Engine case material
Robert H
Robert H is offline
PostPosted: Wed Jun 18, 2014 6:36 am    Post subject: Engine case material Reply with quote
Can someone clear somethingup for me? I have heard that VW-made engine cases on earlier models were magnesium, and later changed to aluminum. I have also heard that all VW-made engine cases were mag. Ane what about after-market cases? Aluminum, mag??
*Darren
*Darren is offline
PostPosted: Wed Jun 18, 2014 7:46 am    Post subject: Reply with quote
actually cases were aluminum until early 1951. Then went electron (magnesium) and eventually again aluminum.
Aussiebug
Aussiebug is offline
PostPosted: Thu Jun 19, 2014 5:36 pm    Post subject: Reply with quote
Errr not quite.
The "magnesium" cases had about 1% aluminium in the alloy.
The later so called "aluminium" cases were still mostly magnesium, but the aluminium content was increased to about 4%. This made the metal more malleable (machinable) and it doesn't go brittle with age the way the older cases do (with the lower aluminium content in the alloy). So the later "aluminium" cases (with AS21 or AS41 cast into the sides) make a much better case for rebuilding.
Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Fri Jun 20, 2014 9:31 pm    Post subject: Reply with quote
Weren't the Type 4 engine blocks cast with a high-aluminum-content alloy?
