61 BUS  Samba Member
Joined: January 05, 2005 Posts: 710 Location: Tucson, Arizona
Posted: Sun Nov 23, 2025 1:37 pm Post subject: 2001 Eurovan GLS - Cranks But Won't Start |
A few days ago, my check engine light came on. I did an OBD2 scan and got error code P0411 Air Injection Incorrect Upstream Flow Detected. No other error codes in any other system. The car still drove fine and I was planning on troubleshooting the aux air system. Today I went to start the car to check out the if the secondary air pump runs and the car wouldn't start. It turns over but won't catch. I did another OBD scan and there are no additional error codes. My battery is relatively new (about 7 months old). With the ignition switch off, it measures about 12.3 volts. When cranking, it drops to about 10.5 volts. There are no unusual sounds when cranking, just no-start. Any troubleshooting suggestions or ideas would be appreciated. This is my first foray into a non-air-cooled "modern" VW. Thanks. _________________ 61 Bus, 2001 Eurovan GLS, 2013 Fiat 500 Abarth, 47 Plymouth Business Coupe, 58 BMW Isetta 300 |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11605 Location: Oregon
Posted: Sun Nov 23, 2025 2:09 pm Post subject: Re: 2001 Eurovan GLS - Cranks But Won't Start |
What scan tool are you using?
Most here use the VCDS scan tool. I have tried the auto parts store scanner and found that the VCDS will detect more fault codes than the FLAPs scan tool.
Sometimes, simply disconnecting the battery for 15 minutes to half an hour will clear things up with the ECU.
Have you looked for any blown fuses, especially for the fuel pump?
Someone way smarter than I will chime in with better ideas than what I have posted today.
Welcome to EV hell! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
61 BUS  Samba Member
Posted: Sun Nov 23, 2025 3:32 pm Post subject: Re: 2001 Eurovan GLS - Cranks But Won't Start |
My OBD2 scanner is an Innova 5610. I did check the fuel pump fuse and it's fine (it has continuity). _________________ 61 Bus, 2001 Eurovan GLS, 2013 Fiat 500 Abarth, 47 Plymouth Business Coupe, 58 BMW Isetta 300 |
Damian Shaw Samba Member
Posted: Sun Nov 23, 2025 5:38 pm Post subject: Re: 2001 Eurovan GLS - Cranks But Won't Start |
| 61 BUS wrote: |
| A few days ago, my check engine light came on. I did an OBD2 scan and got error code P0411 Air Injection Incorrect Upstream Flow Detected. No other error codes in any other system. The car still drove fine and I was planning on troubleshooting the aux air system. Today I went to start the car to check out the if the secondary air pump runs and the car wouldn't start. It turns over but won't catch. I did another OBD scan and there are no additional error codes. My battery is relatively new (about 7 months old). With the ignition switch off, it measures about 12.3 volts. When cranking, it drops to about 10.5 volts. There are no unusual sounds when cranking, just no-start. Any troubleshooting suggestions or ideas would be appreciated. This is my first foray into a non-air-cooled "modern" VW. Thanks. |
Start with the basics:
FUEL - pull the source line off the fuel rail and have someone turn the engine over / be careful that thing will squirt a lot if your pump is good.
SPARK - remove a spark plug wire and using a spare spark plug (I know - prob go get one) connect the spare spark plug into the wire and hold the plug threads against a good ground... Have helper crank again and watch for spark - should be a strong blue spark jumping the gap of the spark plug.
If you have both (you probably don't) look for a massive vacuum leak like the air-intake boot being ruptured or disconnected.
Message the forum back with your results.
(and yeah: welcome to Eurovans!)
Damian |
SambaBurnsRed Samba Member
Joined: February 07, 2025 Posts: 93 Location: object:1698
Posted: Sun Nov 23, 2025 9:19 pm Post subject: Re: 2001 Eurovan GLS - Cranks But Won't Start |
Need to get a scanner to check your crank position sensor, that will cause no start, easy fix too.
Also fuel pressure if the CPS checks out. |
jjvincent Samba Member
Joined: January 11, 2016 Posts: 1489 Location: Bethlehem, PA
Posted: Tue Nov 25, 2025 11:00 am Post subject: Re: 2001 Eurovan GLS - Cranks But Won't Start |
Most likely, it'll be a fuel pump. If it's a crank position sensor a generic OBDII reader will pick up a faulty one of them. It's not the immobilizer as if it was, it would run for about a second and shut off. As for the coil packs, it would be rare for them to lose power.
As for fuel, it'll never throw a code (EV is too old) and a good fuse does not mean the fuel pump gave up the ghost and ended it's life. I would guess if you could search here for where the fuel pump relay is, then jumper it. If you do that and there's total silence, then it's the culprit. If it does run you can also still open a fuel line and see if fuel comes out. |
Da TOW'D Samba Member
Joined: December 25, 2005 Posts: 1402 Location: Bella Coma Canada
Posted: Tue Nov 25, 2025 11:29 am Post subject: Re: 2001 Eurovan GLS - Cranks But Won't Start |
Give the Air Intake at the Air Filter a shot of Starter Fluid then crank
If it starts you might have a Fuel pump problem _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'69 Karmann Ghia Convertible (new project)
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS |
TheOneTrueQuux Samba Member
Posted: Tue Nov 25, 2025 1:05 pm Post subject: Re: 2001 Eurovan GLS - Cranks But Won't Start |
| jjvincent wrote: |
A quick and dirty test for a bad fuel pump is to give the bottom of the fuel tank a few good thumps, preferably while power is applied to the pump and see if it then starts. A rubber mallet or dead blow hammer works great for this. _________________ Josh
1995 EVC
ACU, 098 |
