branston Samba Member
Posted: Thu Dec 11, 2014 7:59 am Post subject: Bosch Coil part numbers |
I've searched and I can't find this, I know I've seen it on samba.
It is a listing cross referencing VW parts and Bosch ignition coil part numbers.
Can anyone link me to it? It may have been in a post.
Thanks |
diablosandwich Samba Member
Joined: January 15, 2012 Posts: 519 Location: Illinois
Posted: Thu Dec 11, 2014 11:26 am Post subject: |
I am not sure if this will help, http://www.oldvolkshome.com/ignition.htm Scroll down and click on the year. On a side note, I finally installed the intake you refurbished for me last year. Looks and works great! Thanks Casey _________________ 2 1966 Java Greens and a 65 Sea Blue that is green |
Posted: Thu Dec 11, 2014 12:17 pm Post subject: |
Thanks for the link. I have that list. There is another I found directly referencing coil part numbers VW to Bosch. I was sure I'd saved it!
I'm glad the intake worked well for you. Nice to know. |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26634 Location: Douglas, WY
Posted: Thu Dec 11, 2014 11:50 pm Post subject: |
Here's some images I've made of some coil part numbers and cross references.
And from later on, some long/short numbers:
Posted: Fri Dec 12, 2014 8:17 am Post subject: |
Thanks so much for the posting your information, I eventually found your original post of the first list, the rest is a real bonus to me.
Thanks |
Posted: Fri Dec 12, 2014 10:46 am Post subject: |
And as for VW part numbers, the VW parts books aren't much help because they only show the current coils they were selling, which retrofitted any earlier coils. In 1960, that coil was 111 905 105 C. By the early 70s, the 6V coil was 111 905 105H and the 12V coil was 113 905 115 C, except for type 3/4 EFI engines, which used a 311 905 115 C.
I dug up some more cross reference data from 1971 and 1996:
Posted: Fri Dec 12, 2014 9:48 pm Post subject: |
| This is just what I needed and more.... Thank-you for sharing your knowledge |
jonat Samba Member
Joined: July 16, 2013 Posts: 109 Location: United Kingdom
Posted: Fri Aug 06, 2021 9:42 am Post subject: |
| glutamodo wrote: |
What year might a black Bosch coil with: 0221 114 021 (311 905 115D) printed on it be? |
jonat Samba Member
Posted: Thu Aug 12, 2021 5:40 pm Post subject: Re: Bosch Coil part numbers |
@glutamodo
great chart! Thank you for your reply.
Mine is a short coil. There is a 130 printed above the VW part #. Would this then mean it was appearing on bugs manufactured in OCT 1971? Could it also mean it would be seen in beetle engines considered as 1972 bugs? |
Joined: April 27, 2002 Posts: 6855 Location: Pentwater, Michigan
Posted: Thu Aug 12, 2021 8:10 pm Post subject: Re: Bosch Coil part numbers |
Yes, a October 1971 part would fall into the 1972 model year of production. _________________ Roads Scholar
Member# 2059 |
Frederik Samba Member
Posted: Wed Aug 18, 2021 7:17 am Post subject: Re: Bosch Coil part numbers |
To add some info from my lists
jonat Samba Member
Posted: Sun Aug 29, 2021 4:40 am Post subject: Re: Bosch Coil part numbers |
| Why did some Bosch black coils have the yellow oval sticker on whilst others have a light blue one? How do I know which to put on a coil that is missing one? |
dustymojave Samba Member
Joined: January 07, 2007 Posts: 5847 Location: Lake LA, Mojave Desert, SoCal
Posted: Sun Aug 29, 2021 11:18 am Post subject: Re: Bosch Coil part numbers |
The blue colored coil is a Bosch High Performance coil that puts out about 1/3 more voltage than the stock black painted Bosch coil. It's an aftermarket high performance item and was NEVER installed at the factory.
So If you are after PURE STOCK, museum quality correct, then use a black coil and sell the blue coil to a guy who is hotrodding his Bug or buggy. _________________ Richard
SoCalBajas Member
jonat Samba Member
Posted: Sun Aug 29, 2021 2:16 pm Post subject: Re: Bosch Coil part numbers |
| dustymojave wrote: |
So If you are after PURE STOCK, museum quality correct, then use a black coil and sell the blue coil to a guy who is hotrodding his Bug or buggy. |
I mean that i've seen a VW black coil with a 12V 'Made in Germany' blue oval Bosch sticker and also a VW black coil with a yellow oval 12V 'Made in Germany' Bosch sticker, both stock.
Also I have seen the same two different stickers on VW stock black short coils. |
Posted: Sun Aug 29, 2021 6:54 pm Post subject: Re: Bosch Coil part numbers |
My understanding, and I don't remember where I got this information from is that the blue sticker was affixed to black painted coils run on fuel injection type III applications. _________________ Roads Scholar
Member# 2059 |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 549 Location: Northridge, CA.
Posted: Sun Aug 29, 2021 10:47 pm Post subject: Re: Bosch Coil part numbers |
| The blue oval sticker came around '73 and maybe a little earlier. My original coil in my '74 Thing had a rectangle blue label. The change had to do with the age of the coil. |
Posted: Mon Apr 04, 2022 4:59 am Post subject: Re: Bosch Coil part numbers |
| Al Capulco wrote: |
As said, the yellow vs blue sticker on the 12V black coil had to do with manufacturing date, Bosch just changed the color. But the blue oval sticker was availible earlier. I don't have an exact date, but somewhere late 60's.
This is a NOS "shorty" 0 221 114 006 12V coil (used for type 1, 2 and 3 as above). Manufactured November 1969 (911 date code). Edit: looking in sales brochures the blue sticker coil was in use at least from model year 68 (Aug 1967).
Sales brochure from archive (type 2 8.67)
