BarnDoor Spindles.
Peter - Belgium
Peter - Belgium is offline
PostPosted: Sun Jan 04, 2004 11:56 am    Post subject: BarnDoor Spindles. Reply with quote
Can someone post or send me some pictures of the spindles of a brandoor bus?
A friend asked me if I could lower his spindles as well, but I have only worked on the recent type so I would like to see some pictures of the barndoor spindles to check if I can do them as well.
Thanks,
Peter
rizzag
Now Wut?
rizzag is offline
PostPosted: Sun Jan 04, 2004 11:59 am    Post subject: Reply with quote
if i remember correctly barndoor spindles are in the late style lowered position to begin with.
flossin, tossin, dippin, and trippin
Peter - Belgium
PostPosted: Sun Jan 04, 2004 12:06 pm    Post subject: BD spindles Reply with quote
So they are "flipped" already??
This would mean that I can not lower them the same way as it is done with the 60s spindles??
How are they lowered then? Is it at all possible?
Still would like to see some pics!!
MoneyMike
MoneyMike is offline
PostPosted: Sun Jan 04, 2004 8:47 pm    Post subject: Reply with quote
Use later spindles!
krusher
krusher is offline
PostPosted: Mon Jan 05, 2004 1:59 am    Post subject: Reply with quote
i tried e-mailing a couple of the companys that do dropped spindles to see it the could do BD spindles but I never got a reply Crying or Very sad
Anyway I'm going stock height now Razz
(06:31:07) RoachGhia: "i drink dick way too fast"
NAES
NAES is offline
PostPosted: Tue Jan 06, 2004 7:49 am    Post subject: Reply with quote
If I remember correctly, MoneyMike is right about using early non-Barndoor spindles. I do think however that the trailing arms must be used as well.
Barndoor Mafia
Box On Wheels
SBS #00
Barndoor Mafia
Il Capo
Barndoor Mafia is offline
PostPosted: Tue Jan 06, 2004 9:41 pm    Post subject: Reply with quote
LowriderMike MoneyMike wrote:
Use later spindles!
I second the motion!!!! Money Mike is right and Ferrett.....don't flair it!!!
Laydo
Hebster52
Hebster52 is offline
PostPosted: Fri Jan 09, 2004 12:47 am    Post subject: Reply with quote
If he wants to lower his Barndoor, use T-1 spindels... I know a couple of guys who did that. They are just about bolt-on. If I remember this right you just need to machine a pair of new bushings for the linkpins. (They are a bit thinner on T-1). They lower about 2,5 inches.
The distance between the torsionarms on Barn vs. later split buses are different aren't they... (correct me if I'm wrong)
Barndoor front axle:
Later Splitbus axle:
I'm going to do the switch the other way... Wink
~Kris~
"The Hebster52" my Hebmuller replica build
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
