johnnyrotten I Cure Seizures!!!
Joined: January 06, 2004 Posts: 1211 Location: Behind the security gate
Posted: Tue Jan 27, 2015 5:35 pm Post subject: Ghia trunk metal ... Smooth or undercoated? |
My 64 Ghia is headed to paint soon and I'm going over the details.
The inside of nose/trunk area has a textured paint to it. The car has been resprayed a different color but I am returning it to its original white. Should the trunk/inside of spare/nose area be smooth or have undercoating with factory paint over it? This is going to be a show quality build and was wondering if anyone has an original paint survivor Ghia in the year range of mine that may be able to shed some light. Any info would be greatly appreciated.
Thanks,
John _________________ Enemies are friends in reverse..... G. Busey
In the garage....
64 Ghia
66 beetle
56 Oval rag
58 ex-art project Beetle
A fleet of parts buses and ghias |
berliner Samba Member
Joined: December 27, 2006 Posts: 440 Location: west coast canada
Posted: Tue Jan 27, 2015 6:04 pm Post subject: hood |
My '64 has the undercoat/sound deadener under original sea blue _________________ I'm part of the problem. |
Posted: Tue Jan 27, 2015 6:18 pm Post subject: |
On inside of trunk lid too or just the inside metal (inner fenders, spare area and around gas tank?
Thanks for your reply _________________ Enemies are friends in reverse..... G. Busey
In the garage....
64 Ghia
66 beetle
56 Oval rag
bill iler Samba Member
Joined: September 09, 2004 Posts: 103 Location: atlantic highlands, NJ 07716
Posted: Tue Jan 27, 2015 7:09 pm Post subject: |
I'm referencing my 70 which should be the same- This car is very original and although the front section was resprayed last fall, it was done exactly as original-
The underside of the front hood has the slightly-rough undercoating treatment. It is only on the actual sheet metal areas, and not on the strengthening frame that it is welded to-.
No other area has it- the entire inside area including wheel humps, spare well, near gas tank etc is all as smoothly finished as the outside paint. |
ernstben Samba Member
Joined: April 30, 2005 Posts: 622 Location: Manchester, Mi
Posted: Wed Jan 28, 2015 8:42 am Post subject: |
bill iler wrote: |
This is how my '63's nose was as well in original Pearl White. _________________ Ben
'63 Ghia Coupe Project
'59 Panel Project
'56 Ragtop Project |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8237 Location: San Dimas
steveoutlaw Samba Member
Joined: November 14, 2014 Posts: 211 Location: Woodbridge, VA
Posted: Wed Apr 29, 2015 5:16 am Post subject: |
Resurrecting - I'm getting ready to do my trunk area as well.
Sooooo......
Are you saying that the underside of the trunk lid should be done in the rough undercoat and everything else in the standard paint? Should it all be standard paint? How about the gas tank, should that just be standard paint?
Thanks. |
Posted: Wed Apr 29, 2015 6:02 am Post subject: underhood paint |
By 'trunk' I am referencing the front nose of the car, not the engine area in the back, just to be clear. Hood refers to the lid that closes on top of the gas tank/storage compartment....I'm basing my reply on my very original Ghia's paint.
The backside of the hood's sheet metal skin, gets a slightly rougher surface- sort of a mild undercoat. Everything else that is body color, meaning side panels, the extra braces, and supports that are also on the underside of the hood. The hinges, entire inside of the nose, etc all get paint that looks the same as the outer paint. The gas tank, on my cars, has the black paint on it just like the engine tin, except for the unpainted fuel gauge. Hope this helps. |
Posted: Wed Apr 29, 2015 8:11 am Post subject: |
Nope, that's perfect. By saying trunk I'm talking the lid that covers the spare and gas tank.
This helps a bunch. |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Thu Apr 30, 2015 5:08 am Post subject: |
From the "Painting Emiko" thread:
kiwighia68 wrote: |
Thanks djway: I use your post to make this list for textured paint:
Underside of front hood, inner section (not the frame parts)
Inside doors (outer skins)
Inside rear quarters
Outside of footwells - under fuel tank
Wheel wells
Under rear luggage section
Underside where rear wheel wells meet the interior compartment
Underside of the roof (my car has textured residue there)
EDIT: Inside engine compartment, outer quarter skins
I think it may be a good idea to do the complete inside of the wheel wells for the reasons you mention. Maybe the underside of the rear trunklid as well. |
_________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
