put pressure against the joint...once you put on the c-clip,you need to put a socket over it and smack it with a hammer to compress the washer and let the c-clip drop fully into its slot
peteandvanessa
peteandvanessa is offline
PostPosted: Wed May 28, 2014 1:49 pm    Post subject: Reply with quote
And if you have dis-assembled the CV joint and can't remember the orientation, then this might help you from putting it together the wrong way round (ask me how I know Embarassed )
Details on the raised shoulder:
My 1974 Standard Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=568220&postdays=0&postorder=asc&start=0
My Son's 1971 Bay Window Westie Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=7295189#7295189
