My Mean Green Camping Machine ('69 Camper)
FireBrush
FireBrush is offline
PostPosted: Wed Jun 04, 2014 10:52 am    Post subject: My Mean Green Camping Machine ('69 Camper) Reply with quote
Just introducing the newest member of our family. She will be fun to work on.
1969 Camper Van - 1600 SP
aeromech
aeromech is offline
PostPosted: Wed Jun 04, 2014 10:57 am    Post subject: Reply with quote
Nice looking bus and welcome to the samba. There are a couple things about your engine that need fixing though.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
FireBrush
PostPosted: Wed Jun 04, 2014 10:59 am    Post subject: Reply with quote
I am aware of the fuel filter and lines as a priority.
What else?
Joey
Joey is offline
Very nice!
You may want to move your fuel filter to under the bus or at least put it before the pump not after it.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
aeromech
aeromech is offline
PostPosted: Wed Jun 04, 2014 11:13 am    Post subject: Reply with quote
What else?
Well if it was me I'd replace the engine driven fuel pump and remove the aftermarket electric pump. I'd relocate the filter to above the transmission for fire safety and install a new one. I'd turn around the coil just cause it's upside down from how it should be mounted. I'd replace that crappy air filter with an original oil bath filter. Probably replace the crankshaft pulley with a degreed one. Your distributor isn't clocked correctly but it can still run well like that. Check your timing though. Oh, and as you said replace the fuel lines.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
FireBrush
PostPosted: Wed Jun 04, 2014 12:05 pm    Post subject: Reply with quote
Aeromech,
Thanks for the tips. Very Happy
I have a shifting problem that I cannot for the life of me find a similar post in the forums. (I have read probably 50-100 searched posts). Shifting 1-4 is great but just a little bit sloppy. If I go into reverse it is very, very hard to get back into a forward gear.
So I am starting at the shifter and working back. I noticed a bunch of washers under the reverse stop plate and I do not see them in the manual??? I will be getting a shift rod bushing kit and hope this works. The round disc above the ball on the shifter has a flat wear spot on it. Will this be an issue?
Jim Bear
Jim Bear is offline
PostPosted: Wed Jun 04, 2014 12:29 pm    Post subject: nice ride Reply with quote
That right there is a really nice looking bus. I really like the interior. Fun and ood roads...
"You're either on the bus, or you're off the bus." ~kk
'85 Vanagon Westy - George In the Stable 2020-?/'74 Weekender - Ophelia In the Stable 2007- ?/'69 Beetle Convertible - SOLD 2017-2020/'67 Beetle - September SOLD 2013-2016 Sad /'67 SO42 Westy - Sage SOLD 1996-2001 Sad Sad/'69 Transporter - Baby Blue SOLD 1995-1995/'72 Westy - Nelly - SOLD 1990-1995--STOP FRACKING
aeromech
aeromech is offline
PostPosted: Wed Jun 04, 2014 12:32 pm    Post subject: Reply with quote
Could be. There shouldn't be any washers under the stop plate. Be sure you have it oriented correctly.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Tcash
Tcash is offline
PostPosted: Wed Jun 04, 2014 12:51 pm    Post subject: Reply with quote
I noticed a bunch of washers under the reverse stop plate.
Aeromech, I like how you changed the font. It states the question without needing to read the complete quote.
The washers may have been someones idea of a short shifter. Or they where addressing a problem. At any rate as Auromech stated they do not belong there.
Good luck
Shifter Parts ID
aeromech
aeromech is offline
PostPosted: Wed Jun 04, 2014 12:54 pm    Post subject: Reply with quote
You can call me Gary Mr. Cash
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Skoolieman
Skoolieman is offline
PostPosted: Wed Jun 04, 2014 5:32 pm    Post subject: Reply with quote
My 69 2ws modified by the po to use a split bus shifter bushing setup due to a broken guide pin and therefore had s8me heavy washers under it like you describe got any pictures of your setup?
'69 Westfalia Camper~Cassidy
1600dp with H30/31 carb 009 distributor and alternator conversion
FireBrush
PostPosted: Thu Jun 05, 2014 8:00 am    Post subject: Reply with quote
I took off the front linkage last night and the guide pin looks good.
Here are some photos of the wear spots I mentioned earlier.
On the Shift Rod
On the Reverse Stop Plate
Here are the extra washers as I found them.
Everything else looks good.
aeromech
aeromech is offline
PostPosted: Thu Jun 05, 2014 8:08 am    Post subject: Reply with quote
Did you look the reverse stop plate over well for cracks. I've found them broken before. I'd say lube everything up and put it back together without those extra washers and see how well it works.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Das Awesome
Das Awesome is offline
PostPosted: Sat Aug 30, 2014 4:45 pm    Post subject: Reply with quote
Wow, that's a nice bus! I hope the Hulk didn't drive that ! Very Happy Nice find and congrats!
"Just because you can, doesn't mean you should"
"Then why did I buy a rustbucket?"
Tcash
Tcash is offline
PostPosted: Sat Aug 30, 2014 5:29 pm    Post subject: Reply with quote
Shifter Parts ID
Lionhart94010
Lionhart94010 is offline
PostPosted: Sat Aug 30, 2014 5:48 pm    Post subject: Reply with quote
RE your engine-
FYI, you are missing a number of clamps, seals and tin pieces, they all need to be there for the bus to stay cool, there are a number of samba post that have pictures of all the tin and seals and clamps that where on your engine when it left the factory
The ones missing I can see from your (1) engine picture are;
Heater tube clamps(top and bottom) and rubber rings on the bottoms-
Heat riser connector and seal from front tin to cylinder tin, as well as the seal that goes in it-
Oil tower drain tube bottom seal-
Does not look like your have the air flaps installed(Quite important piece for cooling)-
Missing Spark plug wire holders?
Pulley nut cover Tin-
PS, you have the wrong exhaust system on it(from a Bug) that may allow Carbon Monoxide to get sucked in the heating system due to the missing tin… and aerodynamics of the bus; bus exhaust exits on the side, so exhaust is left behind with turbulent air flowing down the sides of the bus…
Lot of things to be wary about that previous owners may have done to your bus, I do not see seatbelts in the back, and the modifications that they have done to the interior may not be so great in an accident(be weary of loosely installed furniture or sharp corners/hard objects near passengers ;0)
If you have not already; I highly recommend you check out Richard Atwells Baywindow Guide to Upgrades, you will not regret reading it or anything else he has written about T2 Buses, it will save you lots of time, money and frustration :0)
http://www.ratwell.com/technical/EssentialUpgrades.html
Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm
