aircooled_cy Samba Member
Joined: September 22, 2010 Posts: 29 Location: Cyprus
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18042 Location: Eugene, OR
Posted: Tue Jan 27, 2015 4:47 am Post subject: |
They are lathes that could be used for measuring/turning camshafts? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Tue Jan 27, 2015 10:26 am Post subject: |
What does the tag say on the first one? _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17628 Location: San Diego, California
Posted: Fri Jan 30, 2015 11:45 am Post subject: |
If I were to guess I'd say you chuck up a camshaft in there and rotate it checking to see if it's straight. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23109 Location: Oklahoma City
Posted: Fri Jan 30, 2015 12:12 pm Post subject: |
I have seen pictures of the first tool somewhere being used for checking run out on transmission mainshaft and for chucking a shaft with a clutch disc on it for checking disc run out.
it really could be used for checking runout on any shaft that will fit in it. Ray |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20811 Location: Sandpoint, ID
Posted: Sun Feb 01, 2015 11:09 am Post subject: |
raygreenwood wrote: |
This. _________________ You can't spell sausage without "USA"! |
