i need help making a list
jeggers
jeggers is offline
PostPosted: Fri Jan 23, 2004 4:27 pm    Post subject: i need help making a list Reply with quote
ok, i just got this 86 camper and i want to make a list of things to do to it...general maintinance stuff
aside from oil change, coolant change, what would you guys do to a new to you vanagon that has no prior service records?
laughing_dog
laughing_dog is offline
PostPosted: Fri Jan 23, 2004 5:21 pm    Post subject: Reply with quote
Start running Marvel Mystery Oil through with every tankload.
WES
Seattle, WA
'85 Westy "Sumpy" (Die Goldsumpfschildkröte)
View user's profile Send private message AIM Address Yahoo Messenger Classifieds Feedback
Tram
Samba Socialist
Tram is offline
PostPosted: Fri Jan 23, 2004 8:06 pm    Post subject: Reply with quote
Do a complete 60,000 mile service. That'll take care of all the maintenance as well as an inspection of everything so that you'll have a pretty good idea of where the Vanagon is wear- wise. The best tool you can buy is a Bentley manual. It'll tell you what to maintain when and how to check wear items for durability. You'll always have stuff like starters and alternators for which there is no comprehensive test; e.g, it may be "good" right now and fail tomorrow, but with the Bentley you'll be able to properly diagnose and repair problems. And, we all know that "knowledge is power". Congratulations on your Vanagon!!! Very Happy
Chris181Westy
Chris181Westy is offline
PostPosted: Fri Jan 23, 2004 9:07 pm    Post subject: Reply with quote
If the P.O. did not use the correct antifreeze I would flush the coolant system. I can't remember which kind of antifreeze it is, but I know that one of the main reasons that the Vanagons had such problems with the heads is because the wrong antifreeze will corrode the heads. But after doing this you must bleed the system, you will have to jack up the rear end to do this.
"So we went for a spin in the country
To feel the wind in our hair
To feel the power of my engine
To feel the thrill of desire"
Roger Waters, The Pros and Cons of Hitchhiking
