2000typer Samba Member
Joined: May 24, 2013 Posts: 88 Location: Medford, Oregon
Posted: Thu Sep 25, 2014 11:52 pm Post subject: Reverse light switch |
I have a 1966 bug but it doesn't have the original tranny(I'm not sure what year it is).
It has a plug on the nose cone to install a back up light switch. Is that all that's necessary to get reverse lights or is there something internal in the tranny that's required?
shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
Joined: June 02, 2011 Posts: 1593 Location: Louisville, ky
Posted: Fri Sep 26, 2014 12:44 am Post subject: |
| No, just stick a switch on there. The hockey stick has a nub on it that swings over and trips that switch. |
Merlin Samba Member
Joined: August 19, 2004 Posts: 2119 Location: South Africa
Posted: Fri Sep 26, 2014 2:02 am Post subject: |
Good work on your pan. Keep it up.  _________________
| iowegian wrote: |
| People who are allowed to have signature lines annoy me. |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4658 Location: Whittier 90602
Posted: Fri Sep 26, 2014 4:48 am Post subject: |
| shortride wrote: |
| I would like to install backup lights on my '66 as well. |
A stock/original '66 trans doesn't have the threaded hole for the switch, that started in US '67 models.
If your trans is original and never updated, new replacement nose cones have the hole for a switch and are a direct bolt on...
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-113-301-205-F _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Fri Sep 26, 2014 5:13 am Post subject: |
| I just installed a rebuilt 67 tranny in my 66 with a reverse light switch and I added reverse lights. All you have to do is add a switch and wire it up |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Fri Sep 26, 2014 5:27 am Post subject: |
| shortride wrote: |
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1104510
shortride check into this type for the speedo head or this type that hooks up under the plate to access the shift coupler
_________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
| tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
| sb001 wrote: |
maybe he just snapped cause his car sucked  |
Posted: Fri Sep 26, 2014 7:18 am Post subject: |
| Thank you very much. Back up lights will be nice. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17705 Location: Left coast, Canada
Posted: Fri Sep 26, 2014 8:46 pm Post subject: Re: Reverse light switch |
| 2000typer wrote: |
It has a plug on the nose cone to install a back up light switch. Is that all that's necessary to get reverse lights |
Make sure you use the thick aluminum sealing washer that's with the plug. If you don't use this washer the switch will be too close to the R shift rod and it will prevent you from engaging reverse.
Note: it is the Reverse shift rod that actuates the switch. Nothing to do with the hockey stick. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
Posted: Sat Sep 27, 2014 12:48 am Post subject: |
| I will, thank you Bruce |
kanexavier Samba Member
Posted: Sat Sep 12, 2015 8:32 am Post subject: reverse light in pre-67 |
| Hello; I bought a vw dune buggy that has parts from various years and trying to track down parts. I have a swing axle with no back up switch. My question is can I install a back up switch by just changing the nose cone and wiring it up or do i have to change any internal parts in the tranny?? |
61SNRF Samba Member
Posted: Sat Sep 12, 2015 5:26 pm Post subject: Re: reverse light in pre-67 |
| kanexavier wrote: |
| Hello;...My question is can I install a back up switch by just changing the nose cone and wiring it up or do i have to change any internal parts in the tranny?? |
That's correct, only the nose cone is different with no other internal parts to change.
It's actually the flat end of the reverse shift rail that acts on the tip of the switch, so no worries with the hockey stick either (Beetle hockey sticks are all the same from '61-'79 anyway).
Bruce also gave a good tip above, be sure to use the good thick sealing washer or it could inhibit full reverse gear engagement  _________________ -Bruce
grandpa pete Samba Member
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11225 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Mon Sep 14, 2015 8:49 am Post subject: |
| grandpa pete wrote: |
Don't be afraid of the wiring ;
pull 12 volts off the coil ( is only on when the key is on ) ; run through the tranny switch , to a light on the rear ;grounded... |
Add an inline fuse to the coil circuit as well.
IMO .. protect the entire circuit..
I never understood why VW never fused the IGN 15/54 "ON" voltage to the coil circuit from the Ign switch..
Lots of cooked harnesses over the years because of that penny pinch...
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26400 Location: Olympia Wash Rinse & Repeat
Posted: Mon Sep 14, 2015 11:22 am Post subject: |
| Eric&Barb wrote: |
Because, not if, but when the fuse goes bad you have the VW stall out in possibly a bad place to do so.
Yeah.. I guess a melted harness and possible fire is a bit safer..
Fuses open when a circuit is overloaded or shorted.. they just don't go bad..
If that bad fuse pop stall theory were true... all modern cars today are just ticking stall bombs..
Posted: Mon Sep 14, 2015 11:27 am Post subject: |
Well have over 300,000 miles and 30 + years of driving old ACVWs and never have had a wiring problem with stock wiring. Of course keep the wiring in good shape, especially in the engine compartment where wiring gets brittle insulation. With anything (like fuel lines), preventive maintenance is a must. _________________ In Stereo, Where Available! |
61SNRF Samba Member
Posted: Mon Sep 14, 2015 6:24 pm Post subject: |
| VOLKSWAGNUT wrote: |
...I never understood why VW never fused the IGN 15/54 "ON" voltage to the coil circuit from the Ign switch..
One thing to think about, adding a fuse to the circuit would add 6 more man made connections to potentially break down from oxidation or looseness resulting in a Voltage drop:
1-Terminal crimp on Black wire from fuse panel +15
2-Push on terminal connection to fuse holder in
3-Fuse holder to fuse, input side
4-Fuse output side to fuse holder out
5-Push on terminal to fuse holder
6-Terminal crimp on Black wire to coil +15
Old style ceramic fuses also get hot and cold thus expand and contract, eventually breaking down and open circuiting where they are bent.
I've fixed more than one reverse lights inoperative issue by simply replacing a fatigued fuse and cleaning the holder.
A soldered in fusible link may be more reliable in the long run, say limited to about 20 Amps. _________________ -Bruce
EVfun  Samba Member
Posted: Mon Sep 14, 2015 7:25 pm Post subject: |
I fuse the ignition coil wire up front. VW fused the ignition wire before running it to the reverse light switch for cars equipped with one. I think lack of a fuse to the front parking lights under the sloped covers was an even worse idea than the ignition coil decision. I either move that to the tail light fuse and have them stay on with the headlights, or I fuse that wire. _________________
| Wildthings wrote: |
| As a general rule, cheap parts are the most expensive parts you can buy. |
