dayrider Samba Member
Joined: October 08, 2010 Posts: 20 Location: wichita falls
Posted: Sat Nov 22, 2014 7:12 pm Post subject: Ragtop mechanism removal |
I’ll be painting my 1963 ragtop beetle soon and need to remove the entire ragtop mechanism with canvas intact. I’ve studied the Bentley and searched on SAMBA but I’m still lost on the steps needed to accomplish this. The slide railing is in two pieces. I gather I can remove the rear rail and slide the mechanism out but do I need to first detach the rear portion of the headliner under the ragtop? If so, what tool would best take the fasteners out? Anything else? A step-by-step would really be appreciated. |
my59 Samba Member
Joined: August 13, 2003 Posts: 3975 Location: connecting the dots
Posted: Sat Nov 22, 2014 11:15 pm Post subject: |
Look in my gallery and the workshop pages are posted.
I used a flat dull spackle knife to pop the headliner loose. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2392 Location: DEEK - U.S.A.
Posted: Sun Nov 23, 2014 12:05 am Post subject: |
my59 wrote: |
Look in my gallery and the workshop pages are posted. |
THANK YOU!!!!!  _________________ Jesucristo es mi Señor y Salvador! |
my59 Samba Member
Posted: Sun Nov 23, 2014 6:22 am Post subject: |
You're welcome. Someone else also posted them all together; search
'Factory ragtop sliding roof manual' _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Posted: Sun Nov 23, 2014 5:05 pm Post subject: |
Thanks for the headliner removal tip but exactly how do you remove the rear bow? How many bolts/screws hold it to the body? |
Posted: Sun Nov 23, 2014 7:16 pm Post subject: |
So after you pull the headliner down, you will find that the rear bow has studs welded to the bottom of it and is attached to the roof with nine nuts . . . you will need a 10mm wrench (possibly an offset box wrench) to loosen the nuts.
There should be washers under the nuts and there is also a metal reinforcing strip . . . the roof is sandwiched between the reinforcing strip and the sunroof bow.
The rear bow is somewhat straight (and under a light tension), so when you are unbolting the nuts, it might be helpful to have an assistant outside the car holding the end of the bow down against the roof . . . and be ready for the nut to "Pop off" when it is unscrewed . . . don't lose any hardware . . . you might end up with a "new rattle" if you lose a nut inside your headliner!
For painting, you might want to remove the slider rails . . .
If you were simply replacing the canvas/vinyl cover, there are two special shouldered screws in the front clamping bow that you can remove and the upper-front bow can be taken off without removing the rails. _________________ Jesucristo es mi Señor y Salvador! |
Posted: Sun Nov 23, 2014 9:31 pm Post subject: |
This was very helpful. Thank you! |
nvrgvupjw Samba Member
Posted: Sat Dec 06, 2014 8:51 pm Post subject: |
dayrider wrote: |
If you remove the frame rails, consider using steel wool to polish the tracks that the rollers are rolling on. |
Dake Samba Member
Joined: September 02, 2014 Posts: 483 Location: Georgia
