itskyle Samba Member
Joined: October 04, 2013 Posts: 634 Location: Plainfield, IN
Posted: Wed Jan 07, 2015 10:19 am Post subject: Extreme Cold Weather Starting Thread 2015!! |
Rules, applies to non-garage kept bugs, or bugs that had to be out in the cold for some unknown reason.
Data
ambient outside temperature with and without wind chill
date
time
stock engine, tranny, or not-with details
whether or not an engine heater/heat lamp was used.
I'll start.
66 Vw beetle 67 tranny 71 1600dp engine converted to 12 volt system badly
4 degrees fahrenheit 7:45 this morning.
20 below with wind chill.
Started in under three seconds. Idling normally after about a minute and change. It seemed like 30 seconds because of the cold.
Can anybody beat that? Post yours! _________________ --
69 or 72 Autostick Bug current
66 Bug (We both miss it)
74 SuperBeetle Auto Stick (I miss that car)
73 SquareBack, Straight Stick (Wife misses this one.)
hitest Samba Member
Joined: September 30, 2008 Posts: 10327 Location: Prime Meridian, ID
Posted: Wed Jan 07, 2015 10:37 am Post subject: |
Not to be a buzz kill- but there's no way to tabulate battery health, and the way of which the car was previously driven. If shut off at 10pm the previous night, 30 seconds the next day would make me think my car is broken. _________________
| EverettB wrote: |
FU#5 |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36338 Location: Conejo Valley, CA
Posted: Wed Jan 07, 2015 11:11 am Post subject: |
Sorry, I'm no help. It will be 80 today, and it is a toasty 55 in my garage. The car is fuel injected, too. Starts in about two seconds warm or cold. Coldest start was in the teens years ago, took about four seconds. Good 12V battery and so-so compression.
In the past, I've started in the low 20s and even high teens with a carb'ed 6V Bug. It took a crank or two but always started. I used a larger Group size battery, kept the wiring in good shape, and the timing/carb/choke adjusted spot on. I used to use 30 oil but shifting to 20W50 made it crank faster when cold.
Never tried to start below zero, though. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3338 Location: N.E. Oklahoma
Posted: Wed Jan 07, 2015 3:41 pm Post subject: . |
When I was in high school, in the 60s, my dad bought me a left-over '65 bug in late 1965 and I drove it the 32 miles each way, to school. It drove great in 12 + inches of snow and it started on every cold New Jersey morning...like all early VWs it had minimal heat and awful windshield defroster but always started.
When I graduated in 1966, it was time for me to buy my own car. I picked up a 1948 Plymouth convertible for $75 and drove it for 2 years...was not as good in the snow, had great heat and defroster, but had trouble starting when it was below 10 degrees and I usually had to call AAA for a jump start the positive ground, six volt battery.
I have old VWs these days, but rely on an outstanding Civic Si in the winter. It's the best of all...for every reason.
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13959 Location: White Mountains Arizona
Posted: Wed Jan 07, 2015 5:13 pm Post subject: |
68 bug 1776cc dual Kadron's no chokes. 25 degrees. It is a pain to start without chokes. The car does have a starter button without ignition. So i get the oil flowing 10-30 rotella. Then put the iginition to it. Have to feather the throttle for a minute or so.
The other cars in @ 50 degrees in the garage. Start right up. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Helfen Samba Member
Joined: January 19, 2009 Posts: 3483 Location: Vulcania
Posted: Wed Jan 07, 2015 8:16 pm Post subject: |
1965 111 36hp 1200 matching numbers.
22 degrees. Crank engine with the manual choke OFF and ignition OFF to oil prime the engine for 15 seconds...and to fill the fuel pump and for the pump to fill the float bowl in the carburetor. Turn the ignition sw on, crank again verify fuel is there when the engine starts so sputter. Start the car in the usual Porsche 356 way ( they didn't have chokes) by before cranking to depress the throttle fully three or four times and use the throttle plate as the choke and turn ignition on and crank. Engine fires in a second, and with the throttle modulate the rpm gently to 800 rpm. When the engine will idle on it's own you can go into the house and wait for the engine oil temp to reach 115 degrees ( about ten minutes for my car ) after which you can safely apply load to the engine and drive away. |
iowegian  Samba Curmudgeon
Joined: February 16, 2005 Posts: 9985 Location: Somewhere between Dubuque and Keokuk
Posted: Wed Jan 07, 2015 9:07 pm Post subject: Re: Extreme Cold Weather Starting Thread 2015!! |
| itskyle wrote: |
Data
date
time
I'll start.
Started in under thirty seconds.
Can anybody beat that? Post yours! |
Does an air-cooled car really understand "wind chill"????? |
chink13 Samba Member
Joined: May 07, 2009 Posts: 143 Location: Ocean Springs, MS
Posted: Thu Jan 08, 2015 11:29 am Post subject: |
65 sunroof with a 62 trans and a 73 stock 1600 with kadrons and kadron exhaust.
it was 21F when I got in her
stayed running on the 3rd try
also bug understand wind chill when it come at you from the side I got blown all over the road this morning but I made it without running off the road!! |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24422 Location: NYC/Upstate/ROW
Posted: Thu Jan 08, 2015 11:58 am Post subject: Re: Extreme Cold Weather Starting Thread 2015!! |
| iowegian wrote: |
| itskyle wrote: |
Data
date
time
I'll start.
It does understand it, but wind chill doesn't affect starting at all, once the car reaches ambient temperature. Overnight, cars will reach equilibrium with the outside, of course.
It doesn't matter if its air cooled or water cooled either. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
Helfen Samba Member
Posted: Fri Jan 09, 2015 10:35 am Post subject: |
Seems like it would be hard to gather data when your criteria for the cars is so wide open. Just look at the differences of the contributions to the thread. 12V vs. 6 volt, multi. carburetors verses stock, stock vs. modified exhaust, Different year/size engines.
Even my 65 "A" Sedan has a different engine architecture (36hp) although the size is the same as a 40hp. Distributor, carburetor, air cleaner, emission system. compared to a 40 hp 65 is way different.
It's also interesting to note that with the exception of 1967 12V and a 1300 in 1966 and 1500 in 1967, that the section we are in (1958-1967) most of the cars with their engines, carburetors and 12v. systems don't resemble how they came from the factory or the era 1958-1967.
All the differences is like comparing apples to oranges. |
Posted: Fri Jan 09, 2015 1:36 pm Post subject: Re: Extreme Cold Weather Starting Thread 2015!! |
| Abscate wrote: |
| iowegian wrote: |
| itskyle wrote: |
Data
date
time
I'll start.
It doesn't matter if its air cooled or water cooled either. |
But-----------water freezes but air don't.
Especially when we're talking about the windshield. |
hopkin  Samba Member
Joined: June 25, 2012 Posts: 2560 Location: Ottawa, Ontario
Posted: Fri Jan 09, 2015 1:57 pm Post subject: |
I don't run the car when it's way below freezing, two nights ago it was -13F (-25C, -37C with windchill) when I got home from the store. It got a few degrees colder later that night.
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Fri Jan 09, 2015 8:44 pm Post subject: |
Back in the day, as they say, I owned a 59 beetle (a tourist imported model). I got it in 1967 from the original owner ...for about $400. Where I live (central Saskatchewan) we typically experience at least 4 ..often more ..months of extremely cold weather. As a previous Canadian poster mentioned, recently we've had a bit of a cold snap: overnite lows of -35C (I'll let you google the F equivalent) and that gets pushed well into the -40's with the wind chill. Anyway, "back in the day" we took winter in stride (8 months of winter, and 4 months of poor skating, as the saying goes) and often the few VW's that were around were some of the only vehicles that would start in that kind of cold. On my 59 (and later on a 63, and a 66 ) I used the electric oil pan heater (simple heating element mounted around the oil drain plug). I'd run thinner oil (5w-20) and keep the pan heater plugged in overnite ...that would facilitate easier starting at the very cold temps ...but anything in the -15 to -20C range, we didn't plug in at all ....thin oil was the answer, and cold weather starting (with a decent battery) was not an issue. Another trick we used was the double plug-in: an interior warmer (essentially a small electric space heater) AND the pan heater. The interior warmers were designed to work in the much larger North American vehicles of the day to keep the interior a bit warmish, but mainly to keep the windows from frosting over. They were super-efficient in the much smaller VW bug ...and had the added advantage of keeping the battery "warm" as well. (I helped that out by lifting up the back seat bottom to allow the warmer air to circulate around the battery). BTW....of all the early Beetles I owned, NONE had the optional gas heater ...Canadians in the 50's and 60's were much too frugal to spend the extra $80 or so for a gas heater. It was more common to see a frost scraper hanging from the interior mirror ... so you could get your passenger to keep the interior of the windshield clear of frost!!
So ...if you want to understand how the air-cooled bug performs in a 'real' winter, you should ask us guys in Canada who live in sub-arctic conditions for half the year!!! Up here, if they had an election on global warming, a lot of us would be campaigning for the YES side!! LOL |
Posted: Fri Jan 09, 2015 9:09 pm Post subject: |
| Digger89L wrote: |
How about "frost shields" that went on the inside of the windows?
They were clear plastic and were spaced out from the glass with a gasket creating a form of insulated glass. I even had a very deluxe glass model that had 6 volt electric heating wires in the dead air space. |
Posted: Fri Jan 09, 2015 10:49 pm Post subject: |
| Yes ...the frost shields were definitely an option as well. However, they were unsightly during the "poor skating" period ....and generally just quite ugly, all things considered! |
Gary Haberman Samba Member
Joined: October 18, 2013 Posts: 72 Location: Farmingdale, NY
Posted: Sat Jan 10, 2015 7:27 am Post subject: cold start |
| It was 17 degrees in NY where I live. My '66 bug which I am restoring and leave outside would not start; then again I'm sure the battery is run down. My '62 sunroof bug lives in a heated garage-I pushed her out (why start it to move it 30 feet) and pushed the '66 in to continue working on it. I was able to start the '66 later in the day after charging the battery and warming it up. When I went to push the '62 back in it wouldn't move-I tried to start her and she lurched forward-and it wasn't in gear-WTF! Luckily I searched here to find that this is normal in cold weather-now I'll clutch it next time when it's so cold. This site is such a great source for information. I'm also changing my oil to 10W-30. When I was in college, I drove to South Dakota in January where the temp was -25. The morning after I got there, the car wouldn't start-I had it towed to a service station where the mechanic told me that I should have 5w oil in it-when he tried to drain the oil, it wouldn't come out even when the strainer cover removed! He had to use heat lamps to warm up the engine. |
Posted: Sat Jan 10, 2015 8:25 am Post subject: |
| Interesting cold weather tales! BTW: now I'll clutch it next time when it's so cold. ....you should ALWAYS 'clutch it' when you start a standard transmission engine: handbrake on, one foot with the clutch pedal down, the other ready to press the gas pedal down. Always 'clutch it' ....warm weather or cold ..warm engine or cold. Less wear and tear on the starter if you're not turning over the transmission AND the engine when you're starting. Good habit to get into. |
EA812 Samba Member
Joined: December 07, 2008 Posts: 1231 Location: North central, CT
Posted: Sat Jan 10, 2015 8:31 am Post subject: |
Left work at 11PM last night it was outside since 3PM temp was around 11Β° started right up. I just push the pedal slowly to the floor once, set the choke and be ready to gas it again once it starts. Sometimes it will stall sometimes not. I hold the clutch pedal in also.
Car 1966
engine 1600 Dp Built from parts of three different engines and old NOS Nipon P&Cs
trans: it may be the original
Converted to 12V _________________ Project 66 Daily Driver http://www.thesamba.com/vw/forum/viewtopic.php?t=538786&highlight=
Herbie build
http://www.thesamba.com/vw/forum/viewtopic.php?t=336044 |
EA812 Samba Member
Posted: Sat Jan 10, 2015 8:46 am Post subject: Re: Extreme Cold Weather Starting Thread 2015!! |
| itskyle wrote: |
Data
date
time
I'll start.
Apparently we're in the same boat weather wise! Mine was in the garage overnight when it went down to 0Β° so it was only 1Β°. Its a detached unheated uninsulated garage😃 I went out to start it when it warmed up to 9Β° an tried to video it. That time it stalled. _________________ Project 66 Daily Driver http://www.thesamba.com/vw/forum/viewtopic.php?t=538786&highlight=
Herbie build
