DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6249 Location: SBS headquarters: Missery
Posted: Wed May 20, 2015 6:10 pm Post subject: Nose emblem location measurement |
A hack welded in new metal and drilled my hole about 1/2" off center. To ensure I put the emblem back where it's supposed to me I need a measurement. I figure the most accurate would be from the lower lip to the center of the upper hole. Can someone measure that distance please and post up? Thank you! _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
hitest Samba Member
Joined: September 30, 2008 Posts: 10332 Location: Prime Meridian, ID
Posted: Wed May 20, 2015 7:39 pm Post subject: |
Since my lower lip has a radius where the skin breaks toward the front (like all of them do- approx. 3/16" qtr round), I measured from a much more precise point- the bottom of the windshield frame down to the top hole. It's exactly 158mm frame seam to the center of the hole- using a tape. _________________
| EverettB wrote: |
FU#5 |
Posted: Thu May 21, 2015 5:15 am Post subject: |
I was thinking of using a tape measure to clip the lip, but that works brother! Thank you!  _________________ Anthony
SBS #1
SBS #1 on FB
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2345 Location: Kelowna, BC. Canada.
Posted: Thu May 21, 2015 7:42 am Post subject: |
Heck yes Gordo! Thank you. _________________ Anthony
SBS #1
SBS #1 on FB
olliehank47 Samba Member
Posted: Thu May 21, 2015 8:00 am Post subject: |
| You may also notice the two side holes, which correspond with the indent between the V and W in the logo, are directly in line with the center of the screws for the turn signal lights (in Gordo's photo, the notches for the lights.) This is what I used to line up the logo on my bus. |
