Which Carb Has Better Fuel Control Off Road?
Vanapplebomb
Vanapplebomb is offline
PostPosted: Fri Feb 21, 2014 4:05 pm    Post subject: Which Carb Has Better Fuel Control Off Road? Reply with quote
On type 4 engines, do the stock Solex 32-34 PDSIT carburetors have good fuel control when the going gets bumpy? Do they hold their tuning well? How do they compare to Webber IDFs when getting bounced around?
1800 Type 4 Berrien 295
Dale M.
Dale M. is offline
PostPosted: Fri Feb 21, 2014 4:17 pm    Post subject: Reply with quote
pssst!.... If you want best fuel control go EFI.....
Dale
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Feb 21, 2014 4:18 pm    Post subject: Reply with quote
Dale
While true, it's not what he asked.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Dale M.
Dale M. is offline
PostPosted: Fri Feb 21, 2014 4:36 pm    Post subject: Reply with quote
Glenn wrote:
Dale
Maybe going to EFI didn't occur to him, and may be a little suggestion may get him to think outside the carb box.... Might even get him to thinking he does not need a distributor either....
And yes I know, he did not ask about distributors ...
Dale
Vanapplebomb
PostPosted: Fri Feb 21, 2014 11:12 pm    Post subject: Reply with quote
I want to stick with carbs...same story with distributors.
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Fri Feb 21, 2014 11:38 pm    Post subject: Reply with quote
The stock carbs will need work, such as external float bowl vents and fixing the throttle shaft bushings which always go bad.
Personally I never liked the way one carb adjusting the idle mixture for both carbs.
Use a set of 36DRLA Dellorto's or 40IDF Webers and install a float bowl vent stack in them.
On both style of carbs can be improved with the use of Jet Doctors that CB sells.
Maybe you don't like using JB Weld to hold the vent tubes in place, FAT Performance does it and has won many off road races with them with out them falling out.
If you really drive in rough conditions then go to dry sump (sucker system) for the carbs. It works extremely well.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
hooker
hooker is offline
PostPosted: Sat Feb 22, 2014 9:02 am    Post subject: fuel control Reply with quote
I have used 36mm dellortos on my 82 westy as well as using them on my sand rails with smaller engines without any mods and they have always worked excellant. Yes, I use the german 009 distributor too.
2007 NHRA Division 6 Finals Champion air cooled Rabbit P/U rear engine compact/import class, 13.32 sec 1/4 Woodburn, Oregon
Pauter Big Block VW 2610 cc turbo mid engine roadster 9.69 sec @ 147 mph 1/4 PIR Oregon
I spent most my money on women and VW race cars. The rest I wasted.
Vanapplebomb
PostPosted: Sun Feb 23, 2014 10:34 pm    Post subject: Reply with quote
I guess I wonder because I'm looking for a stock type 4, and they came with the dual Solex PDSIT carbs. I like the idf/hpmx carbs for their ease of set up and tunability. I don't know much about the Solex carbs other than the fact that they are definitely more complex, but seem to work really well when set up right.
Still open for opinions on which of the two would have better fuel control off road Wink
mr_bill
mr_bill is offline
PostPosted: Wed Feb 26, 2014 11:58 am    Post subject: Reply with quote
34 PICT-3 modified for off-road use...
fuel cut-off removed & plugged, with external bowl vent
see ya' on the trail........
"Mr Bill"
Dos Perros Motorsports
Orange, CA
1972 Class 11x/Stock Bug
'60's era "vintage" Tunnell-Buggy
"...no one here....get's out ALIVE...."
Motor = electric
Engine = internal combustion
www.facebook.com/groups/DosPerrosMotorsports
www.alrchapter132.org
www.DAV.org
Brian
Brian is offline
PostPosted: Wed Feb 26, 2014 1:44 pm    Post subject: Reply with quote
Where does the bowl vent connect to?
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Vanapplebomb
PostPosted: Wed Feb 26, 2014 3:31 pm    Post subject: Reply with quote
Hu, interesting. I have never heard of anyone putting a 34 PICT 3 on these engines. What makes the PICT 3 modified for off road better than the PDSIT carb if one were to make the same modification?
Also, does anyone sell an intake manifold for this set up?
jsturtlebuggy
PostPosted: Wed Feb 26, 2014 6:14 pm    Post subject: Reply with quote
The bolt pattern is different on the two carbs. Not interchangeable with out work.
Anything can be done, it just do you want to spend the time figuring it out and making linkage for it to work.
Joseph
Elrod Motorsports
Vanapplebomb
PostPosted: Wed Feb 26, 2014 6:43 pm    Post subject: Reply with quote
Yeah, it seems like a custom manifold would have to be made... cut and splice a couple pieces together in order to make it work. Sounds like more work than it is worth unless someone can give me me good reason why 34 pict 3 carbs would be better off road than the stock carbs Wink
Vanapplebomb
PostPosted: Sun Jul 13, 2014 2:42 pm    Post subject: Reply with quote
Well, looks like I am going to give the stock 34 PDSIT 2/3 carbs a shot since I already have a set on hand. I will definitely need to replace the throttle shaft bushings as well as all the gaskets and diaphragms.
Appart from extending the float bowl vents, are there any other modifications that I can make to improve the performance of these carbs for a little off road fun?
dustymojave
dustymojave is offline
PostPosted: Sun Jul 20, 2014 2:01 am    Post subject: Reply with quote
I believe Bill was showing the mods on the 34PICT 3 for reference on what to do to the 34PDSIT. The float bowl vent hoses can be connected to a fuel filter with the other side of the filter open.
Richard
SoCalBajas Member
fishybastard
fishybastard is offline
PostPosted: Sun Jul 20, 2014 7:58 am    Post subject: Reply with quote
I recently went back to the 34 pict 3 on my rail as well. I am liking those mods for off road use! I do not have my choke hooked up. Can I just remove the choke butterfly? What are the advantages of these mods for off road use?
Dale M.
Dale M. is offline
PostPosted: Sun Jul 20, 2014 11:30 am    Post subject: Reply with quote
One major thing wrong with stock carbs is press in fuel inlet barb... Inlet needs be drilled and taped for thread in barb... Same with early fuel pumps with press in barbs...
Dale
fishybastard
PostPosted: Sun Jul 20, 2014 12:19 pm    Post subject: Reply with quote
I noticed that garbage press in fitting with no barb as well. Seems a bit sketchy.
Brian
Brian is offline
PostPosted: Sun Jul 20, 2014 12:29 pm    Post subject: Reply with quote
Dale
Would AN fittings on the stock fuel pump be overkill?
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Dale M.
Dale M. is offline
PostPosted: Sun Jul 20, 2014 12:55 pm    Post subject: Reply with quote
lustig69 wrote:
Dale
Probably when something like this would suffice..
Probably less than $5 at local hardware, its just a matter of getting carb inlet drilled and tapped to proper size without destroying it... Be careful with DIY here, carb top is cast zink or some other "pot metal" and you can easily crack it when screwing in tapered fitting...
Would be better with straight cut thread (and seal washer) than tapered (NPT)... Possibly like inlet fittings for (late) Weber carbs...
Dale
