Belgian 1976 bay window kombi resto.
jfdestree
jfdestree is offline
PostPosted: Sun Feb 22, 2015 3:07 pm    Post subject: Belgian 1976 bay window kombi resto. Reply with quote
hi all.
I want to introduce you my 76 bay window project. I started it a few years ago, working on it by myself and learning body work along the way at the school of trials and errors. So be kind with me if some of my first jobs are not as good as the later!
I bought it thinking it's was a good basis to start. Well, not so much.
A previous owner liked to travel across France
I first wanted to mechanically overhauled it and enjoyed it this way for a few time before restoring it, but one thing leading to another, I ended with a completely dismantled bus!
Both steps looked like this. A mess made of fiberglass and bondo.
I wonder why people spend time to make a bad job when doing it right the first time is not much difficult?
Rear corner. Right and left looked quite the same.
Cargo floor was a bit damaged as well as some braces. I decided it will be easier to remove half of the floor to get a better access and replace everything.
Both left and right looked like this too ...
I welded a new sill on the driver side, but later decide to remove the two side panels as they where full of dings and dents.
Some C pilar repair ...
New inner and outer rear valence were needed.
As the bottom of the bus was now solid again, decided to sand it. It has been repainted 3 times before and I didn't wanted to add another layer on it.
At least, both doors are in good shape!
I did have to repair the windshield, rear door and sliding door glass but cannot find the pics.
Sliding door bottom corners needed some repairs too;
Cab floor needed some welding too.
After sandblasting it, I trailer it to my in laws body shop get it painted. That's when I decide to change both left panels, following the advices of the shop guys. It was pretty clever that it will be more cost efficient and will give a better end result to change them. As the parts are readily available in VW quality, it was not to difficult to do. The only mod to do is to fill the fuel hole that is on the left side of the bus.
oops
Nice view.
The panels are now welded and I start to prep it, but I lost all my latest pics, I did them with my phone but I drive over it with my truck... 26t are a bit too heavy for a phone Laughing
The bus now sat this way for a few months. Not a lot's of time to work on it and I'm not confident enough to prep it myself. I was a bit stuck as the bodymen at the shop does not have time to work on it, and doesn't have lot's of motivation for this kind of work too...
But, a few weeks ago, a friend offer me to help prep it, so we normally will start to work on it again next weekend. If everything goes well, I can hope to have it painted at the end of spring!
Wink
driverinmyhead
driverinmyhead is offline
PostPosted: Sun Feb 22, 2015 4:03 pm    Post subject: Reply with quote
Wow! Nice work! Should be a lot of fun when it's all finished!
All of the stickers are cool too. Well travelled! Hope you are planning to keep those.
Are you going back to the same color combo?
Thanks for sharing......
jfdestree
PostPosted: Mon Feb 23, 2015 4:22 am    Post subject: Reply with quote
Hi,
Thanks, That's indeed quite some work to restore a type2... I hope It will turn good when finished.
I don't plan to put the stickers back on it but I will keep this window and put another one. Faded stickers on a new paint doesn't make sense to me but I will keep the window as all the stickers are part of the kombi previous life. Ho, and I don't like stickers.
speaking of his previous life, I believe his first job was police van! OG paint is white and I found some traces of the typical fluo orange stripes while sanding it and there was 3 holes on the roof where a beacon light once was bolted . It later had been repainted taïga green and finally the two tones paint job it was sporting when I got it.
I'm still not sure about the final paint. I really like chianti réd or maybe a two tone paint job or put it back white as it originally was...
BusPriest
BusPriest is offline
PostPosted: Mon Feb 23, 2015 7:28 am    Post subject: Reply with quote
Awesome awesome stuff!!!
You're going to have an amazing bus soon.
As far as paint= you can always just paint it white and have a vinyl wrap put on bottom to make it two tone. That way you can have stock and your two tone![/u]
jfdestree
PostPosted: Sat Feb 28, 2015 9:45 am    Post subject: Reply with quote
My kombi is back in my workshop Surprised
It's been months since nothing had been done on it. I have a friend that will come every Sunday and help me finish to prep it and paint it.
The 2 panels I changed.
The fuel trap I had to weld.
From the inside.
We epoxied the front as I had begin to prep it
Thrasher22
Thrasher22 is offline
PostPosted: Sat Feb 28, 2015 10:46 am    Post subject: Reply with quote
Awesome work! I bet it feels great to get some paint on it. You must know what you're doing with metal work, that's very clean.
1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701
jfdestree
PostPosted: Sun Mar 08, 2015 7:28 am    Post subject: Reply with quote
Well thanks, but I'm a DYI'er and this is the first big resto job I ever do.
I did not know a lot when I start this, but I thought that if somebody else can do it, I should at least give it a try Wink 5 years later, it's still not done but I sure learned a lot along the way! I hope it will also give people confidence to start a project on their own.
I found a couple others pics on my laptop.
Last Sunday job. We should have work on it this Sunday, but my friend had to cancel our work cession.
First coat of filler. Each weld spots needed a skim coat of plastic filler.
As it was cold ~5°c, I bought two 1700w electric radiant heaters. Good buy!
Before starting to work, Rudy take a few minutes to check every panels. Every dings, dents etc are spotted. He notes which kind of filler is needed. #1 is for liquid filler (for the lightest defcts), #2 is place to use plastic filler and #1+#2 is for the biggest defects. He use Rage Evercoat filler. Didn't know this brand but work much easily than the one I used previously (Autocolor and Kent.)
This are earlier pics when it was at the bodyshop, I sprayed some etching primer on it to prevent it from rusting.
Welding in the side panels. It sure helps to have acces to a spot welder. The shop got another brand new one, but this old one is dead simple to use. Work still great, but have cooling issue. Had to wait it to cool after a few spots weld were done...
jfdestree
PostPosted: Sun Mar 08, 2015 7:48 am    Post subject: Reply with quote
And found some pics of another job I did for a friend. His 79 bay failed to MOT due to rust issues. When your start developing skills, friends always find something to do to help you practice Rolling Eyes Laughing Laughing
First, sand blasting to have a nice clean area to work and find how bad things are...
After some more grinding to find a good place to start the repair.
Patch welding with a 3mm thick scrap sheet of metal. I didn't butt weld it as I feel it is more solid this way.
Welded in place.
I bought a torsion tube repair kit I found on Ebay UK. Great stuff, a bit expensive but give a nice solution for job like this.
Front wheel repair.
New jacking point from Autocraft in UK, top products!
Done and an happy camper. Not a show quality job, but he is back on the road and passed MOT succesfully!
WestyPop
WestyPop is offline
PostPosted: Sun Mar 08, 2015 8:28 pm    Post subject: Reply with quote
Nice work. Looks great! Congratulations.
Hit the road & have fun... needs more stickers!
Never underestimate the power of stupid people in large groups.
______________________________________
J.R.
68 Westy
(+ others)
jfdestree
PostPosted: Sat Sep 24, 2016 6:42 am    Post subject: Re: Belgian 1976 bay window kombi resto. Reply with quote
Long time without update... Progress are much more slow as expected, but I think it is normal with any "project car" Laughing
Sooo, we finally get the body prepped. All is in a last coat of surfacer and we keep the last sanding cession just before painting it.
I focused on the bottom of the bus, Rudy want it to look as good underneath as the rest of the body. I didn't planed to get that far, but hey, I'm not that on a hurry now...
I removed the front beam, rear suspension arms and every other bits that are bolted to the bus. Will have them sand blasted and powder coated for a clean durable finish. I removed the old underbody coating, wax, grease as much as I could and it was a pita! Next one, I will have it sand blasted for a much more easier, quicker and cleaner result! Lesson learned.
Clean everything with thinner and spray some Standox self etching primer. Next, I will redo all the seam sealer, then spray some epoxy primer follow by a thin coat of anti gravels and finish it in body color. Should look great and for a long time!
Still a long walk, but every step is closer of the end!
jfdestree
PostPosted: Mon Sep 02, 2019 12:17 pm    Post subject: Re: Belgian 1976 bay window kombi resto. Reply with quote
Almost 3 years later...
My Kombi is finally off to the painter. After talking with a close friend during Le Bug Show at Spa-Francorchamps, he advices me a good painter to do my bus.
I had to fabricate some body dollies to move it from the lift where he was proudly sitting for the past 3 years.
I ended up with this.
And on the trailer to, finally and hopefully, got some paint on.
I still have to decide which color... I was set on a VW cherry red and white roofskin, then I found that Gemini blue would be cool and now stay with the original paint which is pastel white, not very exciting, but no risk taken.
Clatter
Clatter is offline
PostPosted: Tue Sep 03, 2019 2:41 pm    Post subject: Re: Belgian 1976 bay window kombi resto. Reply with quote
Applause Applause Applause Applause Applause
Bus Motor Build
What’s That Noise?!?
jfdestree
PostPosted: Wed Sep 04, 2019 4:28 am    Post subject: Re: Belgian 1976 bay window kombi resto. Reply with quote
Thanks you Very Happy
jfdestree
PostPosted: Thu Jul 09, 2020 11:51 pm    Post subject: Re: Belgian 1976 bay window kombi resto. Reply with quote
Didn't update this post in a while...
My bus had been painted Very Happy
The painter got some free time during confinement and spend it on it.
I change my mind again about the color and finally choose savannah beige... I had to repaint the frame and wheelwells to match and apply Raptor bed liner in matching color.
Quite happy with the result Very Happy
Masking
Underbody painting using polyhuretane 2k paint
Wheels well painted with tintable Raptor liner. I used a paint gun with 3.0 nozzle. I expected a more rough texture, turned out better Very Happy
jfdestree
PostPosted: Thu Mar 28, 2024 1:46 pm    Post subject: Re: Belgian 1976 bay window kombi resto. Reply with quote
Long overdue update Laughing
Progress on this project is quite a bit irregular to the say the least.
Dashboard had the usuals previous owners hacks. Various holes and butchered radio housing
some cutting and welding required.
I used krinkle paint and was pretty pleased with the result.
I also clean up the mess in the background Rolling Eyes Wink
I then start to rewired it,and I'm now fighting to resolv some odd. I ordered a new SWF turn signal switch and ignition switch and hope it will solved some of those problems.
finally, some life is coming back into it Cool
To avoid burning wires, I power it using an old battery charger with a 15a inline fuse.
