Nickel_Nackel Samba Member
Joined: February 07, 2018 Posts: 187 Location: Bellingahm WA
Posted: Sun Jul 01, 2018 6:40 pm Post subject: Fighting Humidity |
Hi,
I've been living in my van for the past 2 months and its been pretty great so far. It has been fair weather here in the pnw but as of just yesterday I was changing my sheets on my mattress and noticed a bit of build up of water around the middle of my mattress. it rained last night and this morning but I know I have zero leaks in my van.
Wondering if this is a common issue with camping in a van long term. I think I'm going to build a frame underneath the foam mattress so it can get some air flow.
has anyone else dealt with this issue?
dehumidify even worth it?
Thanks! _________________ 1985 1.9L Potato |
SSWesty Samba Member
Joined: August 20, 2008 Posts: 735 Location: Bellevue
Posted: Sun Jul 01, 2018 7:42 pm Post subject: Re: Fighting Humidity |
It's a tough fight, I use to live on a boat and had to deal with it. Something like DryBunk or HyperVent helps. I like the thickness of hypervent because it creates a pretty good air space.
Boating forums are rich with info on the topic, especially liveaboard discussions or people cruise in tropical climates.
Here is a link for Hypervent https://www.fisheriessupply.com/hypervent-hypervent-mattress-pads-39-50 |
elizer Samba Member
Joined: May 02, 2016 Posts: 1501 Location: Northern Virginia
Posted: Sun Jul 01, 2018 8:01 pm Post subject: Re: Fighting Humidity |
| I wonder how much a eberspacher or webasto going in vent mode would help with humidity when it's raining? |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6933 Location: Fort Lauderdale, Fl.
Posted: Sun Jul 01, 2018 8:42 pm Post subject: Re: Fighting Humidity |
Do some research on You Tube for dealing with RV Humidity.
I know there is one boring teaching a "class" type video which is really very good for info.
You need to keep your windows open to provide an air vent or the condensation from your own body heat will start the rust cycle on the inside of the body.
This is where those plastic rain shields for the front door windows work in the rain environment.
A usb powered fan to keep air circulating helps provided you have usb outlet installed. _________________ This free advice is worth exactly what you paid for it.
Abscate Samba Member
Joined: October 05, 2014 Posts: 24467 Location: NYC/Upstate/ROW
Posted: Mon Jul 02, 2018 5:35 am Post subject: Re: Fighting Humidity |
Wait till you get older. It happens more often. There are many reasons, and which one it is just Depends. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
9.5isCanadian Samba Member
Joined: September 16, 2017 Posts: 465 Location: In your blind spot.
Posted: Mon Jul 02, 2018 7:45 am Post subject: Re: Fighting Humidity |
| Abscate wrote: |
| Wait till you get older. It happens more often. There are many reasons, and which one it is just Depends. |
 _________________ 9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Mon Jul 02, 2018 8:16 am Post subject: Re: Fighting Humidity |
| There is a reason box springs and slats have been used on beds for ages. Other alternatives are to turn the mattress daily and/or have an insulating pad under the mattress so that the moisture doesn't cool enough to condense. |
Posted: Mon Jul 02, 2018 10:36 am Post subject: Re: Fighting Humidity |
Thanks I'm going to try and build a frame for the mattress to breath _________________ 1985 1.9L Potato |
bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 4710 Location: United States, Iowa
Posted: Mon Jul 02, 2018 11:34 am Post subject: Re: Fighting Humidity |
Not sure its been asked, but does in your van also include driving it around some? Do you have an Air Conditioner that you run while driving, if so? Easy target for water like that would be from the AC having plugged drains. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Mon Jul 02, 2018 3:02 pm Post subject: Re: Fighting Humidity |
Zero ac. I did have my girlfriend sleeping with me this last weekend when I first found the water so I'm thinking it might be from two bodies being in a small space. Still going to build a box frame underneath. I drive it daily just to work and back which ia like a 10 min commute _________________ 1985 1.9L Potato |
