Alternative sealer for the mating surfaces of the engine ??
Alexmobil
Alexmobil is offline
PostPosted: Sun Jan 04, 2015 6:23 pm    Post subject: Alternative sealer for the mating surfaces of the engine ?? Reply with quote
Hello everybody!
This week the plan is finish the rebuild of the engine for the DC ( 1600 SP, AS41) and the engine sealant is the only missing part in the process.
I´ve searched Permatex 3, Gasgacinch, curil T or curil K in every automotive shop here in el Salvador with no success.
The options available are:
1.-Indian Head Gasket Shellac
2.-Permatex 2
3.-Loctite 510
4.-Gray silicone
Any advice? (Specially for the mating surfaces of the engine halves)
Thank you in advance and this is the thread of my split:
http://www.thesamba.com/vw/forum/viewtopic.php?p=6768092&highlight=#6768092
busdaddy
busdaddy is offline
PostPosted: Sun Jan 04, 2015 6:27 pm    Post subject: Reply with quote
Avoid the shellacs like #1 and #2, they were great until the man started putting ethanol in gasoline, ethanol dissolves shellac.
Слава Україні!
guatebus
guatebus is offline
PostPosted: Sun Jan 04, 2015 6:43 pm    Post subject: Reply with quote
I have a little bit of Central American VW experience.
When I was living in Guatemala, I did an engine build and I used Hondabond to seal the case halves.
I can't quite remember, but I think I got it at a Honda motorcycle dealership? Something like Yamabond will also work and may be available there.
'64 standard microbus
'69 deluxe microbus
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Jan 04, 2015 6:45 pm    Post subject: Reply with quote
Permatex Aviation
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
busdaddy
busdaddy is offline
PostPosted: Sun Jan 04, 2015 7:46 pm    Post subject: Reply with quote
Careful, Permatex aviation is often alcohol based (used to be anyways), the Hondabond/Yamabond (grey silicone) is a better choice if selection is limited, just make sure you put it on thin and work fast.
Слава Україні!
busworks
busworks is offline
PostPosted: Sun Jan 04, 2015 7:48 pm    Post subject: Reply with quote
loctite 574
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Sun Jan 04, 2015 8:13 pm    Post subject: Reply with quote
Glenn wrote:
Permatex Aviation
This is the best, but it needs to be a very old container of it that has been left open for years to form an extra thick tar-like paste. One that the brush can barely be separated from.
Don't even pretend that you don't know what I mean.
Gordo.
Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others.
BarryL Premium Member
BarryL is offline
PostPosted: Mon Jan 05, 2015 10:13 am    Post subject: Reply with quote
Haha just tossed one yesterday! Pulled the brush and the whole bottom 1/2 came out in a yo-yo then when you let the brush go it all went back inside the can.
Dougy Dee
Dougy Dee is offline
PostPosted: Mon Jan 05, 2015 3:29 pm    Post subject: Reply with quote
Permatex Motoseal is very similar to Yamabond/Hondabond and others. Dont use silicone.
Permatex 3H can be resurrected by mixing rubbing alcohol back in with the thick goop...
21-window
21-window is offline
PostPosted: Mon Jan 05, 2015 3:44 pm    Post subject: Reply with quote
busworks wrote:
loctite 574
This^^^^ If you can get it..
busworks
busworks is offline
PostPosted: Mon Jan 05, 2015 4:38 pm    Post subject: Reply with quote
I ordered mine through fastenal. Was expensive too
wrenchnride247
wrenchnride247 is offline
PostPosted: Mon Jan 05, 2015 7:59 pm    Post subject: Reply with quote
Elring K2 with top left open for a while.
SPL
'62 SC 69x90.5 SP TI
'70 T1 84x105 DP T4
obieoberstar
obieoberstar is offline
PostPosted: Mon Jan 05, 2015 9:00 pm    Post subject: Reply with quote
Is there a VW-Porsche-Audi dealer in your area? I can get Loctite 574 from our Porsche parts depot. VW/Audi have a couple of similar sealants. One is green to seal the camshaft bridge on 2.0T engines and another is white and says on the tube that it is used to seal Type 2 engines. Both work really well.
I can get you part numbers if needed.
j.pickens
j.pickens is offline
PostPosted: Mon Jan 05, 2015 10:31 pm    Post subject: Reply with quote
I'd look for Hondabond. There's tons of Hondas all over everywhere, should be as easy to find as any alternatives. Works perfect, too.
BeaterBarndoor wrote:
Red Fau Veh wrote:
brese73
brese73 is offline
PostPosted: Wed Aug 09, 2017 3:18 pm    Post subject: Re: Alternative sealer for the mating surfaces of the engine ?? Reply with quote
I just read this thread and see its a couple years old since last post. So should I get Loctite 574? I see it on Amazon
Bulli Klinik
Bulli Klinik is offline
PostPosted: Thu Aug 10, 2017 8:02 am    Post subject: Re: Alternative sealer for the mating surfaces of the engine ?? Reply with quote
I'm not familiar with the locktite product, but you most certainly don't want to use any sort of silicone product. Permatex brush on is the preferred sealer. You need something that has 'zero crush', meaning that the case surfaces won't be held apart like silicone would.
Mike K
Bulli Klinik
Colorado Springs
ToolBox
ToolBox is offline
PostPosted: Thu Aug 10, 2017 8:32 am    Post subject: Re: Alternative sealer for the mating surfaces of the engine ?? Reply with quote
http://na.henkel-adhesives.com/product-search-1554.htm?nodeid=8797713760257
LOCTITE 574
Gasketing Product - general purpose. Ideal for use on machined and rigid metal flanges
LOCTITE® 574 seals close-fitting joints between rigid metal faces and flanges. The product cures when confined in the absence of air between close-fitting metal surfaces. It provides resistance to low pressures immediately after assembly. Typically used as a form-in-place gasket on rigid flanged connections. The nature of LOCTITE 574 reduces the migration of liquid product after application to the substrate. It has a high oil tolerance and excellent water and glycol resistance.
Your benefits
Ideal for use on rigid metal parts, e.g. cast iron components and pump housings
High oil resistance
Excellent water and glycol resistance
Bruce Amacker
Bruce Amacker is offline
PostPosted: Thu Aug 10, 2017 7:22 pm    Post subject: Re: Alternative sealer for the mating surfaces of the engine ?? Reply with quote
There are many sealers that will work. Perhaps the most important advice is to make sure the surfaces are spotlessly clean with no oil film- wipe them down with brake clean before applying the sealer. Use no RTV (silicone), I use Permatex High Tack. RTV leaves beads (worms?) that hang out and eventually break off, getting into the oil system and clogging vital passageways. I know a guy who has built lots of motors with Indian Head. Permatex #2 is really thick and will hold the halves apart, I wouldn't use it.
Good Luck!
'66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263
