Front and rear grill trim install
mnakandala
mnakandala is offline
PostPosted: Thu Jan 01, 2015 8:17 pm    Post subject: Front and rear grill trim install Reply with quote
Hi i've searched the forum but coudnt find a answer, does anyone knows how to install these?
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-3345
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-3346
1964 bug
1983 mitsubishi Delica
hitest
hitest is offline
PostPosted: Thu Jan 01, 2015 10:16 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=1185460
Here's a closeup of the typical grill. See the longer tabs? The long, under-window piece may have these little tabs, or several wider vertical strips that grip your beetle's louvers with a pinch. All you need is a plastic spatula or at least a flat wooden tool (tongue depressor, popsicle stick) for the job. Peruse the other ads for these grills for more info if needed.
FU#5
