bladerunner80 Samba Member
Joined: February 13, 2011 Posts: 255 Location: Fife, WA
Posted: Fri Jul 18, 2014 2:14 pm Post subject: Nice trick to popping out those stubborn door hinge pins |
I've been perusing samba for a while researching everyone's different methods for removing door pins, seems that this up there as one of the most hated projects when it comes to bug repair work. I almost pulled the trigger on renting the door pin tool, but first I tried making the c-clamp tool. Only problem with that was when I really torqued down on it, I could see the clamp flex and bow, so I backed off of it. I tried using an airhammer, but it barely made the pin budge, plus I was worried I was going to piss off all my neighbors (I live in suburbia hell).
Then I did some google searching and came across this video of someone using a bench vise to pop the pin out:
This actually worked really well. It required a little bit of setup and a lot of man handling the doors, but once I got everything level and into position, I slowly cranked down on the vise and the pins popped right out. I had also been soaking the hinges with Aero Kroil on and off again for a few weeks, then heated up the hinges with torch (thought the expansion and contraction would help break things loose). The guy in the video used this method on what looks to be nice, clean, freshly painted doors. All I can say is that I am glad my doors are in the pre-paint stage, because I sure I would have scratched something. _________________ http://das-auto-66vw.tumblr.com/ |
obfuscurity Samba Member
Joined: December 01, 2012 Posts: 320 Location: Westminster, MD, USA
Posted: Fri Jul 18, 2014 9:04 pm Post subject: |
Great tip. I love that guy in the video.
Quote: |
My daddy always said, you got to use what you got to get what'chu want! |
_________________ 66 Sedan L456 "Ramona" |
ludsbug Samba Member
Joined: March 08, 2005 Posts: 234 Location: Gardnerville NV
Posted: Fri Jul 18, 2014 9:28 pm Post subject: |
Takes all the fun out of it! |
Posted: Sat Jul 19, 2014 9:01 pm Post subject: |
Ha! I know, the video is worth watching alone just for the dude's commentary! _________________ http://das-auto-66vw.tumblr.com/ |
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4852 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Sun Jul 20, 2014 3:14 am Post subject: |
Thanks for the info, I'll store it away in my super VW filled brain.  _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Sun Jul 20, 2014 3:42 am Post subject: |
Hah yeah I'd buy that feller a beer! |
