Lotterman's Hebmuller body number is identified !
peter schepens
peter schepens is offline
PostPosted: Mon May 11, 2020 12:22 am    Post subject: Lotterman's Hebmuller body number is identified ! Reply with quote
Hello folks,
Since long time, this well known green metalic heb from Markus Lottermann was spinning in my mind as an early bird but with a given body number 103 it dit not match the build details.
After a long search, and investigation and with the help of other enthusiasts, the Lottermann’s Hebmüller, since long time known as Heb 14-00103 is identified. Markus was very glad to find out the real Body number on his type 14a. The car’s former nr 14-00103 was deducted by Heinz Willy Lottermann on the first digits from the Chassis numbers 1-103322. The info was found on a copy from the Wagenbegleitkarte that was provided by a collector who was not aware it was not for his car. So the identification is 100% correct. The car was built 15 July 1949, it was shipped on 16th of July to WEBER dealership in Berlin, and has Body number 14-00008. The original color was elfenbein or Ivory. It is unclear if that was a complete elfenbein car or just a black one with elfenbein sides.. In our research, we found out that another Heb was indeed completely painted in elfenbein. So when the car was restored years ago, Heinz Willy Lottermann used what was available. The heater channels, the front part was changed and replaced by the wrong parts. The Heb should have a flat front panel and a small fuel tank. The car however will be kept in the same condition but made driveable for the German TÜV one day. Do not bother to ask, the car is not for sale as to honor Heinz Willy Lottermann. Check out all new pictures
https://www.hebmueller-registry.com/models-reader-...FR7jWwIuV8
And before you ask around.. The car is Not for sale... Not possible as Markus will keep it in respect from his father, Heinz Willy Lottermann, founder of BAD CAMBERG meeting.
Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
Hebmuller info wanted for http://www.hebmueller-registry.com/home.html
