Street exhaust suggestions
itsmebryan
itsmebryan is offline
PostPosted: Sat Mar 21, 2015 9:34 am    Post subject: Street exhaust suggestions Reply with quote
I just finished building a very mild 1776 for our (my 16 yrs old son and I) project car here is the setup:
Stock heads
Stock rocker and ratio
stock heater boxes
Dual 40 Kadron carbs modded by Kaddie shack
Pertronix Flame thrower vac adv. dist and coil
Norris 329s cam (about a 100 engle )
carter electric fuel pump
engine has been balanced
stock flywheel
I'm looking for an exhaust that is will matched for a daily driver. I'm not looking for race setup just, a good match for my setup. I'm going to ran heater and this car will end up going to my son.
Thanks in advance.
vwsb74
vwsb74 is offline
PostPosted: Sat Mar 21, 2015 9:54 am    Post subject: Re: Street exhaust suggestions Reply with quote
Stock heads
stock heater boxes
stock flywheel
Thanks in advance.
If you lowered the rear get the sidewinder if not get the bugpack merge headers .
74 super beetle
2011 ford explorer traded
2010 mazda 3 hatchback
2014 Honda odyssey
2180cc 48IDA clone
Xr310 cam =171hp@6k rpm sold so as the car😢
itsmebryan
PostPosted: Sat Mar 21, 2015 10:08 am    Post subject: Re: Street exhaust suggestions Reply with quote
vwsb74 wrote:
Stock heads
stock heater boxes
stock flywheel
Thanks in advance.
I have a 2" drop in front and stock in back. Does the merge headers come with muffler also will they work with my heater boxes? Is the Tri-mil dual -quiet any good?
mark tucker
mark tucker is offline
PostPosted: Sat Mar 21, 2015 12:47 pm    Post subject: Reply with quote
1 3/8-1.5 merged should do fine.side winder if you want.trimill has a cheep one but not equal length tubes,but still should do fine for what your doing.
GTV
GTV is offline
PostPosted: Sat Mar 21, 2015 12:49 pm    Post subject: Reply with quote
Standard 1 3/8" header is fine.
EMPI Power Rules!
bugguy076
bugguy076 is offline
PostPosted: Sat Mar 21, 2015 3:57 pm    Post subject: Reply with quote
If you want to go old school, Empi still makes the part #3300 header. The muffler is welded right onto the pipes. I have used one for years on my street car.
Grubby Fingers Racing
1976 Drag Bug
1967 Street Bug
vwracerdave
vwracerdave is offline
PostPosted: Sat Mar 21, 2015 4:21 pm    Post subject: Reply with quote
Tri-Mil "Hotdog" muffler would be perfect. http://vwparts.aircooled.net/Tri-Mil-Hotdog-Muffler-VW-Beetle-and-Ghia-p/tri-mil-hotdog.htm
itsmebryan
PostPosted: Sat Mar 21, 2015 4:45 pm    Post subject: Reply with quote
You would recommend the ones above over these? http://www.socalautoparts.com/product_info.php/tri...ps-p-15721
vwracerdave
PostPosted: Sat Mar 21, 2015 4:55 pm    Post subject: Reply with quote
Your engine is not big enough to need the dual QP's anyhow. For a 16 year old kid absolutely get the hot dog muffler. He will tear dual QP's off dragging the speed bumps in the school parking lot.
itsmebryan
PostPosted: Sat Mar 21, 2015 4:57 pm    Post subject: Reply with quote
ok, Is the Hot dog very loud?
BIGMIKEY
BIGMIKEY is offline
PostPosted: Sat Mar 21, 2015 5:16 pm    Post subject: Reply with quote
I think that exhaust sounds like a hollowed out peashooters or the flared tips in a stock muffler. A bit louder. Nice though. I like the increased ground clearance over a 4 into 1 too.
Mike T
BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue.
bugguy1967
bugguy1967 is offline
PostPosted: Sat Mar 21, 2015 8:34 pm    Post subject: Reply with quote
Al's headers makes 1 3/8 merged headers. Also, Lenin-something sells them in the classifieds.
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
gt1953
gt1953 is offline
PostPosted: Sun Mar 22, 2015 8:14 am    Post subject: Reply with quote
http://chircoestore.com/2-tipp-gt-style-exhaust-type-1.html
I have this one on my 1776 and my 1745. Sounds fine fits fine and looks fine. My deep sump hangs lower.
72 type 1
72 Squareback
