Finally VW Samba Member
Posted: Fri Aug 07, 2015 7:16 am Post subject: DIY Firewall Insulation |
I just about ready to put a 67 back together that I bought in parts. I would like a new firewall kit probably from Chris V, but I don't want to drop the $ at this time (gonna drop the motor for a full rebuild in two years). Has anyone made their own firewall kit? I read a post regarding layered 30lbs felt from a big box, but there wasn't much explanation. Does anyone have any input or ideas? |
grandpa pete Samba Member
Posted: Fri Aug 07, 2015 11:54 am Post subject: |
I put sound deadener /insulation on the INSIDE of the firewall .
For the engine compartment make a paper pattern ; you can cut three pieces of rolled roofing and glue them together with roof tar... Be careful that you use only full pieces . You don't want anything breaking off and getting pulled into the fan .
OR
New 3 piece kit $54 Wolfsburg West _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
jzjames Samba Member
Joined: September 27, 2007 Posts: 1921 Location: Windy Point, WA
Posted: Fri Aug 07, 2015 1:13 pm Post subject: |
If you want to make your own firewall insulation panels here's a tip;
The best material I have seen is a product called Dibiten.
It's a roofing membrane that comes in a roll, is equal to the thickness and quality of the OE engine compartment insulation.
If you can get it somewhere, it's what you want.
Need to get the ''smooth both sides''. Not ''granulated one side''.
It's heavy, thick and stiff, pretty much resembles the original.
Google Images for Dibiten. |
